HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Got a little further with the hinge. After making a hinge joint, the strap halves and horseshoe shaped half were filed and shaped to be about 1/16" wide. After shaping, the straps flare out only at the hinge joint.
Hanging on to the little pieces to file and shape them was done using a modified pair of Channelock 718 pliers. Here you can see the groove for the hinge joint which was done with nut slotting files. The final width of the groove is .042".
Here's a better look at the pliers. They are ground down from a long nose and have smooth faces to grip with, so they don't mar the parts being gripped. It's nice to be able to simply rotate your wrist to better see what you're doing.
Here's the hinge after more shaping. It's almost ready for some detailing.
-Buck
Current build: AL Morgan's Whaleboat (1st build)
Kits in the ships locker: I cannot confirm nor deny that there may be a few kits in there...
I agree with Carl, Incredible!
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Try?  You seem to be succeeding, Buck.  That's more than "try".   Where's Yoda when we need him to explain "try".... :D
I started working on details and did a little test piece on some scrap brass. I filed a slot to make a screw head in some .032" brass rod. I scored the slot with an exacto blade and then deepened it with a .010 nut slotting file. I then smoothed and shaped the screw head with a file and used a Sharpie felt tip pen to darken the slot a little. The excess ink was filed off.
I drilled a .032" hole in a scrap piece of brass and here's how the scew head looks in it.
Best wishes
-Buck
:o  Wow!
Thanks Mark & Carl! You probably already know this, but if you click on one of the pictures you can enlarge it with your mouse wheel on a computer or stretch it with your fingers on a smart phone. I can only focus so close with my iPhone camera so it helps to enlarge the pics. Sorry if you already know this, but happy to help if you didn't!
EDIT: I forgot to mention that you have to press the control button when using the mouse wheel.
Edited by Salty Sea Dog
-Buck
Just a quick update. I finally got the new mast hinge assembly built and just need to finish the parallel boards with some garnet shellac to match the thwarts. The boards are notched at the front ends and beveled at the back and combines ideas from Scoot's 1st and 3rd pics.
-Buck
Once again I bow before the master! So incredibly awesome!
Matt - aka The Squirrel Whisperer
Current builds - Benjamin W. Latham by Matt
Competed builds - USS Ranger by Matt
HMS Bounty Launch by Matt
18th Century 10" Sea Mortar by Matt
18th Century Naval Smoothbore by Matt
Future builds - Willie L. Bennett Chesapeake Bay skipjack (MS) Half Moon (Corel) Emma C Berry Lobster Smack (MS)US Brigantine Eagle (Corel) New Bedford Whaleboat (MS)
Beautiful work Buck,
I like your whaleboat very much...
Nils
Current builds
-Lightship Elbe 1
Completed
Buck, that is superb work on the hinge and the screws. Thanks for the tip about enlarging the images on the screen I did not know that one.
Michael
Wow, Buck.  I haven't been around too much, so just catching up on your build.  While she may be a tad picky, it appears that Becky has indeed sent you along a good path!
Amazing looking work on the brass bits.  Any idea what's next in the lineup?
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Thanks Michael, Jeff and Wayne! I was planning to do the Mamoli Carraca Atlantica next but am switching and doing a double build of Billing Boats Zeeschouws. I've been in touch with our old friend Keith, aka The Mad Chemist. A while back I had sent Keith my Zeeschouw kit to lift his spirits because Lyme disease had him in a slump. I came across another one on eBay last year and broke down and got it. This 2nd kit was missing parts so I asked Keith to trace them for me. Keith ended up sending the kit back to me because the Lyme has progressed to the point where he can no longer build it. So my plan is to build both and send one back to Keith.
-Buck
Glad to hear you have had some communication with Keith.  Last time I talked with him things were not very good at all.
Jesse
That's great to hear, Buck.  I'm looking forward to the double build.
I hope everyone is doing well and had a good weekend. I got to spend some quality time in the dry dock and got the new mast hinge installed. The new hinge sits higher up at an angle because of the fore and aft boards and it caused the mast to lean back (the plans show a forward lean). So the solution was to build a mast step with cleats to position the mast at the proper lean. I could have taken the easy out and just made a wood chunk but that doesn't seem to be in my nature. :) So I opened up my small piece wood locker to scrounge for suitable pieces- everybody has one of these too don't you?!
So the mast step has a box jointed front corner and dadoed in cocobolo strips to position the mast.
The mast step sits at the bottom of a box under the hinge to add a bit more detail the more you look. Got to keep Matt and Ferrit amused!
So far, no snarky notes from the inspector!
-Buck
Nice work on the mast-hinge, Buck. Good to see that the mean ole Quality Control lady let it pass through.
:D  :D
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
I see the problem... the quality control lady is a redhead.   :D  :D  :D  :D    Nice going on the hinge rework, Buck.  You've got a good eye for detail.
Excellent!!! I don't have any tools small enough for that!
Thanks Captain Steve, Mark, Matt & Lawrence. Thanks for the very nice compliments Lawrence - my head is getting so big, my neck hurts! :) It was a lot of fun making the tiny bucket for you, and your Annie turned out amazing. A belated Merry Christmas and a happy New Year to you and everyone.
Best Wishes
-Buck
