Everything posted by mtaylor
Hi Stickyfinger,
The painting is from the 1600's I believe. The reference to the 1744 la Renommee would be correct for that time period. French builders/designers made lots of changes even from ship to ship in the same class. Some changes were applied to other ships, some weren't. I've run into that problem with my Licorne. Originally looked similar to Renommee (8 pdr frigate). It was reworked heavily and ended up looking closer to Belle Poule. The masting at the rebuild was, shall we say "unique". The masting sizes were the same as la Venus, an 18 pdr of 1782. Oh.. no port lids on it either.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
Essentially, just start a log. Your choice if you want to add pics and text from before where you are now.
HJX, I'm not sure about the licensing on the carvings. If the carvings are done from historical drawing is one thing. If done from a model kit, there probably would be. Then again, with all the PE parts for steel navy ship models, is there a license fee paid? I have no idea. You might ask this of Chuck as he probably could tell you.
- 244 replies
- heller
- soleil royal
As I understand it, French frigates of the 1700's only had a port lid on the very first port which didn't have a gun in place. That port was used for anchor handling. As for the rest of the ports, they used bucklers if the weather dictated such. There are some other details different in the frigates from the ships of the line. The ports on the ships of the line with the nail heads. I wonder of the inner planking the carving was on was rather thin, more like a backing to hold the carving? Then the nails would be there to hold the backing on. I note that there's no drawing showing how the carving was affixed to the port. Come to think of it, I've never seen any details on how any carvings were affixed to the hull.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
HMCSS Victoria 1855 by BANYAN - 1:72
mtaylor replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Well done and looking good, Pat.- 993 replies
- gun dispatch vessel
- victoria
Animated video of useful model rigging knots
mtaylor replied to Bob Cleek's topic in Masting, rigging and sails
For those not on Facebook... there's this site: https://www.animatedknots.com/ -
Welcome back home, Halbaby.
I didn't realize the holes were pre-drilled. Have you thought of small pliers (needle nose type) with on jaw that round? I recall seeing them used. The ones that have, the rounded part is tapered but I've also seen some here that non-tapered. Not sure if they're custom made or can be bought.- 993 replies
- victoria
Cutty Sark by Cuda1949
mtaylor replied to Cuda1949's topic in - Build logs for subjects built 1851 - 1900
Al, Get yourself some white glue. Mix the glue with water in about a 50-50 mix and brush the ratlines. You can then use a small tool (a nail is what I've used) and give the rats a nice, gentle, downward curve. But to test first as not all threads are equal. -
Hello Henrik, Welcome to MSW. If you look in the Kits section, there are 14 Agamemnon logs. Not all are finished though. But they will be a help to you with your model. We have an index in the Kit area of all the build logs. I'm attaching a copy so you can find the Agamemnon logs. I and others recommend that you open a log as it's the best way to get help when you need it, make some friends, and it will also help other builders. Wooden Ships.pdf
Pat, can you do the bending first and then drill the holes? Maybe use some CA to hold things together and then after the holes are drilled, soak in acetone.- 993 replies
- victoria
True, it does degrade in the body. We used it in Vietnam to patch guys before and during a Medivac. Here's a bit of history: https://www.popularmechanics.com/technology/a25067/the-surprising-military-history-of-superglue/ The catch was, it wasn't a fix all for most of them. Even so, the medics had it and so did some of us door gunners.
