BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Hi Boris; I am also building the AL. My two cents worth: 1. The hull is accurately proportioned and is double planked as per your preference. 2. The brass decorations are a mixed bag. The quarter badges and some scroll/figures are OK but the transom piece and window column scrolls are poor 3. Plans are OK for what they are but the rigging is not accurate for the period or practice (use James Lees and Steel to supplement). I replaced all the rigging materials 4. Instructions are poor but as you are an experienced builder I think you would be OK with them. 5. I scratch built all the upperdeck fittings and equipment using the AOTS (Marquardt), Ray Parkin's book and the replica build as source information. Hope that helps you? cheers Pat
  2. Interesting reading; thanks Stephen cheers Pat
  3. Great idea Danny, you see some exquisite models in museums and often ponder about the internals; a neat way to show this. I know you have just started but any ideas of a full made up mast (no rigging) as a separate item also? cheers Pat
  4. Ron, there are a couple of free graph paper apps on line (just Google) that allow you to specify spacing (Major and minor units) and set the associated line weights. I can't recal the one I used at the moment but should be easily found. I simple printed off a couple of A4 sheets then uses these as my background template by using hair clips to temp pin the m to the shrouds. You can see what I mean towards the latter posts in my log. http://modelshipworld.com/index.php/topic/400-hmb-endeavour-by-banyan-al-160-circa-1768/page-12 cheers Pat
  5. Hi Ron, I went with 13" actual spacing. Not sure of your scale, but you should be able to sort that - my simple formula is 13 x 25.4 = about 330mm (330.2 actually) then divide by the scale; in my case 1:60 which results in a 5.5mm spacing. 10mm seems to be a bit large unless you are building at a much different scale? cheers Pat
  6. Hi Andrew and a belated welcome to the Endeavour (and in particular the AL kit) builders club Your build is coming along very nicely and I see you avoided my mistake of having the hawse holes misaligned with the deck - nice catch. For my build, I basically ignored everything AL provided once I completed the side planking. What are your plans? cheers Pat
  7. Your Titanic is looking very good; some nice detail there Popeye. You're going to have to speak to the boss and let him/her know that the MSW forum believes you should be full-time on the model - PR for them so to speak cheers Pat
  8. No probs Dave, glad to hear it worked out well. I have left the swivels, anchors etc for the very last fit - as Greg stated, too easy to snag get in the way of the rigging. I am also leaving the jib boom for as long as I can for the same reasons. One of the last things I will fit are the delicate items such as the deadlights, quarter window shutters etc. cheers Pat
  9. Looking very good there Steve, nice crisp detail! cheers Pat
  10. I wasn't aware of this build Popeye, but so glad I found it. That's a great build, I'll settle back for the rest of the show cheers Pat
  11. I wonder, if it materialises, whether they may attempt to challenge the fastest time she set for various trips ? cheers Pat
  12. That is a neat way to do the boat Mark. I especially like the base (top?) piece you have made with the securing points. Rather than carving out the interior, I thought this was a 'plug' and you would build the boat hull around it? In the next boat (or version if needed), you could draw and cut the slots where required on each slice and then connect by carving the rest of the slot for the frames? Sorry not trying to make extra work for you cheers Pat
  13. She is coming along very nicely Dave, nice work. Thin CA before painting should do the trick - medium/thick especially may not penetrate especially after painting which may seal the card? cheers Pat
  14. She is looking mighty grand and very fine there Greg! The detail at scale is impressive and I understand the difficulties, as I am working on HMAS Vampire at the same scale (Frustrating at times eh?) cheers Pat
  15. Thanks Popeye, Mike, Brian and Mark for looking in - appreciate the interest. Having fun with the rattlin Mike a tad tedious huh? cheers Pat
  16. HI Wefalck, I had forgotten this build and only had a chance to revisit today - I started liking most posts then thought that may be irritating - sorry. All I can say is that I am very impressed with your machining abilities and capacity to think up alternate mechanisms. I look forward to the next instalment. cheers Pat
  17. That's a 'bottler' Dan - or should I say a 'corker' (sorry mate couldn't help myself) cheers (and now back to my day job) Pat
  18. Hi Byron, no problems taking questions mate, that is what these logs are all about My kit was the Artesena Latina (AL) but probably not that much different wrt their content. I stopped using all AL parts and accessories about 2/3s way through the hull build, so all my rigging and deck furniture etc is either scratch or after market. My rigging is a combo of Morope (tan) and home made (black). I had already purchased the Morope before acquiring my rope walk so I was compelled to use it or waste my money - easy choice Essentially, I used the rigging calculator (spreadsheet) developed by members JimLad and DanVad which is available on this site. I simply rounded up and down the calculated sizes and simplified the range to 4 tan and 5 black sizes, and applied the general rule of diminishing rope size the higher in the rigging. So while not absolutely scale correct, it should be close. As to references, I have not bothered with the AL instructions at all. I have basically used the AOTS book Capt. Cookes Endeavour by Karl Marquardt as my primary guide, but where there have been obvious or contentious issues I have also used the Replica, Ray Parkin and the feedback of some of our members to steer me. James Lees (The Masting and Rigging of English Warships) has also been very useful. In a nutshell, there will be difference to other builds; this is simply my interpretation. FYI - Ray Parkin and Karl Marquardt were members of our club and there were some interesting debates about the differences in ship construction/fittings and rigging Yes, there are differences between these authors interpretations, and with the NMM plans, the replica rigging etc - although the vast majority of the rigging is generally the agreed. Have a peek at MSW members Greg Lester Mike C and Shipaholic build logs to read of some of the issues that have arisen. cheers Pat
  19. Hi folks, this sounds fairly promising although not confirmed yet. Henry V 'great ship' Holigost believed to be found in River Hamble in southern England http://www.abc.net.au/news/2015-10-13/one-of-henry-v-great-ships-holigost-likely-found-in-england/6848774 and http://www.independent.co.uk/news/science/archaeology/the-holy-ghost-historian-pinpoints-final-resting-place-of-one-of-medieval-englands-greatest-ships-a6689901.html cheers Pat
  20. Good luck Dan, as that add said Bugger! Just when things were going so well - one of Sod's laws isn't it. Look forward to your solution. Will you simply cut off neat just above the eye/loop and put a cap on? cheers Pat
  21. Thanks Greg, appreciate you looking in; and the many others for their likes. cheers Pat
  22. Hi folks, another update to the HMCSS Victoria - and yep - another question? We are progressing quite well as can be seen from the photos with the bulwarks now added and some decorations applied. We are using some experimental techniques with this build as it is a club project where we can all learn so what better subject. The photos show the deck (printed wood veneer), which turned out great. The bulwarks are fitted with all ports scribed (not opened) and these were son delicate we had to make a special jig to support them while they were fitted (and be reused if we open any of the ports). The jig has a base with two sliding outriggers which have the pattern (negative) of the roughtree timbers etc spaced as needed. The jig is screwed to the deck in places where the holes will later be covered and the outriggers extended to the edge of the hull to support the bulwarks etc. the photo shows the jig only partially inserted to provide a hinty of how it was fitted; I will post another when fully fitted when/if we do open any ports The yellow and black stuff is tape to stop the glue holding in these areas. Once the bulwark had been glued in place, the outriggers were slid inboard and the jig removed. At a scale of 1:72, the decorations were just too fine to carve. Our talented member hit on the idea of scribing the pattern into the wood, then applying appropriately sized thread that had been soaked in PVA, pushing it into the scribed pattern to form the decorative pattern. When the glue dried, it held the thread in place and stiffened it sufficiently to make it look presentable. With some cleaning up and some further hull furniture still to do, the whole lot will be painted black (Victoria did not have gilding or highlight colours according to the Contract and log book evidence). The Question: All the photos we have are of Victoria in harbour with the guns run out and poking through their ports. We are trying to determine whether the guns would have been run-in and the gun port lids closed when at sea? In support of having them run-in: 1. There was no threat of war or immediate action in this area/era 2. The ventilation skylight hatches were open (midships around the funnel) which only had iron gratings. Closing the ports would have reduced any shipped water. Against that though, a couple of watercolour lithographs based on etchings, show her with ports open. What do you think folks? cheers Pat
