gjdale
Everything posted by gjdale
  1. Thanks again for the kind remarks and all the "likes". After a few weeks of absence from the shipyard due to work and other commitments, planking is at last complete! The remainder of the deck was completed in much the same way as the fore deck, with the hatch being left in place and planked together with the rear deck. The hatch was cut free on completion, the hatch openings and rear cockpit opening cleaned up, and the transom was then planked in much the same way as the sides of the hull. The transom was trimmed flush with the deck, sides and bottom of the boat, and then the decks were given an initial sanding with 80 grit sandpaper. The aim of the initial sanding is to bring the white caulking strips down level with the deck planks. While it was not difficult to do, it did require a little more elbow grease than I’d anticipated. Anyway, here she is as she sits today. The “spare” hatch is in the foreground (in case my two-part hatch doesn’t work out). There’s still quite a bit more sanding to be done before she will be ready for staining and fibre-glassing.
  2. I'll second Slog's vote of confidence in the Airbrush Megastore, Greg. Excellent service, great advice, good prices, and very quick turnaround. There's also a series of videos on their website. Paul Budzik's videos on YouTube are also excellent and well worth taking a look at.
  3. Paint job looks great Slog. The extra effort was well worthwhile.
  4. Rob, When I built my Bomb Vessel cross section I used a technique called "painting with wood", where I used different spieces of wood instead of paint to achieve the same effect. Link to my build log in the signature block below if you're interested. I've described where I've used each timber spieces within the log.
  5. Congratulations Druxey, on what will almost certainly be a best seller. I've given the Admiral a big hint (link to the SeaWatch page ) as I have a birthday coming up in a few months time.
  6. Well done Kevin, and I see from the photos that you have the domestic testing facility ready for sea trials too!
  7. Great to see you back Sarah. I'll look forward to following along with this one.
  8. Congratulations on reaching such a significant milestone Gary. She looks superb!
  9. Thanks Tom, I've been avidly reading through a bunch of logs and "how-to"s over on the RC Groups site. Plenty of good advice there, as well as some great examples. Even though I've never done it before, I'm pretty confident that I'll be able to make a reasonable job of it. Worst case - sand it all back to bare wood again and go the epoxy resin route instead.
  10. It may be slow Mike, but it sure is beautiful! Great work.
  11. Thanks Bob and Tom. Tom - yes, the hull will be fibre glassed. This will be a first for me, so stay tuned!
  12. Thanks very much Bug, Popeye, Lawrence, Rusty and all the "Likes". A minor update this week.... Deck Planking Planking the deck has presented no particular problem thus far. The instructions direct you to alternate a caulking strip with a plank, but I found it easier to laminate one of each together and then shape and fit as a single unit. The only tricky part of shaping was the last plank on either side around the side of the cockpit, which just took a little time and patience to ensure a good fit. The ends of the planks were trimmed close to the forward end of the cockpit and then taken closer still with a sanding drum in the rotary tool, before finishing by hand. Once all the planking is complete, the surface will be sanded level such that all caulking strips will be level with the planks (at the moment they stand just a little proud). Not bad for a day’s work! There will be a brief hiatus for a couple of weeks as I’ll be travelling with work.
  13. Neat idea for the oars support Jack. Looking forward to seeing the final photos.
  14. Good decision John - you won't regret that additional effort and time.
  15. Planking Planking the hull turned out to be a little trickier than anticipated, and included a “near disaster”. Planking the first side, I followed as closely as I could the lining out marks, having first tapered the planks to fit against these. The problem was in the lateral bending of the planks. Ideally, they should have been spiled. However, the planks provided are not sufficiently wide enough to spile (and I didn’t have any sheet stock that I could substitute). The kit planks are also wide enough that edge bending is very difficult, if not impossible. The result was a less than even surface. On the second side, I decided to adjust the lining out marks to allow the first (chine) plank to fall naturally – which took it exactly one strake higher on the lining out marks at the bow. This meant that I had to insert a wedge shaped piece below this plank, but the remaining planks on that side went on somewhat more easily than the first side. The result also meant that I managed to maintain alignment of planks on either side at the bow. The near disaster came when I went to give the hull an initial sanding to even out the surface. Following the lead of others who have gone before me, I broke out the powered mouse sander and set to. I must have been a little too aggressive in one place because I suddenly noticed that I had sanded through the entire thickness of the planking and could see the white plastic showing through. Oops….. I also discovered that on the other side, one plank had developed a hole – not sure how, but the timber is very dry and brittle. Hmmmm, two repairs to make! My first thought on repairing these was to use epoxy putty, but one of them was quite a large area and was going to look dreadful. After sleeping on it for a couple of nights, I decided that I would remove a section of the planking and patch it with new planks. Another few days to consider exactly how to achieve this, and I finally gave it a crack yesterday. I used a mini circular saw blade held in the Proxxon rotary tool and gently made some “stop” cuts at the extremities of the section I wanted to remove. I was then able to insert the blade of a No.11 Exacto knife and prise the damaged planking free. A quick clean up with the drum sander in the Proxxon to remove the residual glue and it was ready for the new timber. I took my time in shaping in the “patch” parts, and even managed to spile some thinner sections to get a very close fit. I also used some epoxy putty (Milliput) to blend the area at the bow where the timber transitions to the plastic sheeting of the hull bottom. After a careful HAND sanding, I was quite pleased with the results. Here are a couple of views of the completed repair job (forgot to take pictures of the “before”). And here is a close up of the bow, showing the alignment of the planking. The stem is not perfect, but as it will be covererd later by the cutwater, I’m happy with it as is. Then, at last, it was time to start on the deck planking. The process starts with the attachment of the edge or margin boards. These are die cut parts, slightly oversized, and are relatively easy to fit. Once in place, the outer edges are sanded back flush with the sides, and a strip of white “caulking” (.04” x .08” styrene) is applied to the inboard edge. The next step is to place the centre plank on the forward deck. This requires that a length of caulking be sandwiched between two planks (3/8” wide mahogany), then shaped to fit the bow and fixed in place down the centreline. Compared to the hull side planking, this was dead easy! The remainder of the deck planking will follow a similar pattern, with a plank being glued to a strip of “caulking” before being shaped and affixed as a pair. I’ll be back when the deck planking is complete.
  16. Glad you found that info Gary. It seems a long time ago now, but I do recall B.E. providing some extra info.
  17. That's a great looking sail there Mobbsie. I think the seamstress deserves a double grog ration!
  18. Granado is looking splendid Bob. Sorry to hear about Cheerful, though I have no doubt you will manage her repairs so that no one will ever know. Now, about that case...........
