Everything posted by druxey
An excellent primer for learning rigging techniques, Toni!
- 80 replies
- rigging/masts
- NRG
Colchester Smack by Colin B
druxey replied to Colin B's topic in - Build logs for subjects built 1851 - 1900
Nice to see a more unusual subject, Colin. Your 'good enough' certainly is!- 13 replies
- Working sail
- Plank on Frame
Well, Chris, you are mastering a number of basic techniques that you can apply to more complex models later. As for the thwarts, it's much easier to trim them down to fit than to stretch them! You did a particularly nice job at the bow transitioning from clinker to flush at the stem. Well done.
- 30 replies
- Grand Banks Dory
- first build
I also noticed the disparity mentioned by Craig. However, a closer look revealed a structure beyond the bow of about the same tone. Perhaps the vessel behind her? Certainly an interesting subject, Jond!
- 46 replies
Just catching up with you, Alan. You'll be glad you corrected the orlop, as it would otherwise affect the line and clearance of the deck above and.... Drilling hawse holes is a very iffy thing, as you've discovered. Years ago I figured out a new strategy: I filed half-round grooves in the hawse pieces before assembling them on the model. The diameter was just slightly undersize and just required touch-up filing to final size. No chance of tear out or breaking off a hawse piece, plus the upward angle and parallelism to the keel of the hole was established and controlled.
You will have as many opinions as there are model-makers! If longevity is not a concern, then.... anything goes. For stability, hollow wood is a better choice. either hollow lifts, or plank on bulkhead. Other than the species already mentioned, another possibility is yellow cedar, if you can get it in your area. It is a nice stable wood easy to work with a pleasant odour when cut.
Use just one elastic band per frame, over the frame. Use a small piece of scrap under it as necessary. If the plank is wet bent, it really shouldn't need a lot of force to hold it in place.
- 69 replies
- Lowell Grand Banks Dory
- Model Shipways
The diagonal joint is great when there will be a lot of stress on the finished item. In your case I suspect the load will be minimal!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Those thimbles are a great hack! Well invented.
- 562 replies
- vanguard models
- alert
Two points: One, if you aren't happy with something now, you won't be happy with it later! Two, use rubbing alcohol not only to debond, but also to soften and remove any residual glue squeeze-out later, if you missed a bit. Glad that you are enjoying the experience and the challenge.
- 69 replies
- Model Shipways
