Everything posted by dvm27
This is a master class in uncommon block building!
- 589 replies
- le gros ventre
- cargo
Beautiful work Ben. Must be fun to go back and forth between the two ships. Do you have plans to rig either/both?
- 889 replies
I also use one continuous sheet of 180 grit paper vs. two individual sheets. I find that with two sheets I can get a line when passing through the center. OF course that's only a problem when the piece to be thicknessed is wider than half of the carrier.
- 1,085 replies
I would do a rough sanding of the bevels before installing but would wait until they are glued in place before final fairing. There are many variations that may cause errors in precisely mounting frames and, if beveled to their final lines, these are impossible to correct once in place without affecting the shape of the hull.
Obviously the major advantage to the sled is that you can thickness wood to incredibly thin widths. I use plexiglass for dimensional stability
- 1,085 replies
Good luck with this amazing model. I am following the Midwest Modelers You Tube build of her and am agog at the number of after market options available for her.
Nice job on those sheer planks Kevin. I think you will find that shaping and installing the planksheers, especially those short pieces over the hancing pieces, will be one of the more challenging tasks on the model. To that end it is imperative that the sheer/toptimber line be perfectly fair. Consider if you will be shaping the timberheads in situ or off the model. Shaping them in place is extremely difficult so if you decide to make them off the model I would cut the timberheads off now and use a sanding stick athwartships to fair the toptimber line (it looks a bit wavy to my eye). I found that making the timberheads on the Byrnes saw assembly line style was easy and the results were very consistent.
- 1,085 replies
Lovely work Chuck. Seems like those frames take forever but you can turn out 2-3 a day once you get in the groove. Obviously more labor intensive than a POB model but for those who wish to make a POF model Chuck's methods are about as foolproof as it gets. Getting a perfect line of sweep and port sills has always proved difficult for me but Chuck seems to have solved this problem. For the inside of the frames some may wish to invest in an oscillating spindle sander. It makes quick work of these difficult curves.
Photocopying works out if you have one foot X and Y axis's printed on the part to be copied. Most copy stores machines allow you to adjust the X and Y axis's for slight adjustments and usually don't charge for the trial and error of slight adjustments. Just curious - how are you measuring the heights inside the hull for the clamps, hooks etc.? Are you using a height gauge or measuring up from the inner surface of the rising wood?
Wonderful update, Marc. Looking forward to many more this year from you. Best wishes for a happy and healthy New Year.
- 2,678 replies
- heller
- soleil royal
(and 9 more)
I had the same problem with my first POF model. Nobody will notice the thinned sections but they will notice bumps and protrusions. For final fairing use pencil marks across the hull. Sand, mark, sand etc. until all pencil marks are gone. Whatever is leftover is your perfectly faired hull. On your next model you'll be less inclined to cut exactly to the frame marks, perhaps leaving 1/16" for those inevitable frame raising errors. Happy Holidays and congratulations on an excellent first POF model.
I'd like to show you how we make snowballs in Baltimore, Kevin! Have a Happy Holiday season and looking forward to more excellent updates this year.
- 1,085 replies
Well gang, Speedwell is finished except for installing the anchors and adding coils over all the belayed ropes. It has been a seven-year collaboration with David Antscherl and I think the finished model has beautiful lines. She has just enough rigging to make it interesting without the repetition of a full ship rigged setup. Thanks to Chuck for his excellent blocks and rope which really dress up the model. All blocks for sails are included even though they are not present. Thanks to all who have commented on her build over the years and I'll be back in the fall with, hopefully, a new project.
Wonderful work Ben. The slight modification to the carvings makes a huge difference. It's the little details that matter. The carved letters are amazingly well executed. But they look out of place to me. Just a personal opinion but I prefer the flush painted letters, especially if you are painting the outer upper counter and lower counter motifs as suggested by the back cover of Volume II. Others will, I'm sure, favor the current version.
- 889 replies
Brig Le FAVORI 1806 by KORTES - 1:55
dvm27 replied to KORTES's topic in - Build logs for subjects built 1801 - 1850
You should see my junk box! Your work is stunning Kortes. Nobody gets perfect results every time but persistence pays off. -
The ships of the Cruizer class, of which Speedwell was one, were built in 1752-1754 to address the prevailing French and Austrian Wars. The Admiralty wanted fast, shallow draught ships that could carry out policing operations in the Channel and Foreland Stations and discourage French privateers and smugglers. Therefore, a variety of hull design and rig combinations was employed by the Admiralty to see which best fulfilled these requirements. Some were ketch rigged (Speedwell, Fly, Happy and Ranger) while others were snow rigged (Wolf and Cruiser). All this experimentation eventually led to a refinement wherein Cruiser was given a mizzen mast (1753) and ship rigged. This proved to be so successful that the ketch rigged sloops fell out of favor as the ship rigged sloop became prevalent. With the advent of the brig-of-war later in the century the snow rig once again gained popularity. (From Building Plank on Frame Ship Models, Ron McCarthy. Naval Institute Press)
Hole size is proportional to block size so if you're having trouble perhaps the blocks are too small or, more likely, the rope is too big. In any case for rigging one must have a set of miniature reamers such as: https://www.amazon.com/Model-Craft-PBR2194-Cutting-0-6-2-0mm/dp/B001JJZ76I/ref=asc_df_B001JJZ76I/?tag=hyprod-20&linkCode=df0&hvadid=598232118681&hvpos=&hvnetw=g&hvrand=1012005693499827230&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1018605&hvtargid=pla-422910410143&psc=1 As well, using CA on the final 1/2" of the line and pointing it after dry will allow you to get the rope started as James has stated above.
