Everything posted by dvm27
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
dvm27 replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
Beautiful, Doris. The fit and finish of the elements in the Royal quarters compares with the finest of doll houses. I wonder what would happen if you entered the model in a doll house exhibition? I bet they'd be blown away. Pass me a slice of that watermelon!- 883 replies
- royal caroline
- ship of the line
Fiebing's Leather Dye
dvm27 replied to JohnB40's topic in Painting, finishing and weathering products and techniques
The wales of this Echo class cross-sectional model are holly, blackened with Fiebings leather dye. Staining was done off the model. I used three coats, lightly sanded in between, added one coat of dilute sanding sealer and finished with a light buffing of 0000 steel wool. Treenails were added after gluing in place and touched up with more dye on a very fine paint brush. I wear disposable gloves and treat the dye like it is a potential disaster in the making...which it is if spilled or seeps into adjacent work. -
I love your wilder mane version, Ben. I have the tamer dreads on my Pegasus. David probably matched them to our personalities. Hopefully others will note the way the tail is included in both starboard and port views as was done with classical lion and equestrian figureheads.
- 889 replies
Just found your build log, Mark. She's a beauty of a ship as well as model. Love your photos and techniques.
Echo by jml1083 - 1:48 - Cross-Section
dvm27 replied to jml1083's topic in - Build logs for subjects built 1751 - 1800
Jim - the palette I used for the hull planking is boxwood, ebonized holly (Feibings leather dye) for the wales and black strake and holly below the wales. Boxwood for all framing components and holly for the deck. Bamboo treenails. Watcos Danish oil is used for the boxwood and dilute sanding sealer for the holly (does not impart a yellowish hue like Watcos). I should add that I first saw these finishes on David Antscherl's models. -
Here's an update for those of you building the Echo cross-section. We are developing a second, fitting out package with a full instruction booklet. It should be available in the next few months.Stay tuned -
Very well described, Jim. Obviously, accompanying photographs would clarify things for those whose heads are spinning. It literally takes less time to make a frame than reading the descriptive text. Especially after you've done a few. One caveat here. The chocked joints become angled as you progress towards the fore and aft hulls. Note the dashed lines in frames 4 & 5 on the plan. Otherwise the fairing process could break through the face of the chock. However, this angle is so slight on the cross-section section we have chosen it's not really an issue. The setup for doing this is exactly the same as what you have described but the mill vice is attached to an angle plate. One could calculate the angle via geometry or just eye ball it as I did. David Antscherl discusses the laying out of the angled chock in The Fully Framed Model. It's simply a matter of milling the correct angled face on both sides of the mating futtocks on one side, then reversing the direction of the angled plate to mill the chocks on the other side. -
Hmm... complementary $15 pedicure for I'm guessing $3000 of veterinary bills. Sounds like a good deal, Toni. It's an axiom among us veterinarians that if there is to be a "complication" it will always be a physician or lawyer's pet. I hope she continues to improve under you home care and remember - she's as likely to eat your new galley oven as she is her treats!
- 1,449 replies
Just to be clear that's his opinion. Personally I think your models are brilliant!
- 728 replies
- le fleuron
- 64 gun
Translation: "Superb! Gaetan, Unfortunately, the choice of wood is unfortunate.The veins are quite pronounced, which rescaled 1/1 gives a very curious aspect. This does not detract from the very good performance you are doing. Congratulations. Kind regards, Gloaguen"
- 728 replies
- le fleuron
- 64 gun
Echo by dvm27 - Cross Section
dvm27 replied to dvm27's topic in - Build logs for subjects built 1751 - 1800
Thanks, all, for the kind words. I have completed the last update and photos follow. The starboard axletree and winches are installed, along with the unusual rhodings displayed on the Annapolis Swan class model. Exterior planking to follow. As a reminder, the entire port side is left in frame to represent the Echo cross-section timbering package provided by Admiralty Models. The starboard side shows will show her fully fitted out. -
Went to look up the bio on this fascinating ship builder and I believe his middle initial is actually "L".
- 3,618 replies
- young america
- clipper
Looking great, Ben. I actually made the fore and aft sections before framing as it was easy to transfer the bottom shapes this way.
- 889 replies
WQ3296 - The has also been some conjecture that the quarterdeck is in reality a Bermuda deck, fully removable for fair weather, and that the small space may have been used for storage. One day Grant Walker, of the Naval Academy Museum, will take a look inside their model and see what lies within but's it not a priority for them.
ancre LE BONHOMME RICHARD by Jeronimo - FINISHED
dvm27 replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
They deserve to be in a real museum one day, Karl!- 662 replies
- bonhomme richard
- frigate
Perfect, Ben. Now they'll both fly off with a good swipe of the elbow .
- 889 replies
That's the way to do it, Ben. Be extra careful around them once installed. One inadvertent swipe with an elbow will snap them off (I know from experience).
- 889 replies
One certainly can't fight the Admiralty. Splendid work, Karl!- 662 replies
- bonhomme richard
- frigate
ancre Le Fleuron by cabrapente - FINISHED
dvm27 replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
Beautiful work and wood palette. Love that spacing jig for the ratlines. Is it two pieces with the center mortised out?- 332 replies
- le fleuron
- 64 gun
3D printing tests (Form1+)
dvm27 replied to iMack's topic in CAD and 3D Modelling/Drafting Plans with Software
That's pretty impressive. I imagine painting might be a tad difficult on the conjoined pieces though.
