Posts posted by Gregory
FWIW, I like the AYC ...
- FrankWouts and Rustyj
- 2
I apologize. Just realized my link to Tower Hobby shows back-ordered..
How about this:
It could be refined a little bit, but this was about a 10 minute effort with my Proxxon FET, a little filing and sanding.
- GrandpaPhil, BobG, mtaylor and 1 other
- 4
On 8/19/2020 at 8:16 PM, Sheerline said:
Would it be better to buy sheet and spile them or would that make them look a bit wide compared to the rest?
Very nice work so far!
Spiling might be something to consider at this point if you feel up to it..
Have you looked at Chuck's bending techniques?
For the stern just a small increase in width at the stern post for most of the planks is hardly noticeable, as seen here for Chuck's Cheerful. It would only require slightly wider strips, tapered from the stern forward to midship.
For the bow, you might consider a drop plank. There is only one on Cheerful.
Whatever you decide, it will be good experience for you.
46 minutes ago, Edwardkenway said:
Unfortunately I don't have a Byrnes saw, but will be using a Proxxon fe
Edward,
I recently replaced my old microlux with an FET.
I'm still getting familiar with it, but all of Glenn's tips work as well with the FET.
I haven't determined if there is increased clearance at the rear of the fence, but it should be easy to make that happen.
The micrometer-like fence adjustment on the FET is very precise and allows for making fractional mm adjustments.
Hopefully you will be able to get a fine tooth .030 or 0.20 kerf blade for plank ripping. The included carbide blade is good, but wasteful..
- mtaylor, Ryland Craze, Edwardkenway and 1 other
- 4
Looking at their instructions I linked to above, it doesn't look like a kit I am familiar with..
It may be a re-packaged Constructo kit.
It's definitely their own plans.
It looks like the 1927 configration.. The actual plans for the 1927 restoration are available.
3/32 = 2.38125mm
I get ~2mm for 8 inches.. 2.5mm = ~9.6 inches.
40 minutes ago, glbarlow said:
The Thurston I-292, .030 kerf slitter blade. I understand Thurston is out of business, I’m sure there are equivalents if you can’t find one.
FWIW, I've used the .020 and .030 from Malco with very good results..
The pricing is competitive but they currently have a $100 minimum order..
- Chuck Seiler, mtaylor, Canute and 1 other
- 4
While I agree with Jim Lad, I think a model without sails looks good with just braces and lifts..
It's a matter of personal taste regarding how you want to present your model.
For you, it could be a snap shot of the ship in dry dock before all the rigging was taken down..
You can see the Model Space instructions here: Instructions
It looks like an original kit based on the present configuration..
How did you feel about the cost at the time? How does it compare to BlueJacket's pricing today?
- Canute, mtaylor, Keith Black and 1 other
- 4
28 minutes ago, Liam said:
the plans show a 1 mm wire to be used with no loops of overhang
That 1mm wire represents part of the carriage structure..
It doesn't look like the kit provides the various eyebolts and hooks that would be part of the gun tackle..
You would have to procure those from other sources..
Here are some carriages from DocBlake's Blandford.
There are tables somewhere that would indicate diameter/circumference or whatever. but in modeling I go with what looks good.
Here is an example from Victory.
Out of proportion rope and tackle would be distracting..
I think the breeching rope on the cannon in my signature looks too small.
I would change it, but the model is no longer in my custody..
The 1/4 poplar boards you can get at Home Depot are pretty decent..
Good to hear you got a saw..
One of the small one's? Byrnes or other?
- mtaylor and thibaultron
- 2
I have been happy with the cherry from ModelExpo ..
They have some 1/4 square..
Of course, if you get a saw, cutting from sheets will be a better value..
- mtaylor, thibaultron and VTHokiEE
- 3
FWIW, I have found this adapter to work with the 1/2" arbor on Malco blades and the Proxxon FET
Malco has $100 min order requirement, but their 3 " .02 blade for $15.43 is a lot better blade than the Proxxon branded blades..
Two questions... Mast and rigging related.
in Masting, rigging and sails
I believe it's common to do as much as possible off the boat ..
Of course, shrouds and stays will be done on the boat, having attached as much related hardware, blocks, eyebolts etc. before mounting the masts.
Most of the rigging for the yards can be done off the boat..
There are many good examples in the build logs.
