cog
Everything posted by cog
  1. A so you are building/printing the new version RGL, Popeye, and me are building ... Glad I haven't missed a lot, the printer isn't as fast I my slow displacement Interesting build though. Never thought about replacing parts of a resin build to either improve or build another model.
  2. Those may be small improvements, but the make her look good
  3. I like the way your aft funnel turned out! I'll be trying my hand on that one pritty soon. I've got enough left of that, I'll be replacing the reels with leftovers, Nice PE alternative for that life raft platform. Was thinking amongst the same line. I'll be using 0.5mm brass rod, as well for the supports of the gun platforms.
  4. Put on the propeller units, or whatever you call them in English. Replaced the propellor shafts with brass rod A lot more fun to this kit than I thought! Quite a challenge
  5. Today's minor progress: Drilled the portholes (didn't count them) which went reasonably fast Mounted the vents, all nine of them, a pain to get them cleaned up, drilled the holes to get them fixed Forward paravane cradles (big word for such a small piece of plastic) Some squarish block, which I suspect is an air inlet for the engines Put together the rear and front 102mm gun platforms and the connecting bridge, forard platform needs some attention (putty - second image) working on the rear mast, making it from bras rod 0.5mm and tubing 1mm (last image)
  6. I know Lou ... ours won't fit, besides the fact that she will rip it to shreds, but Gibbs will, until Dennis gets "Isolation"
  7. Got used to it, thanks to you, Sam Now I know why I got those Fokker Dr 1's lined up ... How come you don't join in the fun Sam!?
  8. I see you've got your own bench Never a dull moment in your shipyard ... you seem to hop, skip, and jump from one model to another ... It would drive me crazy ... I only have to switch between Musashi, HMAS Vendetta, two 1/700 tiny nip subs, 2 1/72 Fokker Dr1's, and a 1/48 Fokker Dr 1 ... besides all the other things to do(!) By the way, I like the colours. Did you ever try a different type of masking tape ...could solve the problem of your bleeding all over the hull
  9. Nice job John, well worth the front row seat.
  10. Sounds nasty! Africa, Asia, Middle East, South America ... you've got enough choice, but the people to join in ...
  11. Yes it is. Wonderful work, Amalio. You keep amazing me with your sharp details, and very smooth wood surfaces
  12. Don't you need your beauty sleep, mate. You'll be finished before the US has it's kit delivered, even with all the kit bashing you're doing!!! Hello Dave, It's becoming quite an Aussie gathering ... (I'm still missing a.o. Mr "Vulture" Vadas) Fun indeed, something like your class' project building a plastic kit if I recall well ...
  13. Evenin' RGL, Did you get the "old" tool? My deck parts fit rather good. It seems macro photography is required to show mismatches and other wondrous events ... At the tail end you've been sanding rather severely RGL, that might be the reason parts do not line up the way they're supposed to. I've been using a fine sanding stick and 1500P grid sandpaper to get those injection port dimples off. I had a problem with the bilge keels, quite difficult to fit as the points to attach them are hardly visible on the part itself, and on the hull there are three somewhat undefined dents. Could be improved upon, but probably due to the size of the ship. P.s. I like the base you have for her ... colourful!
  14. First steps: Taking parts from their frets, cleaning them up, and dry fitting ALthough it's a 1:350 model, it is small, especially compared to the Tamiya kit I've been working on. The details are pritty good, fitting of pieces is beyond what I expected. The minor thing about it in my eyes are the number of points with which parts are attached to the fret, a lot of cleaning to do
  15. You can use aluminum foil to seal parts where light is protruding
  16. Not much bending to do what I've seen for PE. Stair handrails, which you can do with flat pliers. I think a PE tool would be an overkill for the bending you'll do on this one. I would advise you to buy one for e.q. a 1:350 Hood, or Yamato, but for this one ... nah, no realy I've decided on the pre WWI, mebby I buy another one and do the WWI also. Although, I've got that monster on the table too
  17. You still can make a diorama with a cutaway model, why not. First get her into the cutaway shape you want, you can always fit here into a diorama ... besides, once you have her like you want, it is easier to picture her in a fitting surrounding
  18. Just to show you, I've got the same kit ... There is a paint scheme in the box included, Popeye. You'll need to convert to the enamel brand you're using Hope you can find some if not all in your stash
  19. John, I don't know about specific RAN models, but you can make quite a few based on their British counter parts, which are available. Here is a discussion on it. Greg will probably know more on the subject
  20. Hello Mark, A bit less noise whilst crunching, I'm trying to concentrate Dunno, on what, but it did sound rather nice when I first wrote it Welcome to the multiple-build Nearly forgot, Dennis. If you use acrylics, prime first. As many before me, I switched to Tamiya rattle cans, they do have a small bottle of their ptimer too, for acrylics do not adhere to well on plastic and brass ... once primed, it doesn't matter to much what you spray, or smear on the parts ... if I think about something else, I'll just post it. Cheers
