Everything posted by druxey
Excellent, Richard. Looking forward to seeing your hull grow.
- 30 replies
Swan-Class Sloop by Stuglo - FINISHED - 1:48
druxey replied to stuglo's topic in - Build logs for subjects built 1751 - 1800
If you only took eight months to get this far on a hobby-time basis with a young family as well as work, I'm impressed! That's a major achievement for a first fully framed hull. The pay-off will be as you sand everything to a fair surface.- 475 replies
Like Mark said, Joseph. Welcome!
Thanks, ClipperFan. Now, if I were retired....
- 3,560 replies
- clipper
- hull model
Someone else can add those details. Thanks for your very helpful input, ClipperFan.
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Clipperfan: The only way I can draw that to articulate properly is if her elbow is higher and forearm more horizontal, which will obscure her face in side elevation. Is that your take on this?
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Looking good, Richard. Toni's advice is sound if you haven't faired inside yet.
- 30 replies
Carlings
druxey replied to Don Case's topic in Building, Framing, Planking and plating a ships hull and deck
Please read Longridge's Anatomy of Nelson's Ships or Goodwin's Sailing Man of War, Don. Either will inform you more comprehensively than any brief answer here. However, briefly; every timber on a ship had a structural purpose. The beams of a ship need a lot of reinforcement that planking alone simply would not supply. -
I still own and use an identical palm plane, also made by X-Acto. It has a little less red paint on it now, though....
What were your first tools as a child?
druxey replied to FlyingFish's topic in Modeling tools and Workshop Equipment
Ah! Memory lane.... My very own first tool was probably an X-Acto knife. I recall having a small set in a wooden box with the small and large handle. Before that I used my father's tools, some of which I still use today. -
I interpret the right hand holding the bunched drapery, so is mainly hidden under the drape. Am I wrong?
- 3,560 replies
- clipper
- hull model
- 3,560 replies
- clipper
- hull model
Thanks for the feedback. It was difficult to render the right arm from the differing angles of the various photos.
- 3,560 replies
- clipper
- hull model
It's the horizon lines that show the tilt of the prints are different ones of the same photo. All right, gentlemen, my two cents' worth is added!
- 3,560 replies
- clipper
- hull model
Perhaps you should re-christen the model "Bad Luck Boney", Dan. The years have not been kind to her.
- 95 replies
- POW
- Bone model
Sloping deck
Meanings and usage of words change over time. I do not know when 'camber' was adopted to replace 'round up' but suspect it was in the mid-nineteenth century. However, camber was the descriptive word used to describe the deck construction seen in the draught above. Steel, Naval Architecture page 14,1805: CAMBER. Hollow or arching upwards. the decks are said to be cambered when their height increase toward the middle, from stem and stern, in the direction of the ship's length. -
I'm surprised that you can't source a Proxxon in Canada. Try: www.chippingaway.com or www.Nutmegwoodworking.ca
Sloping deck
No, although it does help drain. The deck is sloped down (this is actually describing 'camber' as the word was used then) to the hawse holes. This allowed the cable to come up on the weather deck. If a deck lower, the hawse holes would be too close to the waterline. On this plan the hawse holes and scupper are not shown. To clarify; 'camber' is the rounding down of a deck as seen longitudinally and 'round up' is the correct term for the transverse (athwartships) curve of the deck and beams. -
Do you ever use miniature broaches to clear small holes? I find them very helpful. The new crowsfoot looks good.
- 95 replies
- POW
- Bone model
