Posts posted by SawdustDave
Tiny little swab buckets are the current challenge. Five down, fifteen to go. Update soon.....
- JesseLee, Piet, CaptainSteve and 3 others
6
Similar findings here Greg.
Played around with both and concluded, I like the look of fixed shot garlands just above the base of the bulwarks and tend to believe that would have been the method used on the SOS..... sticking to it. lolThanks for the input Mate.
Bill....beautiful figures.
I'm guessing the lady on the left must be at least a 38DD cup.
- mtaylor and CaptainSteve
2
Progress update.....
Couple of quickie shots after finishing up all the gun ports....also note the tree nailing finally done.
Then, moving inboard, all of the main deck cannons have now been rigged.
Next, I'll be adding the tiny swabs and rams (so often neglected in models of war ships)...,.
Note: This shot reminded me, I still need to add the quoins to each cannon carriage.Trying to decide on the use of shot garlands, or brass monkey's for this ship. I'm leaning toward shot garlands mounted on the bulwarks. I can't find anything to tell me when brass monkey's came into use.
Would appreciate any input from some of the historians on that issue.
Also playing around with some very small swab buckets and powder boxes.
From what I'm reading, the smaller deck demi cannons on the upper decks would have been supplied with shot boxes, rather than shot garlands or brass monkeys. We'll cross that bridge whinst we arrive there. -
A little blood goes with the territory guys. Just clean it, throw a band aid on it, and carry on.
But then, of course, if you wish to OVER BANDAGE any little scrape, in order to gain sympathy from the Admiral .... Or use it to avoid the dreaded "honey do" ....
That's just another ball game altogether.
Make the bandage large....use reddish paint to add blood stains....make it easy to remove and put back on.
- mtaylor, CaptainSteve and gjdale
3
Nothing wrong with using card stock for such fine cuts Nenad. Looks same when stained or painted, and makes life much more simple for sure.
- mtaylor, Gerhardvienna, GLakie and 6 others
9
The crew will appreciate the accommodations of the heads Bill.
Good to see the beak bulkhead developing.
Lovely work.
- CaptainSteve and mtaylor
2
Playing catch up on this build Chuck. The ropes look great....very natural. Question about the red carriage trucks.
Forget that question....I plowed back to #647 where you addressed the issue of truck color.
My two cents, for what it's worth.... black trucks break up all that red and add definition to the profile of each truck.
Going through your log makes me want to build her again....much slower of course.
Cheers
Dave
- mtaylor, Seventynet, GLakie and 1 other
4
Bill....As you know, we all tend to be our own worst critic....right?
While seeing virtually every single flaw in our own work, and wishing we had done a little different (cleaner, more precise, more accurate, etc.), we look at the clean perfect work of a fellow modeler as flawless examples of how we SHOULD have done it.Personally, I consider this as a very good thing about having MSW friends.
Otherwise, how would we ever improve our skills. -
Not much to report this morning. I guess this posting is mainly just to say "good morning" to my MSW friends after a few days of not posting any progress.
Finally finished installing all of the gun port lids to the port side.... both sides now completed. I'm not going to bore you with redundant pics of the same result seen in my earlier posting of the starboard side.
Planning to rig a few more main weather deck cannons today before moving back to sculpting the figures for the beak cowling.
I'm sure you all agree, it's great to see our friend Bill Short back in the shop after a long absence. His SOS has been such an inspiration to me in my feeble effort.
Welcome back Vivian.... we look forward to seeing new pics of your progress, once you are able to take them again.
So clean.... so beautiful. But I still refuse to rip my bulkhead off and start over Bill.
Loving to see you back in production my friend.
- CaptainSteve, mtaylor and WackoWolf
3
Eye popping. Did you use gold leaf for the gilding or a paint?
David B
Dave B.... Good Q....
Considered melting down some of the Admiral's necklace's, ear rings, etc. (she would never miss them...RIGHT?)
Na.... What a foolish question!
After experimenting with several different gold metallic paint options, looking for the brightest gold on the market, I landed on RUST-OLEUM - AMERICAN ACCENTS - 2X ULTRA COVER.... METALLIC bright gold (spray can).
I found it to be a noticeably brighter gold than any other I tried.
Purchased at Lowe's Home Improvement stores anywhere.
I first spray the parts by sticking them, face up, onto a piece of masking tape inside a paper plate. After thirty minutes, carefully remove the sprayed parts, clean any paint flash from the edges, then lightly brush on a finish coat with my smallest detail brush.
Occasionally, the camera will point out a flaw in the way light is reflected on the surface, and I can refinish the flaw, even after the piece has been glued in place.
- CaptainSteve, mtaylor, UpstateNY and 7 others
10
Transom Complete........
All transom carvings completed and the lantern now fitted.
Think I might should take a little break before I begin to tackle the transom counter. It appears to be pretty straight forward.
Mostly, I just need to do a few more cannon ports and some tree nailing as a change of routine.
- paulsutcliffe, dgbot, Canute and 19 others
22
Sometimes the ability to zoom a photo spoils the effect of the subject, specifically when these are miniature carvings. Just like a fine painting, they were not met to be viewed at super close range but rather from a distance as the artist has created this image for that purpose. Some of my carvings look fine from a distance of say 2-3 feet, but close up they change.
Regards,
Bill
I'm so glad you pointed that out Bill.
Love the new beak construction. Beautiful work as usual.
Dave
I like version 2 very much but do like the dome on version 1, looks like the dome on some of the old Florentine cathedrals. Nice work Dave.
Cheers,
I too preferred the more rounded dome shape Pete.... I lost the contour with all the grinding I did to keep the 8-sided shape tapering from bottom to top.
Anyhow.... AIN'T DOING HER AGIN!
Thanks for the visit BV, Patrick, Greg, Bill and Mobbsie.
Most say, the transom lantern is such a critical piece to the overall appearance of the iconic stern of the SOS, if necessary, I would have built it several more times to get it right.
As model fixtures go, I would put this one among the most difficult scratch builds I personally have ever tackled. Bill might agree with that assessment.... told me he did the little top three times.
Off to a good morning...
Three new carvings to fill in the panels on the transom.....only 25 to go before I can attach the transom module to the stern.
Had to interrupt progress in order to chase a little round ball around a course with sticks ill designed for the appointed task.
- CaptainSteve, GLakie, popeye2sea and 8 others
11
Lantern.... Version II
I took a much more deliberate approach to rebuilding the lantern housing. Went to Autocad and created a template for the windows.
Then made a jig to insure exact size and squareness of each unit and a pin jig to insure string spacing for the window screens.
The overall result of the second lantern is much closer to being acceptable in terms of scale and quality.
Here's a comparison to the two units....
And here's the new lantern dry fitted to the transom....
Took only three days for the second unit considering everything went pretty smoothly.
Now....Back to a few more transom carvings.
Very nice job Nenad. Very nice!
- GLakie, CaptainSteve, Omega1234 and 4 others
7
Thanks guys....appreciate the nice comments.
However, after taking a good long afternoon nap, came back to the shop to re-study this most important piece.
Unless I change my mind after a nights sleep, I will likely begin version II of this fixture tomorrow morning.
What the hey! Bill Short's postings has a quote I cannot argue with....
"Mediocrity will never do. You are capable of something better.” ― Gordon B. Hinckley
Thanks for the reminder Bill
Update - Transom lantern housing:
Seems like I've been working and re-working this little fixture for at least a month. Keeping a reasonable octagon shape and matching up the base with the windows and then the top was very frustrating.
Finally managed to tweek it enough to live with the results.... dry fitted as seen here.
My only concern is the overall height of the lantern housing, which is the result of my shaping the radius of the roof. My eye says it should be slightly flatter.
After looking at it for a few days, and before gluing the fixture in place, I'll decide whether to reshape it or not.
Meanwhile....any opinions and comments from the crew is welcome and appreciated, as always.
- CaptainSteve, Kevin, John Allen and 13 others
16
Sovereign of The Seas by SawdustDave - FINISHED
in - Build logs for subjects built 1501 - 1750
Getting the proper scale of these little swab buckets was most critical.
Fairly easy to create out of walnut dowel....the brass strapping and wire handle makes them pretty time intensive.
Only sixteen more to go!
