Everything posted by mtaylor
Jesse, Battle damage in the shipyard happens to all of us... I just hope you found all the parts.
- 1,306 replies
- syren
- model shipways
Cool... not only are you an excellent carver, you're fast. I can't wait for the update, but I will... <twiddles thumbs><whistles><looks innocent>
- 962 replies
- sovereign of the seas
- ship of the line
Scalpel and tool storage
mtaylor replied to planktonette's topic in Modeling tools and Workshop Equipment
If the blades are loose, a strip of that magnetized rubber works well. -
Congratulations, Tim. She looks super. I guess the model tech has come a long way in 10 years, hasn't it?
- 24 replies
- gemini
- orange hobby
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
That's great news!!!!!- 4,152 replies
- cutty sark
- tehnodidakta
Tom, What's the TPI on the blades? Are you using a zero clearance insert on the scroll saw? I have 2 different blades I use for the thin stuff.. One is from Sawbird.. #3 Double Tooth Reverse (the teeth at the bottom dont' cut on the down stroke but on the up stroke. These are 20 TPI but I think they may have some with a higher tooth count. The other type is from Olson.. Skip Tooth #400 with 33 TPI Hope this helps.
Ken, I'm late with this... I'll look into that for the next ship. I'm kinda' locked into this method for the rest of the glazing, I think.
Looking good, Mobbsie. Try this.. think backwards. If you look at the plank on the ship it looks straight and flat, right? But when you pull it off, it's wide at one end and narrow at the other. And, the plank has curve on the flat plane if you push it flat on the bench. The catch is how to make that plank match that curve. Now, try taking a piece of cello tape that you can write on and stick it on the hull where you want the next plank to go. Mark the edge of the existing plank and remove the tape. When you stick it down on the bench or a piece of wood, you'll see the curve. Then mark off the plank with your measurements for width and connect the dots with a curve. It really is and it really isn't that simple. But once you figure it out in your mind's eye and have done it, there will be a moment... a big smile and the light is on.
- 129 replies
- armed launch
- panart
Jeff, They also make more than mini-drills. Do a search either here or on Google, you'll see what I mean. Also, one of our sponsors here at MSW is a dealer: http://www.proxxontoolsdiscount.com/
Bug, I think this will mean a lot not only to Diane but to the rest of us here at MSW. I'm sure that Augie would agree that Confed is in very capable hands. A fitting tribute and memorial to a wonderful human being and a great friend.
- 2,191 replies
- confederacy
- Model Shipways
Nice work, Kees. Breaking off the mold is always scary.
- 434 replies
- pelikaan
- beamtrawler
Sweet work on the figures, Dave. I'm in awe.
- 962 replies
- ship of the line
TurboCAD PC vs Mac
mtaylor replied to Maury S's topic in CAD and 3D Modelling/Drafting Plans with Software
A lot of PC programs get ported straight across to Macs. The problem is that often, the developers/programmers don't take the time to test (or rather the company won't give them the resource for this) and functionality is often lost. The OS's are just different enough that what works on the PC won't work on a Mac. -
It looks gorgeous in the photos and probably even better in person. I hope the sea trials go well.
