ChrisLBren
Everything posted by ChrisLBren
  1. Thats a really handsome hull Ed ! Love the lines
  2. Totally hear you on the warping issue - I experienced it myself when i was trying to source plywood during the winter of 2009 on Confederacy. Why not just use the station frames and pair down the amount of frames from 66 to 22 and save the wood and the trouble since you're fully planking.
  3. I agree with Nigel - why not just build her POB since Hahns plans do not depict accurate framing and you intend to fully plank anyway. Frolich has a couple magnificent examples of POB builds in his book that look better than quite a few full frame builds to say the least.
  4. In the 74 Gun Ship Series there are only 6 Station Frames drafted. You would need to draft the others - which again if you should be able to do with all of the information provided. You may want to reach out to Gaetan B - he has build the French 74 three times in three different scales. Hope this helps, Chris
  5. Hey Mark, Sorry to hear but totally get it. Like Gaetan mentioned - maybe consider an Ancre Monograph or a Swan ? I just think the plans are so much better as they are newer. Whatever you decide to build - look forward to following your log. Chris
  6. Hi Michael, I built the Wappen (at least the complete hull) back in 2001. The kit I purchased had the metal carriages - so i scratched them. The one tip i can give you is make sure to check the elevation of the gun ports in the former near the bow before cutting them out (the semi circular piece - don't remember if it was wood or pre fab wood). These are not correct on the instructions. On the plans they are correct. I had to make adjustments after the fact - not sure if they ever corrected this. Good luck and have fun with your build, Chris
  7. I bought the 74 Plans from Bourdriot first from a seller on this site. In order to decipher them - I bought the first three volumes of the 74 Gun ship from various sources including ebay for Volume 1. The plans do correspond with the fold outs in the books themselves as you've already mentioned. It is an idealized representation of a 74 - not an actual ship. I am using these volumes as a guide to build Le Gros Ventre and the Commerce de Marseille as L'Orient - since both of these monographs have full hull timbering drafted for you. You will need to do a little drafting in order to build the 74 full frame. It wouldn't be an issue if you wish to build her plank on bulkhead. Hope this helps, Chris
  8. Damn - nice work Remco - and looks like it was fun !
  9. Hi Iran, I agree with starting over here - depending on how bad the twist was. My rear bulkhead former was slightly warped (less than 1/16th of an inch in the rear corner when placed on a piece of glass face down) At the time I couldn't get any perfect plywood as it was winter in Chicago and after so many botched attempts (I was new to the scroll saw at the time) - I settled for using it. I too thought extra formers would fix it - it never did and i spent the rest of the build compensating for it. Its not too noticeable on my hull - only from certain angles. If you look dead on my stern and its fixed perfectly perpendicular in the build board, then look at the beak head bulkhead - it lists slightly to the port and vice versa looking at the stern from the bow. You can find my log under the scratch build sections if you haven't already seen it. Chris
  10. Looks sweet Rusty - please keep us posted on your experience with the Sherline - i think thats my next must buy tool along with a Byrnes disc sander. If I can just get some time to finish up the head rails on Confederacy…..
  11. Hi Don, La Belle and the Le Gros Ventre both have full frame drawings and could be good targets for you. They could also be build POB. La Jacinthe is also a nice model - that is designed as a POB build as it doesn't have frame drawings. You could loft those if need be. You won't be disappointed with any of them. Take care, Chris
  12. Looking good - I don't mind the sheen - Im sure the flash from your camera is enhancing it ! Brings back memories from my build three years ago when I was at that stage ! Chris
  13. Hey Kevin, We are all our own worse critics - trust me - I almost gave up on my Confederacy build a half dozen times - mostly because it wasn't meeting my own perception of "perfection" Stick with the build - again I admire anyone who can build like you with plastic - lord knows I can't….. Happy holidays, Chris
  14. Looking great Mark - Happy Holidays !
  15. Looks great Rusty - i can't tell from the photo - do you have a top finish on it or not ? Ive seen the dyed used with or without - personally i like a bit of glow on my dyed wales so in my case Danish OIl Worked well as does Tung Oil. Im sure Wipe On Poly wood have a similar effect.
  16. Hi Rusty, Good luck with the Fiebings - love this stuff - just make sure to mask everything - it splatters easily. Chris
  17. Nice work Bob ! I know how tricky building those lights can be from my experience on Confederacy. Really well done
  18. Love it !!!!! The use of one wood - Pear - and iron fittings - looks spectacular !
  19. Thanks Alexandru - Ive got the Commerce de Marseille Monograph - another 3 decker - and am thinking about building her in 1/48th. Enjoying watching your build, Chris
  20. Hi Alexandru, I'm admire your work immensely - curious - how long long ago did you start your build and when do you foresee finishing ? Also will you mast and rig ? Thanks, Chris
  21. Thanks man - I'm merely imitating Bernard Frolich's approach - using boxwood, swiss pear and dyed swiss pear to resemble Ebony - all woods sourced from Hobby Mill - which I can not recommend highly enough.
  22. Thanks guys - next up the head timbers - which should be fun/challenging. I've got plenty of 1/8 costello boxwood! Then its really all down hill from there to finish her up.
