Posts posted by flying_dutchman2
Ian;
Cute little boat. I like it. So I am pulling up a chair and observe.
You are coming along very well.
Marcus
- Seventynet and Elijah
2
After the conference and a road trip (1200 mls) up the Pacific Highway and lets not forget a day in Tijuana, Mexico I am have been working on her again.
This picture shows items I used and what I did with them. I have made small nails out of them. I didn't have any.
Piercing holes with a dental drill.
Forming the trim after soaking.
Trim attached and waiting to be dried.
- Ryland Craze, Elijah, cog and 8 others
11
Prepped and painted the bottom - rust red. Came out pretty good.
She is on a makeshift stand.
I have already sanded the mast, boom and gaff according to size. They will all be painted white. Made some of the cleats and so on. The stern is covered with a piece of cherry veneer (donated by Kurt van Dahm).
Marcus
I am done painting-sanding-spackling. I have also removed the tape from the windows and the walnut veneer.
Here I am prepping the boat for a rust red bottom and have marked the rudder with tape. I will first paint the rudder several coats of the same color as the rest of the boat and then the bottom of the rudder will be rust red.
I taped the rudder to the benches to keep it straight and then to be able to draw a straight paint line.
I taped a little level to a dowel which will go temporarily where the mast goes.
Having the stand level on the table and part of the stand where the keel goes into, I can move the boat up and down and keep an eye on the bubble. This is where I need to keep the boat level to draw an accurate paint line.
Marcus
Mike Y,
As Yamsterman said; all wood oxidizes over time. Some slowly some fast. Example: If you had a block of Pink Ivory - 5cm x 20cm x 20cm. After about 10 years the outside layers have lost its pink lustre and the wood is light brown almost sand in color. If you sand off 2mm on all 6 sides the block will be light pink again. The more you sand off the darker the pink color.
I have done this with walnut but the model I built with this wood has been in a display case for about 4 years and the light in the living room has somewhat faded the wood.
If the wood has been properly dried the pink will last. But generally ALL wood fades. UV rays is the enemy of this.
Most of this information comes from a book I have on Arboriculture.
Marcus
I did the research on Pink Ivory and our club will get a mini-presentation on this.
Pink ivory (Berchemia zeyheri), also called purple ivory, red ivory, umnini or umgoloty, is an African hardwood used to make a variety of products (for example: billiard cues and knife handles).[1] The pink ivory tree grows predominantly in Zimbabwe, Mozambique and South Africa. The tree is protected and sustainably maintained in South Africa, only felled by very limited permit.[2][3] The wood is extremely hard, with a density of 990 g/dm3.
The specific name honors the German botanist and plant collector Carl (Karl) Ludwig Philipp Zeyher, 1799-1858 in South Africa.
For the modelers in the US here are some places you can purchase this wood from.
http://www.wood-database.com/pink-ivory/
http://www.exoticwood.biz/pinkivory.htm
http://www.bellforestproducts.com/pink-ivory/MI
http://www.righteouswoods.com/MA
This is the general color. It has many variations
Marcus
- Mike Y, WackoWolf, Seventynet and 4 others
7
Here I am creating mast hoops. I use this excellent book a lot for ideas.
The metal pipe is a roller which I scavenged out of a HP printer. The paper is from a paper bag. I start by rolling the paper to form. Attach one end of the paper with a drop of CA to the metal tube. Heavily coat the paper with Elmer's white glue and slowly roll wrap the paper around the tube. Remove excess glue. Once dry, heat tube and pull the paper off.
I still have to cut it with a razor saw. Once done the book mentions to dilute CA and coat the hoop with it to strengthen it.
I use the metal tube because when I heat it, the CA glue lets the paper go. Don't know the chemistry of it, but it works.
Marcus
I have been sanding - spackling and painting. She is starting to look good. I have more than 10x thin coats on her. There are still some little depressions here and there but I am leaving it at that. I am pretty happy with the results. Planning to do a few more coats of this same color. It is a very light sand color. Could not get a darker sand color in a can. Maybe in the future I will invest in air-brush equipment but I don't do a whole lot of painting.
- FriedClams, mtaylor, tadheus and 12 others
15
Try DELFTship http://www.delftship.net/DELFTship/index.php/delftship/delftship-free
There is a free version I've been using and there are paid versions.
Marcus
Kees,
Houd je taai. (be strong).Marcus
- kees de mol, mtaylor, cog and 1 other
4
Hi Kees,
Take care of yourself!
btw: We sailed from IJmuiden to Newcastle last week,
That is too cool. What type of sail boat do you have?
Marcus
- Piet, mtaylor and kees de mol
3
Just an update.
I have restarted this built while working on the Catboat. The big difference is that, the above POB has been put aside and used for practice planking while a NEW POF is in the works.
I read through this built several times and I am using the suggestions on how to create the frames. I will use 1/4" Baltic Birch Ply for the frames and 3/16" pieces in between the frames.
Frames have been rough cut with the scroll saw and need to be sanded (yes, pictures will follow).
Bottom line............................ this will be version 3. I have learned a lot from just building a scratch hull in both POF and POB.
I need to finish the Catboat first.
Marcus
Very Nice.
Your wood combination is very pleasing to the eye.
I am going to copy your color for my mast, boom and gaff. I like what you did with your blocks.
Now that I see the bright white color of the rigging, I am going to change that. I am going to see what my sister has on her real boat and then check my stash and see what I can come up with.
I will add the sails. For the Catboat I will have my neighbor do all the stitching on the sails. She did them for the HMS Bounty, & Yacht Mary as well.
I have been looking a lot at your built and have learned some things.
THANKS.
Marcus
- Elijah, cobra1951 and Seventynet
3
Marcus,
First of all, great job. Don't put yourself down.
I expect you are working with primer first. Sand it as smooth as possible, then take out the putty. The advantage of primer or paint, is you see the dips before, and after sand the hull. Smooth them out with putty. Another light sanding, and another layer of primer.Sand again ... Check again. if smooth to your liking, last layer of primer. Light sanding and you can finish it of with the colour of your dreams ...
You'll make her shine, I know you will
Cheers mate,
Did the primer only once and sanded it somewhat. Should have done what you suggested. More layers of primer and sanding.
So I did the painting already and I did notice the dips are disappearing. I don't want to paint to thick either. Many edges of the boat will be covered with 1x1mm dowels.
Thanks for the tip which I will use in my next boat (I have a pond Yacht - Solingen 1 waiting).
Marcus
- popeye the sailor, Piet, Jack12477 and 2 others
5
So for the last 3 months I've had little time compared to the last week. Work is slowing down especially with the 95F (30 something C) temperatures and who wants to shop for plants in this heat. I am also taking 2 days a week off as well.
After all the spackling and sanding the boat is relatively smooth. Tapped up areas that need to show the wood.
Now comes the part of building a ship I hate the most. It is called painting. I have never been good at it. I read all types of 'How-To's', I have many articles about this subject. It is just not for me. I try to avoid it like the plaque. But,..... this boat calls for it so after reading some and practicing some I put on the first coat using a can of paint with the correct color. Darkish sand.
Looked good after the paint job was on but after it dried I noticed several spots that were drippy.
Sanded that down and did another coat. As of this morning it is still a problem here and there.
When I look at the hull with a magnifying glass (overkill) there are all sorts of dips and bubbles. So I have decided not to be anal about this and do the best I can. It is a model and I am not trying to win a contest in best paint job.
I can paint little items, but when it comes to what I do now, I get anxious.
Marcus
- cog, Piet, Duanelaker and 5 others
8
Hi Marcus, that's a rather ingeneous solution for those of us who forget to step the mast (ahem). I may just be doing the same thing. By the way, how are you planning to attach the boom?
Just the way the plans show. The templates for the mast come off once the mast is at the correct angle.
Marcus
Pelikaan 1999 by kees de mol - FINISHED - scale 1/75 - Dutch Beamtrawler
Kees,
Thanks. It is the mast in the back that got me confused. I do have several books in pdf form on flat and round boats.
I know the name Petrejus and I think I can find something from him on Google.
Another book I have 'Vlaamse Visserij en Vissersvaartuigen' book 2, by Gaston Desnerck, 1976, bought it a long time ago in Amsterdam at the book store 'de Slechte'. I paid 30 guilders for it and looked it up recently and it is now 330.00 Euros. I am missing Book 1., but I am not going to pay 330.00 Euros for that one.
While I am on the subject there is a freebee floating around from before 1895-1905 called Ship Building from its beginnings by Emile van Konijnenburg, It is in 3 parts and in English. Nice plans, good descriptions and many boats and last but not least several German books on these types of boats. The Germans have written much on this subject.
For the none Dutch people here; The Dutch had numerous types of flat and round bottom boats. Every town that has a wharf has a many types of these boats. For pleasure, for freight, passengers, etc.
Several years ago I started writing an article on this for the Nautical Journal. It got huge as I was describing every boat possible with no end in sight. So I put it away. I can split it up in sections.
Sorry for hijacking the thread......................... back to you.... Kees.
Marcus
