Michael,
This build just gets more and more impressive everytime.  Those beads are almost too perfect.
Your leather work was nice but it seems a shame to cover up such nice jaws.
Bob
Current build:  SS_ Mariefred
Mark thanks for your comment,
Bob I am thinking of only covering the inside curve that could chaff on the mast, so instead of stitching the leather like a glove I am thinking of glue with a row of tiny tacks along the top and bottom edges. more like this
Michael
Edited by michael mott
I think that may be a bit more correct. I'm no expert, but on the odd wooden gaff that I have seen IRL, that was how it was done.
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
Andy thanks for the confirmation, I was looking at a sketch in John Leathers book The Gaff Rig.
Michael
Carlos thanks for your comment. In John Leather's book he mentions the copper plate and said that it also was a cause of problems on the mast and that sometimes it caused some rot under it.
Michael
nice work on the beads and gaff.....look forward in seeing her with some color :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hello Michael
here´s a detailed foto of the jaws ,we can see exactly the leather
On this foto we can see the rings around the mast for the main sail
By the way ;are you registed in facebook ? I ´ve many fotos to share
Best regards
Carlos thank you for posting those two pictures they are very informative.
I am not on Facebook, and have no intention of getting on it either. I do have email and I do enjoy this forum and have a photobucket page.
Regards Michael
Impressive scale and impressive model :) Excellent craftsmanship Michael
Current build: LA MARTEGAOU
Past build:
BRACERA
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do... Sail away from the safe harbor. Catch the tradewinds in your sails. Explore. Dream. Discover"
KIND REGARDS!
ELMIR
Akutansin, Elmir, thanks for your kind words.
I have been chipping away at the gaff, literally
using the shrink tubing i made a wire strop for the gaff
and was pleased with my stops set into the gaff they are boxwood
And now I know that the drawing in John Leathers book was correct and that the chock stops face the same direction
The wire is too stiff though so I need either thinner softer wire or I will use rope, I prefer the wire so will look at what options there are for that.
I did haul up the gaff using the blocks it was fun threading the halliards, I did a quick and dirty job of tying the halliards with hitches, I keep running out of shackles and blocks! and I take my hat off to all you folk building and rigging fully rigged three masters, that would send me to the loony bin.
It is interesting thinking about the different types of blocks needed for the rigging to function properly though.
The thing I need to address now is some cleats and belaying pins.
Earlier in the day I was working on the other boat.
Michael
sweet looking rigging Michael.......you've achieved realism.   that's the beauty of it!   if you were to put weight on it,  does it conform to shape?  perhaps that's all it lacks...........nicely done!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I was also wondering if a mock set up for the gaff strop and some tension on it would shape the wire to the 'V' it should be.
Rigging on the mast is beautiful, but I agree the wire is too stiff.  Some insulated electrical wires are very flexible, maybe if you remove the insolation and color the copper . . .  I'm sure you will figure something out you've done so good so far.
Bob
Popeye, and Druxey.
I did put a little tension on the gaff to see what effect that would have and I was concerned that the combined weight of the sail and boom even with some tension would not be enough to overcome the stiffness of the wire which is .047 which in 1:8 scale is 3/8th an inch which seems a little heavy anyway. if I use the .024" wire it is a little over 3/16th in scale. so I will see how that looks.
Michael
Hi Bob
We must have been cross posting, I am going to see what I can do with the smaller beading wire cable first.
Michael
The .024" plastic coated Beadalon 49 strand wire works well. This is with the boom hanging loose and no extra tension, I need to get some smaller diameter black heat shrink. and make the loops bigger but I am happy with the way it is hanging. Also I need to reverse the inside chock. I think I will also make a small saddle for the wire to attach to the block rather than just the shackle.
Michael
beautifull rig Michael,
I can`t wait to see more....
Nils
Current builds
-Lightship Elbe 1
Completed
I had a look at various rigs for gaff peak halyards.. Seems like when rigged like yours, it could also have a block on the static wire. So you could have a sister block, or two separate blocks joined at the strop. It you google image search "gaff peak halyard" there are some great images of various arrangements.
Either way, she looks great.
Andy
USF Confederacy
Michael,
Just catching up after a long holiday to find that your rigging is progressing beautifully.
The Bristol Channel pilot cutters usually had a saddle on the span, but there are also old photos showing the use of a block, so take your pick.
John
Beautiful workmanship Michael. Well done.
With the obviously highly developed skills you have I was wondering what a cutaway model would look like - what with all that internal joinery work in the cabins, etc, etc...??? Maybe a future project...
And a very nice workshop too!
Michael
member of
United States Naval Institute
Royal United Services Institute
Society for Nautical Research
Navy Records Society
author of
The Art of Nautical lllustration - A Visual Tribute to the Classic Marine Painters, 1991, 2001 & 2002
United States Coast Guard barque Eagle, 2013 (Blurb Photobook)
former assistant editor of the quarterly journal and annual
Model Shipwright and Shipwright 2010
Hi Nils thanks for your kind remark.
Hi Andy thanks for the comments I did have a look at the web images I am not sure I fully understand you comment though about sister blocks.
Hi John good to see you back from holidays, I am going to make a saddle for the wire span, just haven't got there yet.
I did make a twisted shackle yesterday it allows the block to stay in line with the one on the mast.
I made a better one today after a lot of mucking about with form tools for the brass turning.
Michael
Michael thanks for your kind comment, seems we posted at the same time. regarding your question about cutaways for myself it is not in the cards if I build a boat then it goes into the water, and unfortunately the water would just pour into a cutaway.
Jay thanks, I need to get a move on or I will never get this puppy in the water. Actually I do want to get the hull painted soon but I want to finish off the main rigging hardware white the mast is in place , I can make the rest of the deck furniture and all that after I remove the mast. Since I am making it up as I go along, and not following an exact set of plans it is a bit of a learning curve.
Michael
B.E. thanks for stopping by.
It interesting working on each aspect separately as the need to operate the rigging and sails dictates what I have to make next. each task seems to require more research into how things are done.
Last evening I was able to make the rail for the bottom of the mast the posts knees and rail are all from different colours of maple they are not glued yet. The posts are set through the deck and abut the beam in front of them.
The belaying pin is a placeholder to see what they would look like the final ones will be from Lignum Vitae.
Michael
Silly question perhaps, but wouldn't all the edges of the coamings and other deck fittings be chamfered or rounded off a little? The model looks terrific, though.
