Everything posted by mtaylor
Echo by Maury S - FINISHED - Cross-Section
mtaylor replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Just beautiful, Maury.- 324 replies
Stunningly beautiful work, Ray. Indeed, be proud as you've done a fantastic job on her.
- 536 replies
- diana
- caldercraft
Wouldn't the color be a huge variable depending on the type of tree used for the bark? Perhaps even the individual methods of the dyer also influence this? I'm asking as I'm curious.
Ben, Can you make the mast removable? In for when it's on display, and out when it's on the water.
A stunning stern, Nils.
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
Beautiful work, Giampiero. I noticed the wonderful touch of the ropes securing the chimney hood over the fireplace. That's a detail I don't think I've seen before in any build.
Greg, The problem with many of the full-size tools is the size. For example, a full-size table saw. It's tough to find a blade with a fine enough tooth count that doesn't splinter the woods. Some things though, like a drill press or scroll saw (with appropriate blades), work very well.
This might help with the archaic language problem: http://southseas.nla.gov.au/refs/falc/contents.html Jeff and QA: What the others have said about a build log and asking questions. We all ask as no one has 100% knowledge, although some are pretty close to that. QA: Those instructions seem to be very typical of Billings. I think the Wasa's were about that simple. :D But it had a great set of drawings and booklet of photos (bad reproduction problem) and excellent drawings with dimensions, etc.
Tool for Sanding Inside of Curved Pieces
mtaylor replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
Chris, One tool I found works well is a variation of a floor polisher/sander I picked up from DaveS. I take a large Dremel felt disk and counter sink the hole a bit. The disk is then attached to the mandrel and then sticky back sandpaper is pressed into place the disk and trimmed to something approximating round. In the Dremel 90 degree attachment it gets me into the hull with ease. Just don't press hard, keep the disk moving and the high spots come down pretty quick. Finish is with another bit sticky back sand paper on small sheet of cardboard like the back of note tablet. Something flexible. I also use this on decks. Here's a pic: -
- 456 replies
- finished
- bomb ketch
I just spent an hour at your website and need to go back and finish.. the tool making alone is amazing craftsmanship.
- 281 replies
- falls of clyde
- tanker
You've done a magnificent build on her, Nils. I'm in awe.
- 2,625 replies
- passenger steamer
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Nenad, I'm like you. Not a master but having some fun building ships. MSW is a very good place for us as there are those who know and can teach us. And those watching, in turn, learn from our mistakes.- 4,151 replies
- cutty sark
- tehnodidakta
I tried thicknessing plank widths with a jig and that worked. The jig was basically a sheet of basswood with a slot to hold the strip on edge. The sheet was clamped into place on the sander and the strips fed through in slot. I'm wondering if that might work on beams?
- 191 replies
- young america
- clipper
There's only some pics in the gallery... http://modelshipworld.com/index.php/gallery/image/12629-jefferson-davis/
