Everything posted by BANYAN
Glad it's you and not me trying this at such a micro scale Piet. Did you try gluing up on wax (grease paper for cooking) as it won't stick to that I think. I do my gluing up on a glass plate, again for easy removal. cheers Pat
Great detail Greg. Boy are you moving along, I getting dizzy just following cheers Pat
- 342 replies
- dreadnought
- zvezda
Thanks Chris, yep it is 61; interesting they also bring it down. Unfortunately for my rigging plan, I have been following the AOTS whom utilise these shroud cleats in a different sequence and it is already taken up. More to ponder. Appreciate your input, very useful. cheers Pat
You like to set yourself a challenge don't you Piet? That base is looking great, pity about the glass though. cheers Pat
The current netting looks great for scale Sjors, and Anja has done a great job fitting it. If the black does not work out, and you cannot live with the white, you could try to dye the white a darker colour (deep tan) in-situ with a paint brush loaded with the dye? Careful application should result in a neat finish and as the rails/stanchions are black you run minimal risk of discolouration of other parts. Just a thought. cheers Pat
- 1,616 replies
- caldercraft
- agamemnon
A Lorch Micro-Mill that never was ...
BANYAN replied to wefalck's topic in Modeling tools and Workshop Equipment
Another tantalising update Eberhardt - I have stocked up on the tissues so ready for the main installments That knurling tool does a great job. cheers Pat -
Thanks Mark and Frankie; much appreciate your responses. I have rechecked the AOTS (by Marquardt also) and again all that is said is "belays at Top" - so I think I will go with that - saves me a bit of rigging also . Frankie, that is a good solution; I will see if I can achieve that as it is a bit fiddle to reach in there but I should be able to do it. Many thanks again Pat
Thanks again to all the likes and comments; the encouragement sure helps with big decisions like this. Popeye, I won't tell anyone about the sheet lines if you don't . Thanks for the comment re the finish, but the photos hide some of it - they really do need a "cut and polish"; especially close to the iron work as evidenced in photo 4. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
Great job on the Catheads mate. Where did you get the crowns? I have not been able to find anything of the right scale size yet. cheers Pat
I have fitted the reefing tackles to the foremast topsail yard, but am having difficulty determining how the running part (hauling part) of the tackle is belayed for HM Bark Endeavour as of 1768/1770. According to the AOTS, there is a simple statement (callout number with comment) that it is belayed at the associated Top. The running rigging belay plan does not show the belay point. Earlier diagrams for the Top indicate two eyebolts in the after part of the Top (located just aft of the lubbershole) on either side of the mast. However, from what I can determine these are for the Topgallant Tye tackle? Can anyone point me in the right direction please. Peterson is too early to use as a reference and I cannot find anything in Lees (yet). cheers Pat
Bravo Gaetan; simply stunning work. cheers Pat
- 728 replies
- le fleuron
- 64 gun
Nice work Greg, all that detail will really enhance the build. cheers Pat
- 342 replies
- dreadnought
- zvezda
Nice work Piet, a very clean cut indeed. ....and great to see you wearing the safety glove cheers Pat
Great work as usual Glenn, I had to look closely at a couple of the photos as you could believe you were looking at the actual paddle-steamer. cheers Pat
Great detail and excellent control of the scroll saw to achieve it Gaetan. cheers Pat
- 728 replies
- le fleuron
- 64 gun
Looking good Greg, that wooden deck really brings her to life. Hope you don't have to do too much more corrective action with the CA. cheers Pat
- 342 replies
- dreadnought
- zvezda
Thanks for looking in and the comments folks; much appreciated. Yep Mark, first wood ship model apart from the battle station I built along the way as practice There are heaps of little errors from the days I first started but these I can live with. cheers pat
- 517 replies
- Endeavour
- Artesania Latina
Nice jig Mark, very effective. With such light passes i don't think you will have to worry about wear on the sanding drum causing spacing issues. cheers Pat
Part 2 - sorry some of the photos are not that well focused in the earlier post. In the following you can see the new solder joints, and the finished results for the port side also. Unfortunately it was impossible to get any shots of the actual soldering operations. Photo 4 (first in this post) shows the third-hand setup which was raised by using solid wood blocks, photo 4 shows the new soldered joints (mid-yard and end-cap are visible (before cleanup and repaint) and photo 5 shows the port side boom completed. cheers Pat
- 517 replies
- Endeavour
- Artesania Latina
