Everything posted by druxey
If you must use wire wool, use bronze not steel for the reasons given above. However, it's hard to find these days.
That is one of the critical points in forming the quarter gallery; everything is parallel to each other. You should be fine from here on.
- 399 replies
- winchelsea
- Syren Ship Model Company
Ships name 1700s
druxey replied to DaveBaxt's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
B. E.: I know that the French usually showed the ship's name in a compartment on the counter, but was not aware of this being done by the British in the early 19th century. Victory's name was certainly seen this way in early 1900's photographs (below), and persisted until changed to something more appropriate recently. -
Wet and dry paper is used for metal, not wood. This, and the fact you are using extremely fine grades is why you are getting clogging. Garnet, emery, aluminum oxide and silicon carbide are used on wood. See: https://www.empireabrasives.com/blog/sandpaper-grit/ Usually, for wood, 400-grit is as fine as you need to go.
Best wishes as you manage an elderly parent. It's never easy.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Ships name 1700s
British ships' names appeared across their counters officially in 1772, although this may have formally been done for a few years earlier. The practice seems to have been discontinued during the Napoleonic wars. -
Soft, medium or stiff brushes?
druxey replied to CPDDET's topic in Painting, finishing and weathering products and techniques
Look after a good quality sable and it will last you years. I have some over 30 years old and they are still in good shape. Cheap brushes are a snare and delusion. You have to keep buying them over and over and they will shed hairs in your beautiful fresh coat of paint! -
Swan-Class Sloop by Stuglo - FINISHED - 1:48
druxey replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
The illustration shows full-size practice. You can cheat, as long as the end-result looks right.- 475 replies
Glad you had such a good time. I'm so sorry that I had to miss the great showing this time. U.S.: Why you no open land border to nice, polite, vaccinated Canadians?
- 2,699 replies
- heller
- soleil royal
(and 9 more)
"When all else fails, read the instructions!" Good save, though!- 475 replies
Looking good; gryphons notwithstanding (or flying, for that matter).
- 186 replies
- keelless
- reverse clinker
- (and 4 more)
Magnifique, Monsieur! Thanks for the update and best wishes at new London.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
That netting is a work of art in itself, Keith. Congrats to your good lady. Glad you've solved the turnbuckle problem as well.
I've just stumbled across your terrific build, Brian. There are just too many posts to click 'like', so please take them as read.
2022 MODEL SHIPS CALENDAR
druxey replied to kurtvd19's topic in NAUTICAL RESEARCH GUILD - News & Information
The meaning of 'speculum' has morphed over time. Bob. It also used to mean a mirror, reflector or lens. In other words, it meant an observational aid. Certainly the meaning of a medical instrument was (also an observational aid!) also used at the same time period (the late 1500's). Information is from the reliable Oxford English DIctionary.
