Everything posted by yvesvidal
ancre Belle Poule 1765 by j.guydal
yvesvidal replied to j.guydal's topic in - Build logs for subjects built 1751 - 1800
Superbe travail. C'est du grand art !!! Yves -
Great project. I feel your pain with the printing time..... 614 hours to print my Russian ALFA submarine !!! Patience and a clean extrusion are key. Yves
- 6 replies
- swedish navy
- Destroyer
The next step of the stand was realizing the ramps and structures that will support (safely and reliably) this massive model. The crucial part was handling the hull and positioning it in such a way that I could measure and build the six vertical supports that are preventing the model from tilting and rolling on its sides. The ramps are slightly inclined but not enough for the model to slide back. I also wanted to create something that would allow the full display of the copper clad hull, in all its beauty. Below, you can see how the model is stabilized using 1/4 inch poplar dowels with some felt to protect the copper. Moving, installing, removing ...... the massive hull was a challenge and a good workout at the same time. Most of the weight of the model rests on the central ramp which is very solid and stable. The rear part of the ramp is equipped with a small piece of wood to prevent any desire of sliding the model may have, and is cut so that the rudder can be manipulated fully by curious hands: Once inserted, the standing structure fits perfectly into the box. Here are the steps: I am sure you may be impatient to see how the model fits on this display stand. I know I was.... Et voila. Lots remains to be done and now that I have some confidence in the display, I can go back to the hull and finish all the missing details. Thank you for your interest. Yves
As indicated before in my response to Kevin, I have been working on multiple fronts: Making a bowsprit and its associated rigging. This is not part of the CAF model kit, but I wanted to present a little bit more than the traditional Admiralty Model approach and wanted to play with some lines and ropes. I have quickly came to the conclusion that I suck at rigging and my utter admiration goes to these magnificent models depicted with their full rigging. The second front has been building a stand to display this large (and very heavy...) model. I needed to do that before finishing all the details of the hull and in particular the gun port lids, which are very fragile when manipulating a massive hull of more than 22 pounds heavy. In addition, the bowsprit was necessary to calculate the dimensions of the stand. For the stand, I decided to copy somewhat, the display presenting the 1/32th - 1/36th scale model from the Royal Museum in Greenwich, UK. The display of the original model is composed of a drawer that can be pulled from the rear and which extends the ramps, and allows the sliding of the massive model for inspection. Exactly the way it should be done to convince a set of tight-fist admirals and finance comptrollers in ancient British times. My stand will not be so sophisticated but I wanted to replicate the shipyard ramps used to assemble and build these magnificent vessels. After measuring the "beast", I ended up with some inside dimensions of 60" by 16". A friend helped me cut the wooden parts (poplar and plywood for the most part) and I started assembling and painting the display stand: Priming that large box required a few cans of Primer and a lot of sanding. Each corner will see some modern handles (this stand has no pretensions to mimic the old cabinet or museum stands) installed to help with the handling of that large display. The bottom of the box is covered with a piece of dark blue velvet fabric. An edge has been created to support an acrylic cover if I ever get a chance to buy one custom made. Yves
Vincent Black Shadow by CDW - Revell - 1:12 Scale
yvesvidal replied to CDW's topic in Non-ship/categorised builds
So Craig, are you postponing the building of the Pocher Alfa Romeo, in favor of the Revell kit? Yves -
Thank you Kevin. Things are not moving very well.... I am struggling to build a very simple stand to display the ship. I need to do that before finalizing all the hull details. Yves
Curtiss BF 2C-1 by CDW - FINISHED - Hasegawa - 1:32 scale
Did you use the Camel Yellow from Tamiya or something else? Yves -
I agree completely with Craig. The planes developed during that time period were very interesting and full of good and crazy ideas. I would call it the Golden age of aviation around the world, and it is regrettable that so few kits be made available, especially in large scales. And yes, these yellow painted planes and the big Seversky belly planes are just wonderful to assemble and look at. Yves -
Interesting Build log for sure. I like the choices you made and your approach: Fun must dominate the build, otherwise, it is just punishments. Yves
- 154 replies
- Enterprise
- Trumpeter
Amazing !!! And what a great and unusual presentation. Yves
- 200 replies
- Transport No. 103
- Hasegawa
(and 4 more)
Barncave Shipyard by mbp521 - Scale 1:1
yvesvidal replied to mbp521's topic in Non-ship/categorised builds
You should hire a couple of Mud specialists (usually from Mexican descent) to finish your drywalls. They are experts with the mud and will finish everything in less than a day. Then you can paint and seal all this dust and fibers. Yves
