Everything posted by dvm27
Truly awful question (thread from kits)
dvm27 replied to achuck49's topic in Masting, rigging and sails
Give that mess of thread to the ship's cat and you are guaranteed to see it emerge from the poop deck and require a trip to the ship's surgeon after a day or so! -
You, Sir, are a fine ship model maker! The mortises for the dovetail plate is perfect.
- 1,215 replies
- sloop
- kingfisher
Lovely work, Ben. What's your plan with regards to her final appearance? Windows...one planked side? Greg
- 889 replies
You are certainly a planking Master, Chuck! That's a beautiful hull.
- 1,051 replies
- cheerful
- Syren Ship Model Company
HMS Naiad 1797 by albert - FINISHED - 1/48
dvm27 replied to albert's topic in - Build logs for subjects built 1751 - 1800
Beautiful execution and wood pallette, Alberto. -
Beautiful, Ken. Makes me want to build her again. There's something about her lines that is very appealing.
- 455 replies
- fair american
- model shipways
In addition to Toni's kunckle-saving advice please check those frame/station lines as you close her in. I found that I had to rejig a few frames around the dead flat due to cumulative error. You can modifly the fillers a bit to compensate if necessary.
- 889 replies
Beautiful run of planking, Chuck. As one who is now working on the square tuck on a fully framed model I can appreciate the difficulties of following actual practice. I like your solution.
- 1,051 replies
- cheerful
I love the sanding sealer non-finish, Toni but i's just personal preference. I haven't found an oil finish that doesn't yellow the holly somewhat. Are you planning to touch up the undersides of the wales or is it invisible in the upright position? I'd worry about bleeding into the holly even with tape. Perhaps a scored line as David suggested elsewhere?
- 1,449 replies
Lovely, Chuck. It matches your planking plan beautifully - almost like you planned it
- 1,051 replies
- cheerful
Great job on those mast tops, Danny. Did you have any problems with warping after gluing them up?
Echo by jml1083 - 1:48 - Cross-Section
dvm27 replied to jml1083's topic in - Build logs for subjects built 1751 - 1800
You couldn't ask for a more perfect start for your Echo Jim! -
Echo by Maury S - FINISHED - Cross-Section
dvm27 replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
In my Pegasus case are several workshop projects such as the cutter in frame, mast and a yard. They really add to the display.- 324 replies
Sorry, but the like button just doesn't cut it for work like this. Your updates are highly anticipated by all of us. Take a few days off for Thanksgiving then get back to work!
- 3,618 replies
- young america
- clipper
You're in luck. Olof Eriksen has built a Cutty Sark as well as Victory and Constitution...all in steel. Of course he has the advantage of being a master machinist and owns a large industrial manufacturing company where he also built his models in his spare time (or on the clock since it's his company). Here's a link to some photos of one of his models http://uniquesystems.com/u-s-s-constitution/. Do consider that a fully rigged (steel rigging of course) steel model of Constitution weighs 1300 pounds and requires a case 15' x 8' x 10'. This could upset some spouses. His Victory Model is featured in a two part Scale Ship Modeler Magazine (1990) article and this stainless steel model is an exact duplicate of Longridge's model in London, right down to the anchor stock planking of the hull. I don't know where his Cutty Sark resides. I believe Olof is or was a member of the New Jersey ship model group so maybe Chuck knows.
Once David and I have completed our upcomming workshop on sail making we will proceed with the next Echo class installment. You can't go wrong using the Swan series as a guide but read ahead to make sure you aren't digging a hole for yourself (like adding the port stops before the outer planking).- 324 replies
Congratulations on a major milestone, Toni. Looking forward to those after treenailing/sanding photos!
- 1,449 replies
Very nice, Ben. All the gun and sweep ports seem to be aligning quite well.
- 889 replies
Danny and Tommy are both Aussies so maybe all Australians are gifted? After seeing Tommy in concert I wanted to turn my Matin guitar into timber for my ship model.
Were ship figureheads routinely removed?
dvm27 replied to robnbill's topic in Nautical/Naval History
I seem to recall seeing a painting wherein the ship's figurehead was encased in a protective cage while at sea (iron). Anyone else remember something like this?
