ccoyle
Moderators
Everything posted by ccoyle
  1. Doris, I'm afraid there are not enough superlatives in our language to describe your work -- it is truly outstanding in every respect. Cheers!
  2. Okay, everyone -- slow down! The problem here is that opinions were expressed, and then opinions were expressed about those opinions, and then ... well, you know how these things go. I think everyone agrees that this is Henry's model, and ultimately he can do with it whatever he wishes. So, let's leave the opinions aside for now and let Henry get on with his restoration. Back to you, Henry!
  3. Where do you want to begin? Unboxing? Starting the build? Already part-way through the build? It's up to you.
  4. Just noticed this in your signature. HMV beat you to it. 😉
  5. So I just now finished putting the second coat of epoxy on the coamings. This was such a small amount of epoxy (one squirt each of resin and hardener) that I announced to the womenfolk that I wasn't going to change into my grubbies for the job. Doubt was expressed about whether I could do this without making a mess. Ten minutes later, upon coming in from the garage, the following conversation was had: Me: "I'm done." Wife: "Did you get any on you?" Me: "No." Daughter: "Then I owe Mom five bucks." 😆😆😆
  6. Great subject. I added a bit to your title for those of us (perhaps only me) who had no clue what 'HDML' stands for.
  7. It looks like you made a good recovery!
  8. Finally an update. Have been working on this project slowly, interspersed with with bits of boat building. I now have White Tail's fuselage completed to the same stage as Spanish Nationalist. Remind me not to build any more airplanes with W engines -- three cylinder head covers per plane got kind of tedious. 😬
  9. Duke of Abercorn was launched in 1919 as TSS Curraghmore, renamed in 1930, and scrapped in 1935. This model suits your skill set, Valeriy -- you should build one!
  10. Forgot I needed to add the coamings. These were about 3 mm too long, so I used a sanding drum in my Dremel tool to take off the extra length and to round off the edges.
  11. Good luck! Interesting shop you have there -- very tidy, and with an enviable stash of plastic kits in the background!
  12. Looks fabulous, Jan! I hope you will create an album for her in the gallery. Cheers!
  13. A lot of old sailing workboat designs found second lives as pleasure craft, so I'm sure that taking liberty with the kit's rig and color scheme is not unprecedented.
  14. Man, that is taking a Guillow's kit to a whole new level! All of the balsa-and-tissue models of my youth came to assorted sad ends. 😬
  15. Nope -- just didn't know what the "V model" was. Now I know!
  16. Today I applied the second coat of epoxy to all the interior surfaces using a roller. I also applied the first coat of epoxy to the rails (except for the exterior underside -- the reason for that should be apparent) and epoxied the decks in place. Tomorrow I will give the rails their second coat, along with the decks' first coat. I'll give the decks their second coat during the week sometime and then be ready for exterior epoxy next weekend.
  17. Hello, Murat. It looks like you are using a set of kit plans as a source for part templates. Can you tell us about the plans?
  18. Hey, Steve. Build logs are the heart of our forum. You can read about how to set one up by clicking here.
  19. Whom did you purchase the kit from? Model Expo will replace missing parts from kits. If it's a private transaction, you're probably out of luck. But -- we have plenty of members who have built that kit and may be able to help you out, especially if your post title is more specific and your question is posted in the correct subforum (hint hint). I took care of it for you this time around. 😉
  20. Steve, start up a build log and show us what you've got so far. Your catboat probably has a relatively straightforward gaff rig, and we should be able to get you over the finish line. Cheers!
  21. Sziggy, I'm not sure how you are adding attachments to your post, but you should use the file uploading link that shows up in the bottom-left corner of the reply window (example below) to upload pictures. Practically no one will want to view your photos by sequentially opening a series of downloads -- too time-consuming. My PC couldn't even open the files.
