Everything posted by druxey
So sorry for you both, Michael. Been there, not easy.... Any missing pet really leaves a hole. I imagine Tyra had a great life with you both. 20 years is a good innings, but that isn't of much consolation.
- 2,215 replies
Friezes
druxey replied to Diver's topic in Medway Long Boat - 1742 - Public group project.'s General discussions/How to join
Or use slightly watered PVA (white) glue. -
Dilute the white glue to a milk or light cream consistency.
- 43 replies
- Norwegian Sailing Pram
- Model Shipways
The measurement question is answered in that the ship was built using British feet and inches, ans measurement for the model are quoted in the same system. Instead of driving yourself crazy converting measurements from duodecimal to metric and then dividing by 48, try to buy a scale ruler (on eBay or elsewhere) that has a 1:48 scale on it. Then you can measure everything directly.
I've not used an Exacto handle in many decades, having switched to Swann-Morton like Allan. I'm amazed that they still make their handles round. Has nobody sued them for injuries such as Allan has mentioned?
Joinery
druxey replied to Maury S's topic in Building, Framing, Planking and plating a ships hull and deck
I'm trying to imagine the inside of the joints! -
Similar diagonal braces against the side of the hull aft were called sleepers, not pointers.
- 3,560 replies
- clipper
- hull model
Oh, my! I'm just catching up on your last few weeks of work. That chaloupe is simply a lovely little gem. Hopefully the geometry of the quarter gallery lights will work out for you. Looking good!
- 2,696 replies
- heller
- soleil royal
(and 9 more)
To confirm: pointers were X oriented diagonal braces across the ship's hull, popular in the 16th and 17th centuries. However, they cut down on space in the hold. Riders replaced these.
- 3,560 replies
- clipper
- hull model
I understand this arrangement and don't question it, Siggi but, in general, it is unusual! I imagine the hinges would be well protected when under the replaceable lining. Also, even when not shown on the draughts, the lining would have been there.
Proud owner of a Dremmel drill stand
druxey replied to DaveBaxt's topic in Modeling tools and Workshop Equipment
Why bother with a make-shift lathe of any kind? The old time spar-makers simply made the spar a tapered square in cross-section, then planed it octagonal, finally 16-sided and then rounded it off. One can do this easily at model size using a V shaped holder and a 7-10-7 proportioned scale to mark the sides of the square stick out before cutting it octagonal. One can use a mini-plane or sharp chisel for this. It takes little time and, at model size, after the 8-square is cut, sandpaper does the rest of the job. No power equipment required! -
Interesting quotation. This was apparently a merchant ship. In a naval one, the spaces between the frame timbers were filled to the level of the floorheads with oak, presenting a continuous surface. The circumstance described could not have happened. Also, in naval ships the floors were planked over (the ceiling planking) and permanent iron ballast placed above that.
Coagulate is the word you are looking for. According to the Internet - which, as we know, is infallible! : Egg whites coagulate at 60°C, egg yolks 65°C, with full coagulation occurring at 70°C. But, once again, we digress!
- 186 replies
- keelless
- reverse clinker
- (and 4 more)
Dan: There are several liquid solutions used by conservators to consolidate brittle and fragile lines. Cellulose nitrate in acetone is one possibility. HMG adhesives in thick and thin formulations are others.
- 95 replies
- POW
- Bone model
I wonder whether there are still enough pieces of The True Ship around to reconstitute her.... Just kidding!
- 3,560 replies
- clipper
- hull model
I hope you've labelled that piece, Michael. Otherwise some day it may be mistaken for firewood....
- 3,560 replies
- clipper
- hull model
That is interesting that a gun port was placed in the path of the anchor lining. I don't question it - it is on the original draught, but quite unusual.
