Everything posted by druxey
Welcome! What you wrote about your experience so far is exactly what all of us have gone through/are going through. You will have plenty of sympathy and advice if you need it here. For a first attempt, you've done very well. Your model looks like most folks' third or fourth!
I hope your grandson is watching and learning your techniques. Make sure he starts a log on MSW as well! We'll be watching.I 'm happy to read that he will carry the torch on for you.
- 29 replies
- hmw
- Hamburg Harbor
I missed 'Nike' completely! Thanks for pointing it out. Early promotion, not for a shoe in this case, but a runner!
Looks like an early version of what was called a 'shoe block' in the 18th century. In that case, the two sheaves were set at right angles to each other. Think two single blocks joined end to end at right angles.
You might be interested to know I found a copy some years ago of The Practical Shipbuilder of 1839. It was reprinted in limited facsimile edition in 1940 by Richard McKay. Inside the front cover is glued a sliver of wood about 1" square and about 1/16" thick, labelled in pen: Piece of the Ways Donald McKay's Shipyard East Boston - 1845 - 1875 The book is dedicated and signed by Richard McKay. There are seven fold-out plates of representatire hull forms of a sloop, brig, etc, up to a large ship.
Terrific work, as usual, Danny. I'm sorry that you are having difficulty continuing. If you can't complete this model, I hope you know someone who can and do both the model and you justice.
- 29 replies
- hmw
- Hamburg Harbor
You make this look very plausible, Sceatha!
- 81 replies
- egyptian
- byblos ship
A question about glue.
druxey replied to danbloch's topic in Building, Framing, Planking and plating a ships hull and deck
Like the other gentlemen say! -
When I first made open boats, my molds were made with grooves for the frames. I realised later that I didn't need to do that: I simply built the planks, edge glued over a plain mold. After freeing the shell, I bent in the frames (this is at 1:48 scale). Works just fine and saves a lot of work. Clinker boats can be built in the same way. The only critical points are: a) The planks must be accurately spiled b) the fit between strakes be really tight in the case of the carvel hull
Not only do I enjoy looking in on your log and progress, but this little piece of etymology is fun to learn about as well!
- 81 replies
- egyptian
- byblos ship
Don't drop the thread, Steven! That will cause the same issue of skinny planks, but just move it down. Two drop planks under the wale illustrated in the photo.
- 740 replies
- Tudor
- restoration
(and 4 more)
Aft looks pretty nice to my eye. Forward is good, other than you may need to 'drop' a strake or two under the wale to avoid plank ends of the upper belt becoming too skinny into the bow rabbet.
- 740 replies
- Tudor
- restoration
(and 4 more)
