Posts posted by Landlubber Mike
Nice catch there Egilman. It is surprising how some of these kits missed what seem to be basic obvious details, got them backwards, etc. Maybe just working off a picture or two, and not as much research? On the other hand, I guess we are spoiled to have kit manufacturers like Wingnut Wings and Zoukei Mura that put in tons of research for accuracy.
- Edwardkenway, Egilman, Canute and 5 others
- 8
I highly recommend these Micro-Jig Grr-Rippers. The picture below shows it on a full size table saw, but you can get a 1/8” leg and so I use it on my Byrnes saw. Much easier and safer than using push sticks.
Another great safety accessory is a cross-cut sled. You can order one from Jim if you have a Byrnes saw.
I feel very fortunate to not have suffered an injury thus far. I find it best to first think about the cut and make sure you tick off your safety list. For me, my list includes things like eye protection, where am I standing, appropriate blade height, and visualizing and setting up how am I supporting and pushing the wood through the blade. I always wear short sleeve t shirts and would never wear gloves!
I’ve often had to stop myself when thinking to do a “quick cut” to take a step back and make sure the safety y precautions are taken. My guess is rushing and getting too in a groove to the point you’re not fully concentrating are some of the biggest contributors to accidents.
- bruce d, thibaultron, Wintergreen and 6 others
- 9
Another beauty Chris. I still can't believe that it is build from card, amazing work!
I really like the effect you are creating with the washes, etc. To me, this avoids the "plastic" look you see on a lot of car models. Nice job!
- mtaylor, popeye the sailor, Egilman and 2 others
- 5
Glad to see you back on this Kevin. I've got one in the stash with the GLS upgrade, but need to get my modeling skills cranked up a few notches first. Great job!
- Canute, Kevin, Old Collingwood and 1 other
- 4
Looking really great! These are going to be spectacular when done. Nice job!
- popeye the sailor, Egilman, Canute and 3 others
- 6
3 hours ago, Beef Wellington said:
Hi Mike - yes they do taper, and I took exactly the same approach used for the quarterdeck planking described in post #668, being about 3mm at the bow and 3.8mm at the waist, and re-used an appropriate section of the template used to shape the quarterdeck planks rather than creating a new one. I've found that until you really get well into it, the curve is rather hard to discern, but the good news is that there isn't the same constraint as on the quarterdeck to terminate against the waterway.
Ouch sorry Jason, I hadn't scrolled up to read your approach. Thanks for passing it along, very clever!
Looks really great Jason!
Are the planks tapering as they get to the bow? If so, and you don't mind me asking, how are you cutting those planks? On my Pegasus gun deck, I didn't bother tapering the planks at the ends of the deck as they wouldn't be seen, but I'm considering whether to taper them on the upper decks. Haven't quite figured out how to go about doing so, aside from measuring and cutting a very slight taper on one side of the plank, and then squaring the ends.
Looking forward to this one!
- Canute, Old Collingwood, mtaylor and 1 other
- 4
3 hours ago, shipman said:
Mike, you did a good job.
Somewhere in my loft stash is the 1:200 Nichimo kit.
Of course, size isn't everything. but....mine is much bigger than yours! LOL
Thanks Shipman! 1/200 would be a really big kit, almost twice as long as this one! Looks like a nice kit.
- Jack12477, lmagna, FriedClams and 5 others
- 8
Proxxon DB250 would be a better bet in my opinion.
- thibaultron, DaveBaxt, Keith Black and 4 others
- 7
15 minutes ago, JohnB40 said:
Mike, Stunning piece of modeling once again. I find it unbelievable when I reference the scale to the Tamiya jar. I'm looking forward to viewing your destroyer diorama.
John, thanks very much! I think I said this before, but the kit and Infini detail set are what do most of the work here. I'm just trying not to mess things up too much. Thank goodness for Optivisors and fine tweezers though!
Hey Glen,
There are a number of different techniques you can use. Some use this technique, others add clay to a base to get the waves, others use artist watercolor paper, and then there are those that carve the sea out of wood. In part, I think it depends on the scale you are working in and how rough the seas you are trying to portray. So for example, if you were working in 1/700 scale, the watercolor paper approach should be just fine. Working in a larger scale or with rough seas, paper wouldn't work I don't think.
For the seas here, I followed the general technique by Scale-a-ton on YouTube. He has a few different builds on his channel with this technique. I think I used an amalgam of what he shows on his various videos, so take a look at his ship builds. I'm infinitely grateful that he took the time to share his techniques with the rest of us!
Essentially, the steps are:
1. Get a board (I used insulating foam board from Home Depot), cut it to size, mark the outline of where your hull will sit.
2. Crinkle up bits of aluminum foil and put them on the board using white glue. When finished, put white glue over the entire board, and put a full sheet of aluminum foil over the top to smooth out any sharp points.
3. Next comes paints - I primed with white Mr. Surfacer, followed by a light and irregular spray of Tamiya sea blue. Then you spray Tamiya gloss clear over everything, followed by Tamiya clear blue, followed by another coat of Tamiya gloss clear. You can add in other colors (grays, blues, greens, etc.) as you see fit. The key is to not add a full, heavy solid coat of any of the paints, but keep the airbrush moving so you get interesting variations and tones.
4. Then you add the hull to the board, and use heavy gloss gel medium to build up the seas and spray around the ship. I used Liquitex. You can use cotton dabbed with the gel medium to indicate spray (the cotton stays white). I haven't tried this yet, but for larger waves, you can build them up using bits of toilet paper which turn clear when the gel medium is added.
5. Finally, you can use paints (white, light blues, light greens, etc.) to help indicate the wakes, waves crests, disturbed water around the ship, etc.
It seemed like a very easy technique for my first time, and so far has worked pretty well on both my 1/700 and 1/350 builds. For my current Yaeyama 1/700 build, I might try the watercolor paper technique shown in this Vallejo video as I'm planning on showing the model anchored in still waters.
I'm on the home stretch with this build. Managed to add some other details including the wood slats in the rack near the funnels (used some cherry veneer I had, cut into thin strips and used wipe-on poly), then weathered and added the final clear coat last night. Will add the torpedos and carts, the small boats, and figures, and then rig the model and add flags. For my first 1/350 plastic ship model, I'm really pleased with how it's turning out.
As a little preview, given how fast and sleek the Shimakaze was, ever since I got the kit, I thought presenting the ship in a waterline setting would really show it off. So, I built a waterline diorama base for the model as well. It's made of foam board using the crinkled aluminum foil technique. I built the frame for the diorama using balsa strips that I got from National Balsa in the thickness I needed, that I cut to size and stained. I first practiced making a waterline diorama for my 1/700 destroyer, which is just about done, and can post pictures of it in the next couple of days. This one obviously is a little bigger but so far so good.
Thanks for looking in!
In between other projects, I try to squeeze in a little time on this build. I added a few more details, including the searchlight (not included in the kit for some reason) and these vertical tubes along the hull sides. Google translate on the Mara book suggests these are ash chutes, so I guess a way of disposing waste from the ship's engine? Since I'm at the point where it's not worth the risk of adding other more fragile details to the model (especially if I have to tape around them), I got the linoleum deck taped up which took quite a while.
Last night I put on a coat of Mr. Surfacer 1500 black primer and worked on main gun at the bow and the small boats. I also starting thinking about the waterline diorama for the kit, marking out a piece of foam board for it.
So, this is moving along pretty quickly relative to most of my other builds despite not spending as much time on it. Coming out pretty nicely I think. With the experience of the first 1/700 build, I feel like I'm not getting stuck as much or breaking things off in mishandling the model as I did on the destroyer.
- mtaylor, Ryland Craze, Canute and 3 others
- 6
I tend to agree with Chris. It's supposed to be fun, not something you are going to dread for a long slog of the build. You could always try scratch building one on the side, and if it's going well, keep at it. If it is causing too much angst, just go back to the kit.
Whichever direction you take, I'm sure it will look fantastic in the end.
- Canute, Old Collingwood, lmagna and 8 others
- 11
That looks fantastic Alan. Really nice job!
- Old Collingwood, Canute and mtaylor
- 3
You probably already know this, but you can remove some of the tackiness of the tape by first putting it on your skin, then on the model. That removes a little bit of the adhesive and may lead to less pulling of the paint. I've done this with Tamiya tape and it still works fine.
Another thing that might help is to let the primer cure completely. When priming, I let it sit for a good 24 hours. Acrylics are tricky in that they dry quickly but have a long curing time.
To be honest, I haven't had much problem with Vallejo pulling off on plastic. It's usually on PE that's the problem.
- king derelict, mtaylor and Canute
- 3
I use Vallejo’s thinner with their paints and primers. I don’t use Vallejo on areas that will be taped as I find it can pull off.
When I first got my airbrush, I thought you could rinse acrylics thoroughly through the airbrush with just water and not have to do a more detailed cleaning. With Vallejo, however, I find it leaves a residue which will gunk things up. So, I clean out the nozzle, needle, etc. after every session. It’s sorta soured me on Vallejo, but otherwise I like the color coverage, no fumes, and not having to mix in thinner in the cup. To really clean it, you can shoot lacquer thinner after shooting Vallejo but I know you don’t want fumes.
Now I’m more a fan of Tamiya and Mr. Color, even with the pre-mixing and fumes. I find the paint cleans out of the airbrush much more thoroughly than Vallejo. But, certainly understand why you don’t want to go that route.
Looking great Glen! Clever use of the nails for the shrouds!
If your nails were like mine, I think they are used to pin the planking to bulkheads. I use them to help pin the first planking, then remove them when the glue dries. I don’t use them to pin the second planks though.
- Keith Black and mtaylor
- 2
I’d probably be reluctant to scratch the assembly. Given how distinctive and symmetrical it is, you’d really have to get it perfect or it will look odd, especially with how much visual interest the boom has. Not saying it can’t be done just I wouldn’t trust my modeling skills on that! Could always try it out and see how it goes?
If you use brass, would it be too heavy and make it a tail sitter?
Looking great Egilman! Very intricate work on those harnesses which you pulled off perfectly.
- lmagna, Edwardkenway, Egilman and 6 others
- 9
Bell Helicopters HTL-4 (MRC) & H-13H (Revell) 2 for 1 By Egilman - FINISHED - 1/35th scale
in Non-ship/categorised builds
Lou, maybe we should have been kit designers. Our wives think we are perfect and never make mistakes.
