cog
Everything posted by cog
  1. Super ... Patrick, I see you are a man whom likes his curves I'm ready anxious and waiting on al those magnificent steps in this build. You always seem to pull a rabbit out of a hat at some point ... curious what you'll come up with this time ... when I look at it's size compared to shadow, you'll have your hands full with the size of your interior decorating ... I would like to see a golden tap in the bathroom if you have the time
  2. i like the photographs from ships with the unpainted PE, as well as the painted. However the unpainted versions do have an unpainted ship as well. I wouldn't know if the remainder of the ship being painted wouldn't make it look strange with the bare PE ... Looking forward to your plastic en PE journey
  3. Paint: check ... Well that's quickly done Move it along Scott ... see you when you get there
  4. Yessssssssssssssssssssss!!!!!!!!!!!!!!!!!!!!! That's more like it ... Add a Nieuport to it, and you are complete
  5. Naturally, and it swivels too ... it's a 1 € cent in the backgroud, isn't it! Goodness ... it's small
  6. Looks rather grand ... although i would let the Dr 1 should fly too. Prop looks good! It suddenly struck me ... Any reason why you left the left side of both plaines uncovered, and didn't alternate?
  7. A very commendable build, Mike. I like how it turned out ... half naked you should let those two battle it out at the ceiling, you'll have some noise whilst building the next challenge
  8. I presume you didn't cast them yourself, although it wouldn't surprise me if you did. Those look a lot more sturdy than the ones bent from wire ... very nice, and crisp looking ... a real asset to your build Cheers
  9. Roger, To get it clear for my layman's "brain", by increasing the length of the rope the required power is diminished, something like the leverage one gets from a longer pole vs a short one? Cheers
  10. Emergency toilets ... Deck looks awefully good ...
  11. After this extraordinary feat, Frank, those push boat controls will be a stroll in the park ... This is truely amazing detail ... Cheers
  12. Another little gem finished. You are gathering quite a fleet! I am curious how you will tackle the next one. Any drawings found yet? or is by your minds eye ...
  13. looks verrrrry promising. maybe give the inserts a slightly less hard angle ... 45º or 35º instead of he current 90º ...
  14. French ... judas But I forgot to tell you, you are doing another wonderful job on these dual barrel turrets, Scott
  15. Love how she is taking shap Jack. Nice work on the brass fittings too
  16. Don't fret Mike. They look as if they were meant to be this way ...
  17. Remeber @Adrieke emigrated to downunder ... he build a sternwheeler with a winding staircase ... worth a look I would say ...
  18. Keep it up, a few more to the top ... and then the other side ... you are doing marvelous
  19. Piet, Why didn't you remove part of the lower hull to make it more like a waterline model? Since you do not make the water opaque, you can still do that ... What you also can do, make a filler from some (foam?) board to increase the contents, cut out the shape of the hull as to fit the Java in the position you want her ... less polymer to poor in ...
