Everything posted by mtaylor
I'm glad it went well, Marc. Take the time off you need as burn-out is tough to recover from. Druxey, we're paranoid about everything lately.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Grumpy and eccentric is an understatement. Some of practicums aren't bad. Others seem to be rather haphazard with bits and bad bits. I'd use the build logs here as primary reference and his book more as an overview. Personally, I wouldn't waste my money on them based upon what I've seen. Oh.. and he goes ballistic if try to sell the book as he claims you can't legally do that.
https://www.reuters.com/world/middle-east/shipwrecks-world-war-i-are-seabed-museum-turkey-2021-10-02/
How was the show, Marc. I hope you had a great time and your ship got a lot of attention which you and it deserve.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
I think the part in the water doubled as a ram. The French and others did several like that before they realized that the "new" ships would never close and board.
Maybe this is the one I'm thinking of..... https://twistedsifter.com/2012/08/30ft-model-replica-battleship-admiral-graf-spee-william-terra/
I recall seeing a video of a battleship that could be driven about a lake. Might have been that one. He towed on a special trailer and also lent it out to places for promotional reasons, etc. Might have been that ship.
I believe there's a museum that has folks doing some work. Maybe just mapping the wreck and a bit of recovery.
Thanks for following along, everyone. More of a proof of life and just a minor update after a busy week. I took my planking fan and sorted out how the strips need to be shaped. Then started gluing them with school white glue together in stacks of 15. Once the glue dried, I shaped each stack with my mini belt sander and once done, put them in water to soak and be separated. I've started planking. About 6 strakes so far on each side. A bit of luck and the first layer should be ready for sanding either tomorrow night or Monday. I'm believing I'll have to do minor filler after sanding. <fingers crossed)
- 505 replies
- vanguard models
- Sphinx
Welcome to MSW, RA. You might go to the top of the page and look at "Group Projects" for ideas. Some are kits, some are "semi-kits" and some are scratch.
If you haven't done this, I urge you to.... Test the scanners/printers against the original. Scanners and printers for a long time have not done exactly 100% copies. They're off by as much as 2-3% for each machine to prevent counterfeiting of money. I've run into this in the past and now use a local architectural print service.
- 38 replies
Yeah... I'll have to move fast as winter is coming. I'll also take some appropriate materials to do some underwater basket weaving for relaxation.
https://www.cbsnews.com/news/north-dakota-drought-exposes-130-year-old-shipwreck-abner-oneal/
Well done and well detailed. The helicopters look good from here. In person, they probably look better as the case keeps one's nose from getting too close.
Beautiful machining, Rik. On the flywheel groves... could it be spun up on the lathe and a file used to gently remove them? Or maybe emory cloth? I machined some cannons years ago and had to that for the same reason... not sure what caused those groves. Later found out, I could avoided them by using the power feed on the cutting tool.
