Posts posted by Gregory
Here is an image I found.
- thibaultron, mtaylor and Canute
3
On 6/12/2021 at 4:11 PM, Chuck said:
One is made entirely of Boxwood while the other is made almost entirely of Yellow cedar.
While I am well aware of the qualitiies of boxwood, the cedar has more of a glow.
I look forward to seeing how it ages..
I wouldn't want to wait 200 years for the boxwood to take on the amber look that looks so well.😁
- Chuck, FrankWouts, Ryland Craze and 2 others
5
I get the cutting blades from Malco. On my last orders a few months ago, they have required $100 minimum order.
I don't see any thing in the 200 tooth range. I know I have made super fine cuts with teeth in the ~100 range.
Byrnes also sells blades Not sure about the arbors, but they also sell arbor adaptors..
For the gratings look for a thickness that suits your job.
Have you tried changing the file extension to .STP and see if Tinker can see it?
You might consider installing the free version of Fusion 360, import the STEP files, then export them in a format TinkerCAD can use..
Meanwhile you might want to up your game by playing around with Fusion360..
While you are here..
Have you heard of Meshcam ?
While it targets CNC users, it is a very powerful tool for refining STL files..
It is not free, but some might find it a worthwhile investment.
Here is a demo video of what it can do..
Do you mean Blender ?
Blender seems to be more about 3D animation rather than creating objects for 3D printing.
Fusion 360 might be more of a go-to for parts creation.
It's free for hobbyists.
I'm revisiting this in response to the original post.
On 3/2/2021 at 2:26 PM, Tomculb said:What methods and dyes have people successfully used to get the color they want?
There was a discussion about staining/dyeing boxwood where it was agreed boxwood doesn't take some stains very well. One or more people mentioned dyeing with an alcohol based stain.
I proceeded to get some Fiebling's dark brown shoe dye to experiment. It actually worked pretty good to make my boxwood blocks darker.
I had thought, and mentioned above, that I didn't think synthetic/polyester would take dye very well, with the idea that it was like trying to dye plastic and wouldn't stick.
Well, I was wrong.
On a whim, I dyed some of my home made polyester rope with the above mentioned dye and it really worked pretty good.
Top is before, bottom is same rope dyed. ( Please ignore the unravelling.. That happened before I baked my rope.. )
Getting the color you want could take a lot of experimenting, and have a lot to do with the color you start with.
For home rope makers, I see it as a way to avoid getting different colored thread for standing and running rigging..
Find a good light color you like for running rigging, then dye it dark for the standing..
Note: The dye can be very messy, but it cleans up pretty easily with alcohol, depending on how long it sits before you get to it..
7 hours ago, DaveBaxt said:
That sounds like a good way to do this but could be a little tricky as I have already fitted sections for strengthening
When I described extra bulkheads, they don't have to extend to the backbone like the original framing.
All you are looking to do is fill out the outer profile to provide a surface for planking. Just add what amounts to shims
to the edges of the existing bulkheads. Create as many layers as you feel necessary. It is a lot like adding blocks, but laminated so
you can reduce the amount of shaping needed.
On 6/6/2021 at 12:04 PM, glbarlow said:
Normally I replace kit rope with Syren products but that is no longer an option and I have little interest in making my own.
I'm going to toss this out here..
I can make what I feel is very acceptable model rope.. However, I do not think I want to go into the model rope making business..
If someone has a particular project, with details in color and size, I would enjoy working with them to provide the rope they need.
The cost would basically be postage and materials. I do not have the space to create 20 foot lengths like Syren used to do.
It would be more in the 4 to 5 foot range.
Of course, I could provide as many 5 foot pieces as someone might think they need.
I never made anything for my own use that was more than a couple of feet. No one line in a project was ever longer than that.
Send me a message if you would like to discuss this or get a sample..
- Ryland Craze, KentM and mtaylor
3
The gun ports outside the forecastle and the quarterdeck are on the weather deck. Port lids would serve no purpose..
11 hours ago, druxey said:
If you absolutely want to pounce at scale, use watch gears.
Like these:
Dying/coloring rope; sources for purchase of quality rope
in Masting, rigging and sails
How much time?
Isn't just bout any material going to change with humidity if it is not sealed in some way?
