Everything posted by BANYAN
HMCSS Victoria 1855 by BANYAN - 1:72
BANYAN replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Very many thanks E&T. Thanks for looking in and the compliments; as this is a club build (5 builders) I will pass them onto the respective builders of those parts; I can only claim a small contribution to the hull and the doing the channels though. regards Pat- 993 replies
- gun dispatch vessel
- victoria
Thanks Russ, yes she was a truly beautiful vessel with a 'royal yacht' fit-out internally and cutting-edge (for then) equipment - at one point, Lang and the build over-seer [Lockyer], bemoaned the fact they could not get even more ventilation into the crew spaces . Lang, who designed her on the proviso he had a free-hand did the design for no cost to the Government. I think he was trying to prove a point to the Admiralty at the time of how to achieve the most efficient hull form for a vessel of this type. Although like the Arrow/Vigilance class, she had a slimmer profile for speed, and shallower draft to allow her to work in shallow waters but maintained great blue-water sea-keeping performance.- 993 replies
- victoria
Thanks for all the likes and comments folks, much appreciated: - thanks Albert - Mark, a bit of a pity but this is the second ship we have done in the Colonial Navy series which is being displayed in the HMAS Castlemaine Museum ship. They are both the same scale, and the other was painted so to be consistent ... cheers Pat- 993 replies
- victoria
There is a drawing in Marquardt for the D-Block. While it is for the lifts etc, reimposing it onto the hull for the anchor would probably work. It is a simple line drawing which, I am sure if you cite the original there would not be a problem? I know Karl Marquardt quite well and I am happy to ask him for permission to use it on your behalf if you would like? regards Pat
That's a nice looking result on the rudder Ulises and an interesting technique. cheers Pat
- 786 replies
- Royal Louis
- Finished
Hi Pete, Marquardt shows one on page 250 of his "18th century rigs and rigging - not sure if this would be the same though. He describes it as "D-blocks were lumps of oak, formed in the shape of the letter D, from 12 to 16 inches long and 8 to 10 inches wide(see figure 184j). They had a sheave fitted and were bolted to the ship's sides in the channels, to take the lifts etc. The D-block was English and came into use at the end of the century, mainly in men-of-war." This does not tie in with your period but could they have been similar in concept but positioned at the bow? cheers Pat [Edit - Falconer gives the same description; Goodwin does not mention them at all.]
Keith, I think the easy answer to your question would be replacement/upgrade parts for all those cheap (mostly very poor quality) white-metal / britannia metal parts you find in kits including decorations, cannon, figureheads, etc. If these are done with more care for the detail there may be a market especially if packaged as 'detail up packages" for various ship kits (*much as the PE you find for some ships and many plastic aircraft models). I have just had a whole ship done (at 1:350) and the level of detail that can be achieved using the right printing medium is incredible. cheers Pat
Thanks Denis, Dave and Per - much appreciate you all looking in and leaving a comment. Thanks also for the many likes. I haven't tried to fix the scratch yet but will try the car polishing compound. Denis - nail polish? more clues please I am intrigued
- 517 replies
- Endeavour
- Artesania Latina
Thanks for looking in, the likes and comments folks; I am very happy to see the interest in this vessel. cheers Pat- 993 replies
- victoria
Thanks Greg and UTS; and for all the likes. Greg, I am preparing the space for the next one cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
Thanks Druxey; it has proven a great method to date. the real test will come when it is time to open the ports etc We did think of using false risers as well but this proved a little easier according to the gent who did this part of the build. cheers Pat- 993 replies
- victoria
and I thought my rigging project was complicated - nice job Dave! cheers Pat
- 962 replies
- sovereign of the seas
- ship of the line
The current level of completion has seen the figurehead and channels added. The decorations have been largely completed and the figurehead was built up and refined by club member Geoff Martin (who also designed and built the bulwarks jig, and completed most of the hull construction) - this figurehead is only just over 18 mm total. Another member (Geoff Peters completed the copper plates and I have added the channels and about to embark on adding the remain deck and hull fittings. I have also opened the holes for the Tube Scuttles which were a combination airing port and light port designed by Oliver Lang. This brings us up to date with her current status. cheers Pat- 993 replies
- victoria
The bullwarks, roughtree timbers etc at this scale are very thin, and also as this ship was constructed without full frames (no projected timbers), we needed to develop a jig which is shown in the photos below. The jig screwed to the deck (in locations that will be covered later) and expands outwards. The bulwarks were then built up against this jig which supported them during construction. The jig will be fitted again soon to allow us to cut out the various ports and access gates. We decided to experiment with the deck as the scale size of the 6 inch wide deck planks would have proved to be a nightmare in planking. The deck arrangements were drawn up in CAD and then printed on timber veneer which was then glued down to a false deck. This has proven to be a reasonable approach for this model (cost and time); although, we have yet to deal with the glue joint . cheers Pat- 993 replies
- victoria
As mentioned in the earlier posts, we have been moving ahead with the build and the hull has been completed, including the copper plating. The screw Built by Chris Ramsey) to the Maudslay design, does rotate but we did not bother with the feathering at this scale. This design of the feathering screw did not require the whole screw to be raised, but was rather locked in the feathered position when under sail. cheers Pat- 993 replies
- victoria
Thanks for looking in and comments Keith and Greg. Keith - more like 13 (most while I was still working) Greg: see http://modelshipworld.com/index.php/topic/14596-hmcss-victoria-1855-172-by-banyan/#entry453812 cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
Research I do not intend to post copies online of the plans I have developed of this ship as there are some unscrupulous people out there whom turn them around for their own profits (as has been evidenced recently). However, I will provide a background discussion on the research effort that has gone into this ship. I think I have tracked down almost all known drawings, lithographs, plans, photos etc of HMCSS Victoria and it is a great pity the Government, Navy or other Australian authority have not kept any significant records etc. It is almost like they washed their hands of the Victorian Colonial Navy L The above image is an out of copyright lithograph of a painting of the Victoria by J Taylor c1860. The image was obtained from (held by) the State Library of Victoria Identifier: H6503 There is only one painting that I am aware of that I do not have a copy of. I have managed to purchase copies of all known photographs, wood cut etching (London Illustrated News) and lithographs etc. The owner of the only known surviving/existing plan of the ship, a single sheet drawn by Oliver W Lang (ships designer) which includes the side profile, sheer and waterlines. There is also a separate drawing of the ship's boilers, both of which have been kindly provided by the owner to let us take a copy in return for permanently displaying the model in his Museum (HMAS Castlemaine) when it is completed. The only other known set of plans have disappeared from the Victorian Records Office (and no, the set discussed earlier are not those). I have also assembled every newspaper article, journal articles, magazine articles I can find, including a copy of the Geoffrey Ingleton collection of related documents. The services of a researcher in the UK were also engaged, whom has tracked down and provided copies of a lot of the correspondence between the various parties, authorities and family members etc (including Lang, the ship's agent, ship-build overseer (Commander Lockyer, RN), the Colonial Office and the Victorian Parliamentary Records office). The rest of the supporting information has been derived from searching through contemporary articles, journals, records, reports, publications etc to get the details of the listed equipment and fittings stated in the Contract. I have also had some very useful help from a historian and author whom has done a lot of research on the history of the ship, but not the ship itself. See: http://users.vic.chariot.net.au/~ianmac/vicship.htm All of the information collected will be donated to interested not-for-profit parties on completion, probably either the Australian War Memorial or Navy Heritage Centre, but as the Naval heritage/history people do not seem to rate this ship it will probably be the earlier.- 993 replies
- victoria
Background HMCSS Victoria was the first major defence vessel ordered and built by the Victorian Government, with her order placed in 1854. The ship was ordered to provide defence for the Colony during the ‘gold rush’ era as there was a perceived threat and fear that the riches of the Colony may prove very inviting to foreign interests; especially Russia. The ship was designed by Oliver William Lang, naval architect and then the master-shipwright of Pembroke Dockyard, as a one-off design. He designed the ship for no cost to Victoria on the proviso that he be given a free-hand in her design. The ship was built by Young, Son and Magnay at Limehouse Docks, on the Thames in London in six months in the latter part of 1855. HMCSS Victoria was delivered in January 1856 and arrived in Victoria 31 May 1856. The ship had classic lines and was often remarked in the Press and by the public as a beautiful ship. She was fitted out lavishly in mahogany with fittings the equivalent of a luxury yacht. The main engines, boilers and marine engineering equipment were built by George Rennie and Co. at the adjacent Blackfriars Engineering; and, the innovative feathering screw designed and supplied by Maudsley. According to her Build Certificate (27 July 1855) she is described as: ‘…round stern, carvel built steam-vessel 'Victoria' – that the said vessel has a half woman figure head, is flush decked and has a lower deck before and abaft the engine room , with platforms below the same – that the length from the fore-part of the stern aloft to the after part of the stern post is one hundred and sixty six feet – the broadest part above or below the main-wales is twenty seven feet, the depth of the engine room from the upper side of the floor to the upper side of the beam is fourteen feet nine inches; and the burthen is five hundred and eighty tons (OM).’ For further background on this ship, see the following site: http://www.cerberus.com.au/hmcs_victoria.html The following link provides a summary of the life of her Captain, William Henry NORMAN, who commanded her throughout her service life. http://www.cerberus.com.au/muster_dadabik/index.php?table_name=crew&function=details&where_field=ID&where_value=90- 993 replies
- victoria
Hi folks, the new project. I am not the sole builder of this model which is a club project for the Ship Modelling Society of Victoria. I am coordinating the build, doing the research, drawing the plans and assisting in the build process. I am providing this log as she is an interesting ship and I thought members may be interested. While designed as a warship along the lines of the contemporary Arrow and Vigilant Classes of Gun Dispatch vessels, she was operated in various roles, with only a very short period of active duty as a commissioned ship during the Maori Wars in New Zealand. Her Majesty’s Colonial Screw Sloop (HMCSS) Victoria was built for the defence of the Colony of Victoria during the gold rush era. The above image is a copy of a purchased image from The Illustrated London News which shows her during her Builders Trials. Additionally, as much of the hull construction has already been completed, I will provide a summary of this part of the build only.
- 993 replies
- victoria
Nice work Elijah, she is looking great. I like the slipway you have mounted he on. cheers Pat
- 701 replies
- phantom
- model shipways
Thanks for looking in and congratulatory comments Russ, BE and John. Russ - thanks, it was your early support in ther battle station build that got me into 'bashing' the kit so much. BE - thanks for your help with the pennants also mate. John - I really appreciate your assistance in the detail photos of the replica rigging you took for me . ...and, yep, I would much rather scratch the case cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
