druxey
Everything posted by druxey
  1. Thanks, but not yet, Chuck! It's gesso and sand and repeat time now.
  2. Just about completed the smoothing of the plug. It is worth taking time to refine this even though it isn't part of the model itself. A little filler was required in spots in order to create a smooth fair surface. Next will be several coats of gesso and sanding. The planking runs can then be marked out.
  3. The sheer was sawn out and smoothed using shaped sanding sticks. The half-hulls were then joined with a central 'spine' to allow for the keel/stem/stern post assembly. The projection allows me to clamp the plug in my vise. Shaping then began using a sharp chisel and gouges.
  4. Coming in late to this party, that is a lovely job that you are doing on this, Håkan. Visually the colors work very well.
  5. The lifts for the plug have been cut out and glued up. Next, the profile of the boat was marked out on the inner surfaces of the halves. I remembered to keep the off-cuts of the lifts to temporarily glue on again in order to scroll-saw the profiles!
  6. Lovely clean work. Usually the first head beam is in one piece and scored on to the front of the stem head. I've not seen this arrangement before.
  7. Thank you kindly, Bruce. That would be much appreciated! If there will be blame to be laid.... It's not often one has the luxury of a specific period small boat photo to refer to. Yes, Håkan, she is definitely carvel planked.
  8. Well, having read the thread on an article seen the drawings and photos about a cutter preserved in Venice, the beautiful form has inspired me to attempt to build a model in 1:48 scale. The first step was to download the photos of the pages in the article that showed the surveyed drawings. These had to be stitched together and distortion removed, which was done in PhotoShop. Then the drawings had to be re-sized to 1:48. Having the overall length, width and depth helped define the reduction required. Once the drawings were to scale, I could begin. The first step was to begin preparing a plug on which to build the hull. Leaves of yellow cedar were cut from blocks (1) and sanded. Four layers a scale 4" thick, two layers 8" and one layer of 15" were needed for each half of the plug. These thicknesses matched the waterlines on the plan (2). Tracing paper was used to transfer the waterlines to the leaves of cedar and laid down using graphite paper (3). The opposite pairs of wood leaves were rubber cemented together before cutting them out on the scroll saw. To be continued!
  9. If I may comment; I'm glad that you are having a good time, but reading and understanding the instructions first will prevent frustration!
  10. I have a whole box full of different flexible and rigid sanding sticks and blocks. The blocks have convex and concave surfaces in different radii. Great for sanding things like stem pieces or deck beams.
  11. Great result, Mike. The hanging of a rudder is so often poorly done with a huge gap between it and the stern post.
  12. Quick! Ask Phineas for his 'shipwright's secrets'!
  13. Have you considered turning just a master pattern and casting the guns that you need? That way they would all be identical. As Wefalck points out, your lathe set-up is far from ideal for repetitive miniature work.
  14. Well done, Dan. Your client mailed the parts in an ordinary envelope????? At least I'm glad that the aquarium case has gone! She looks great. And now you don't have to smell the ivory any more!
  15. Don't slather on the epoxy? Also, you could put a bolt through that has a light coat of oil or grease if you are really concerned, then remove said bolt after.
  16. You will find, unless building a floating box, that every knee will be slightly different and will need custom fitting. Mass production here won't fit.
  17. Each knee will be 'custom', not off the shelf! If you are planning to rig later, there are also a myriad blocks to make....
  18. About ¼" by 3", but I make them in all kinds of sizes depending on the application.
  19. I suppose that the wood specie you are using is the issue. You need a dense wood such as pear or Castillo for such items.
  20. If you look at the frame pattern, you will see the slot for the deadwood. There are two lines across the top of the slot. The solid line is the fore edge of the frane pair and the dashed line indicates the bevel to allow the frame to sit at the correct height. Does that solve your problem?
  21. Run the grain diagonally so that neither arm is cross-grained.
