Baker
Everything posted by Baker
  1. Beautiful model. Welcome to MSW
  2. And a few weeks ago i sawed wood for masts and spars Before i install the fore castle i have to decide where the shrouds of the fore mast come, and how much. Some info about the lengts of mast early 17th century And it seems that the lower part of the main and fore masts are about the same height on level The number of shrouds on the fore mast also varies a lot (between 3 and 6) Determine mast length in relation to the deck. The fore mast is a little bit shorter than the main mast. The angle to the deck also varied greatly. From right-angled to strongly bending forward 5 is to much, when we fire the cannon, we will do more damage to our own rigging than to the opponent. 4 is better, where one enters the ratlines (on the forecastle) the distance between the shrouds is already much narrower. Thanks for following, likes and comments
  3. Finishing the pumps. As said, the pumps of the Batavia and Duyfken replicas served as an example. A hole is drilled in the centre of the pump. This is where the metal wire comes in that is attached to the pump arm A plastic disc is glued to the base of each pump. Around the base is tissue paper glued with CA glue Pumps painted. The basis is a kind of seal between the pump and the deck (source Duyfken Replica) Ther is no outlet on the side of the pumps like on my "modern" pump. Reason, they do not serve to pump clean water into a bucket. But to pump dirty water out of the hold. Pumps dry fitted in place. 2 options. option 1 option 2 For the moment, i go for option 2
  4. They were rounded with a very poor man lathe (a knive, a file and sandpaper) I should invest in some better material. But ... space, space. no space left to install it The staghors came from the Duyfken replica . The pumps are from the Batavia and Duyfken replica It looks that on Windows 10 everything should work through paid micro$oft programs. That's my problem... Ps, Most things on the lapotop already work back (for free).
  5. Most of my time the last few weeks has gone to installing a new laptop. The old laptop hadn't survived a fatal upgrade to windows 10. And considering I'm no IT specialist , complete installation of the new laptop takes a while ... Building the staghorns The staghors were first completed and then glued on the model. In total there are 10 4 at the waist 4 on the half deck 2 at the fore castle (to be placed later) The places where they are provided are based on these drawings. Building staghorns first glued on a plank after drying cut loose Meanwhile, the construction of 2 pumps has started. Again many questions. On which deck, how much and where do I place them. Which deck? The deck below this deck is expected to drain water to the hold. Therefore, the pumps are on this deck at the waist / rear castle. How much ? Probably 1 or 2. Because we anticipate a long unknown journey. This Pelican gets 2. Where? Normally behind the main mast close to the center of the deck. The pumpshafts should be (visible) on the lower deck. But to be able to drill holes , I will have to remove part of the deck from the rear castle (small construction error ). These pumps will be glued to the deck later. If I place them now, they'll get in the way of the knighthead and I'll get in trouble later. Thanks for following, comments and likes
  6. The Golden Hind : certainly not. Most plans and kits are based on drawings and ideas that were not from the 16th century. No one can say that he is building the right model. But actually no one can say your model is built incorrectly I try to build a Pelican / Golden Hind ( i discovered that building a 16th century galleon is complicated...) The Revenge : maybe It is said that modelkits are designed from a drawing by Mathew Baker, a shipbuilder from the 16th century. Correct?? These are old kits. Designed according to the then available information. Have fun building these models. that is the most important thing.
  7. The little one at the bottom center looks like me when I was younger 😂
  8. Welcome to MSW, and good luck with the first model 👍
  9. This is one of the reasons why i use polystyrene The plank for the belaying pins should definitely be wider. Otherwise, you will run into problems with the rigging
  10. My idea, Probably an original winch is not made of one piece, but from different pieces of wood. And is this misunderstood by the builder of the model, and therefore it has grooves There are also no square holes in the winch?? the ratchet is ridiculously weak : indeed Added the winch of the replica yacht Duyfken And a winch on a drawing (also with "grooves")
  11. interesting lesson in history. But. Dutch, Hollands, Flemish, Frisian. let's say that in this very small part of the world. no one understands each other when he speaks his own dialect. and if you look far enough back in history we might all be a little bit family
  12. Nice stories about hot barrels. My only experience with a "hot" barrel Fired 40 rounds 8 x 57 in a short time with my K98. The barrel became hot, so that through the warm air above the barrel my target (paper card) seemed to "float" Warm oil dripped out of the wood And my shoulder was stiff the next day...🤕
  13. As promised Drilling out a gun barrel Twist with the x acto knife Drilling done Matt black paint Pencil Ps, This is my first post on MSW done on my smartphone and no google translate. A mile stone for me
  14. Yep, Forgetting to tell. I always add about 25% matte black at their gunmetal
  15. I normally use gun metal. With here and there some pencil to get more detail. Matte black and then going over with pencil is also pretty good. Best is to practice first on some leftovers. There is an easy method to drill out the barrel. With a sharply pointed x acto knife. But pictures will tell more than my google english (is for later) Look in my signature at the ADGZ funkwagen.
