Everything posted by druxey
I would diplomatically disagree with Marquandt if you are referring to an English ship. Pin racks are the term used by Steel. Very nice work, Greg.
A lot of moving parts to keep track of and to coordinate! Devil's advocate here: Could you cut off the aft end decorative scroll and horse's head and reattach it slightly further down the head rails? Then it would not rise quite as high as at present. Feel free to ignore me, Marc!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Two interesting items you've shown, Ron: that 'Quad hand' looks very helpful; and the dusting powders, which also look very effective. Thanks for bringing these to our attention.
- 542 replies
- Sphinx
- Vanguard Models
(and 3 more)
Mediaeval Shipwreck found in England
druxey replied to Louie da fly's topic in Nautical/Naval History
Lots to be learned from this wreck when it is studied! Thanks for posting this, Steven. -
Visiting this thread is always a pleasure, Rob! Obviously with such a vast quantity of rigging, time management and work flow becomes important.
- 3,560 replies
- clipper
- hull model
Royce's lathe? That must be quite a story! I like the elasticized clips on the frame for stretching material. If you had a greater number of clips around the periphery, it would take care of the ripples when the fabric is wetted.
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Is there a possibility that a line was rigged from the main yardarm to swing the boat outboard sufficiently to clear the boom?- 1,013 replies
- gun dispatch vessel
- victoria
Are you able to rig in your sleep by now, Rob? Beautiful work, as ever.
- 3,560 replies
- clipper
- hull model
Re-dos: The mark of a true model-maker. Good on you, Bob! You'll be glad you revised the rigging. There should be a little stretch in the shrouds to allow you to align them.
- 146 replies
- Harriet Lane
- Model Shipways
To prevent 'hourglassing' the shrouds due to over-tightening ratlines, do every fifth ratline first, then every third and lastly the remaining ones. It's easier to control the tension that way.
Well done, Bob. Those home-made eyebolts look fine.
- 146 replies
- Harriet Lane
- Model Shipways
Good for you doing that surgery, Marc. If you make an angled bend at the corner of the beakhead bulkhead, would that not give a straight run to the back of the figure?
- 2,699 replies
- heller
- soleil royal
(and 9 more)
