Everything posted by mtaylor
Beautiful work, Remco and well worth the time, I'd say.
- 1,214 replies
- sloop
- kingfisher
Chinese Laser Engraver/Cutter
mtaylor replied to t5956ws's topic in Modeling tools and Workshop Equipment
Bob, 10L per minute on the flow rate. -
Tim, The thinner thread does look better and more realistic, IMO. Good fix.
- 144 replies
- basilone
- BlueJacket Shipcrafters
Air assist is a small compressor like one might use for a bubbler in a large fish tank. The water pump is a fish tank pump but one that moves 10L per minute or so. You can't use a slow drip as the heat must be dissipated lest you crack the laser tube. Air bubbles in the tube are also very bad. One other add on... a thermometer for the cooling water. There's an optimal temperature range with these things usually 20C(68F) to 25C(77F). I'm using a remote fish tank thermometer. I also put two one liter bottles of ice into the tank to drop the temp and give me a longer working time before the temp rises too much. The commercial/production folks generally use a chiller but that's dollars... so there is that trade-off. Cooling water needs to be distilled and also monitored for algae growth. Smoke detectors are good... but watching the cutting is better. It doesn't take much for one of these to catch fire and get out of hand. There's lots of good information here: http://www.lightobject.com on these lasers (in the support forum) as well as upgrade and replacement parts. -
Peter, Given that beech in the US may not be the same beech available to you, try it. Test it and see what it does. Your tale about the bonsai has a lot to do with shipmodeling. What's done early can come back and bite you later. Don't ask how I know this. I think there's a lot that is in the "depends" category... Will the frames be visible? To which you've already determined this one. How thick will the frames be (both width and depth)? Will the frames but cut as futtocks and assembled or will they be one-piece? It still boils down to "you're the captain and it's your ship, build it the way you want it". I've seen people use basswood for framing with success but there were problems. You might have to build your frames and then coat them with a mixture of glue and water to stiffen. Have some fun... we'll be around to help out and to see a nice ship being made.
I think I'm puling up a chair. After watching your builds on the other subs, this will be a "must see" event.
- 55 replies
- auguste piccard
- submarine
Definitely get the air-assist. It will help prevent flare-ups. As a laser cutter owner/user, here's some other tips.. 1) Check the lens. The Chinese have a habit of putting them in upside down. The curved part of the lens goes "up" towards the mirror, not down towards the material to be cut. 2) Keep a water spray bottle and a fire extinquisher handy. And NEVER walk away and let the unit cut or engrave un-attended. There's a lot of horror stories where the cutting material catches fire and the operator returns to find the area in flames. 3) Definitely set the focus. And also check that everything is square to the z-table. Shim/adjust as needed so that your focus doesn't vary from side to side and front to back. 4) If you haven't, align the mirrors. The beam should hit each mirror dead center. Here's a good link on these units.. and he has excellent alignment procedures: http://dck40.blogspot.com 5) Most importantly, have fun. But be safe, especially when cutting. Make sure the lid is closed. -
Tom, That is a very well known and documented condition hereabouts. I'd go see Dr. Per in his topic for this: http://modelshipworld.com/index.php/topic/474-therapy-for-shipaholics/
- 212 replies
- constellation
- artesania latina
To fix the title, just click "edit" on your first post and "more options" on the lower right had side. -
Hello Peter, Welcome to the darkside (also known as "scratchbuilding") I'm looking forward to seeing your build. Gaetan does have a good point about beech. I find that the grain is a bit too pronounced, it's an open grain wood, and it's also very flexible which for framing can cause problems. The beech available to might be different, though.
Beautiful woodwork on the decks and "family area", Pete. The contrasting woods work well together.
- 258 replies
- buzzards bay
- herreshoff
Cutter Cheerful 1806 by rafine - FINISHED
mtaylor replied to rafine's topic in - Build logs for subjects built 1801 - 1850
Sweet work on the rudder, Bob.- 525 replies
- cheerful
- Syren Ship Model Company
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
I like this also.. There is some great thinking outside the reality going on, Nenad.- 4,152 replies
- cutty sark
- tehnodidakta
Jim, You are making excellent progress in spite of the problems. The staining in place worked out very well.
Gordon, Try editing the topic to add some info... like Kit Name and Manufacturer. The title "instructions" won't help those looking at topics.
Brad, Have you had a look around the Kit Build Log area? Just go to that section and do search.. Here's the results I got: http://modelshipworld.com/index.php?app=core&module=search&do=search&fromMainBar=1 It's doubtful that anyone has built both kits but looking at the build logs should give you an idea as to which you want to build. As to "best"... that's arbitrary as it's in the eye of the beholder (or in this case... the builder).
Milo, There's a Ranger build going on by Matt.S.S http://modelshipworld.com/index.php/topic/9830-uss-ranger-by-mattss-corel-sm55-164-medium-4th-build-2nd-build-log/ You might check with him.
Denis, I'll wager you have a kit with a modification for that deck. Also, I'm guessing that those bulkheads are a lot stronger than they would be in plywood.. but don't go testing that. :D Looks like an interesting kit.
- 208 replies
Fascinating project, Steven. Not many of us would undertake such a project.
- 740 replies
- Tudor
- restoration
(and 4 more)
You should be a proud papa from what you've been telling us. May the spice flow and the force be with you.- 4,152 replies
- cutty sark
- tehnodidakta
ancre Le François 1683 by jose_b - Scale 1:48
mtaylor replied to jose_b's topic in - Build logs for subjects built 1501 - 1750
That's a very nice longboat, Jose. I like that unpainted wood. -
Those look like the Swann-Morton Plastic Surgery scalpels, Dave. They work a treat.
- 962 replies
- sovereign of the seas
- ship of the line
