druxey
Everything posted by druxey
  1. Seeing your reference, Gaetan, have you tried melting the end of the brass rod to form the 'bouton'? I've found that by holding the rod or wire vertically (not with my fingers!) and holding the torch at about 45 degrees, the tip of the metal will melt and form a round ball. You could then flatten it if you want.
  2. Steven: the ornamental work and stern were simply symbols of affluence and power. Practically, they were of no use whatsoever, other than providing windage! Some further progress on the ornamental brackets. They are glued to a scrap base and the first sides carved. They will then be detached, turned over, and the other sides completed. As you can see, they are rather small and fiddly things to produce.
  3. Glad to read you are back at the model and hopefully not too much worse for wear, Frank. Hopefully frame alignment won't be a big issue for you. She's looking good.
  4. Steven: That is a rather naive engraving of the procession, of which many different images were published at the time. The date of this was January 8. 1806. It must have been a cold, miserable day for this. The canopied, ostrich-plumed barge, (lower centre) is the one carrying Nelson's coffin. A more sophisticated and perhaps accurate version of this scene at Greenwich as the cortege departs is also in the RMG Collection (PAH 7324)
  5. On the other hand, perhaps a re-do of the piece if the gap is that large?
  6. I totally understand, Steven. I worked without power tools and on a shoestring for many years. A thin coat of wax shouldn't narrow your grooves. Other solutions are a coat or two of gloss varnish. I wouldn't recommend anything that is water-soluble like white glue (sorry, Mark!). Personally, I use paste wax over gesso. And I don't think soap is quite 'it' either - water soluble.
  7. Ah, yes. Th aggro of printers and scaling! My empathy on that, Maury.
  8. Gorilla glue is ghastly stuff! I had a friend who tried to fix a piece of furniture only to have it end up glued to his carpet.... Use white PVA or yellow aliphatic glues. Much better choices.
  9. Thank you all, yet again. Today's work was on the Hospital badge that is mounted high on the boat's stern over the upper transom. The pictures are self-explanatory. At this scale the paintwork is more impressionistic than accurate! I'll be refining the shell on the fore side of the badge more.
  10. Well, some progress to report. The ensign staffs are done. They were made and tapered using the usual square to octagon to round method. The trucks plus a few inches below them are painted gold. I scored around each staff to act as a stop for the paint: it was too small to mask conventionally. For those wondering why the pace has slackened a bit, I've another project to announce shortly.
  11. Ah, I misunderstood. Yes, the framing will need lateral stability when you come to fair. Even wedges of dense styrofoam should do the trick, I would think.
  12. Nice progress. I like your planking layout on the upper bow. I see McKay has drawn the wale planking thicker at the bow rabbet than the rest of the planking. This was not usual: wale planks normally taper around the bow and are the thickness of the rabbet where they land in it.
  13. Good stuff! Nice to know the kids aren't being entirely neglected....
  14. Those frames look terrific, Frank. As for keel flex, once the keelson is in and there are longitudinal such as deck clamps, the structure will be much more stable. As far as time goes to construct frames, your results are worth it.
  15. If you are a serious modeller - and it appears that you are - and can afford it, you should seriously consider a small circular saw.
  16. If I may comment again, Maurys, those lodging knees look rather 'chunky'. Check out photos of contemporary models, and you'll see that the athwartship arms are narrower.
  17. Seems like a more workable solution, both from a stability and ease of construction perspective.
