druxey
Everything posted by druxey
  1. A knot won't do what you want. You have to do it the way it was actually done. The block is stropped and then lashed to the yard. That way it will orient correctly. Check any standard book on rigging to see this.
  2. Had you considered very fine chain link from a jewelry supply house?
  3. Please, if you are extracting solvent vapour, you MUST have a sparkless fan motor!
  4. You'll never go back to basswood now! Enjoy working with quality wood.
  5. Mark: sorry that I'm late in on this conversation. Read the three tutorials on lining out and spiling on this site before you go too far. Under 'Building, framing, planking and plating...."
  6. In the Chicago area, you will need to frame, insulate, vapour barrier and drywall the perimeter for sure. You are probably right in calling in a qualified contractor to do all this properly. I have a laminate floor over a cushioned insulating barrier on concrete and this has worked well for me. I do some sawing, etc. in the basement: a shop vac and suitable hook-ups to machine tools are necessary (see Lee Valley). In addition I have a ceiling mounted fine dust filtration system. No complaints from my Admiral.
  7. I have no idea, Alex, but suspect from its appearance that it is less than 50 years old.
  8. Alex: although the Royal George model in your link is beautifully crafted, it is a modern interpretation. Apart from the nibbed plank ends, the butts on two adjacent stakes would never be placed on adjacent beams. This would be a weak construction technique. When researching "How was it really done?", always study the remaining historical records. Modern interpretations, however well made, can be very misleading. Of course, if accuracy is not an issue for you, ignore what I've written!
  9. Good stuff, Alex! I'll be over with a suitably sized joint of meat soon.
  10. Your metalwork is beautifully executed, Alex. Will the stove have a chain-driven spit as well?
  11. Welcome back, Doris, and congratulations on a stunning model! I'm sure many of us were wondering what and how you were doing. I hope your new work is satisfying and will allow you time to continue to create more outstanding models. Dobri!
  12. Sorry, Robin: it is the lights that can be hinged up and aft for ventilation. The sections of the bulkhead would be struck for cable handling in this case. I apologize for any confusion.
  13. If it's 18th century you are after, the book suggested above is The Fully Framed Model, Volume IV, published by SeWatchBooks. That gives you all the detail you'll ever want for the period 1760 to about 1785.
  14. For cable handling, the bulkhead panels would be hinged up under the forecastle against the beams, Robin.
  15. Good advice, Pete, and very nice chairs!
  16. Funny how doing things for a second time always seems to go faster. You did save this now, didn't you?
  17. Nicely done. I feel my own method much inferior now; I simply hold the pieces up to the window (daytime) or task light (night)!
  18. Nice looking bulkhead, Toni, although I was puzzled that you applied a comedian to both sides of the basswood. Perhaps you meant to type 'Castello'?
  19. I would think that deadlights that swing up would be more likely. The more elaborate hidden sliding versions would be for Admiral's quarters on a first rate!
  20. Interesting question. Steel (1794) states that the ratlines only go across every 6th lower shroud. However, contemporary models show all the ratlines going all the way across.
  21. Tom's idea is a good one, but I'd try this out on a sample of fabric before you make a whole suit of sails, just in case it doesn't work!
  22. While I'm sure that staple spacing was calculated using some proportional formula, Alex, the photos I was looking at showed much closer spacing than you suggest.
