Everything posted by mtaylor
Excellent work on the flags, Bug. I like the way they hang and drape....
- 274 replies
- Santa Maria
- Artesania Latina
Echo by Maury S - FINISHED - Cross-Section
mtaylor replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Beautiful, Maury... a feast for the eyes. What Druxey asked..... what's up next???- 324 replies
From the bits and pieces I've read, the topmost sails were set first. The Brits knew the fleet was coming out prior to the Battle of Trafalgar because the French and Spanish were setting the top gallants and top royals. I'm sure there's some books around that would describe this process... but darned if I know which ones.
Chalk up another error to AOTS.
Interesting to say the least. AOTS Diana doesn't show crowsfeet either which I would have thought was pretty standard for the period.
Tom, You can send them an email in English. What I've done in the past is write it in English and then put a Google translation right after it. What they do is not a separate drawing on other monographs I've seen but include the boats on the sheets for deck fittings. None of us English speaking types have the monograph yet, as only French is available right now. The English version is coming after the first of the year.
Can you post a picture or two? That might help, along with manufacturer (if it's a kit)?
Sure, I can divulge... but not take pictures or "try it out". I was allowed to inspect the contents and then it has to be put away for the next 7 days and a wake-up. A new laser tube for the laser cutter. It will boost power from roughly 32W steady state to 45W steady state. I'm hoping to cut 3/16" boxwood in one pass at a good rate of speed with minimal V-ing of the kerf. If that works... I'll give 1/4" boxwood a shot. I felt (and so did some others) that I needed more power. Anyway, the extension for the cabinet is arriving tomorrow. Need to modify the case as the old tube is 850mm and the new tube 1000mm long.. and a bit bigger in diameter. Hmmm....If I got a tube big enough, I wonder if I could build a Death Star? Surrender? No.. attack in a different direction... err.. hmm.... Admiral... yep... surrender.
Matti, The hull is looking good, and that shipyard has everything one could wish for.. including a Panzer.
Thanks for the "likes" and the comments. Yes.. Admiral's orders are not to be questioned. Then to, part of my Christmas present arrived today, and that re-enforced the following of orders. Happy day is coming... the rest of the present is due in tomorrow. Please don't give up. I find a bit of patience, a bit of stubbornness, and a willingness to scrap something and start over goes a long way. This really is my first scratch build of a full ship. The Triton was a good learning experience and confidence builder. I'm not perfect but trying.... For the record, this is my second shot at this ship. The first was sent to the breakers yard due to stupidity and not thinking on my part. Janos, That's interesting you had problems with pear also. Very strange. Thanks Paul.. See my answer to Etcher.
Dremel Versatip Butane soldering kit
mtaylor replied to riverboat's topic in Metal Work, Soldering and Metal Fittings
The torch would be faster even using soft solder, Frank. No need to wait while the iron heats up and the joint heats up quickly. However, go with what you're comfortable with. -
Cutting Boxwood
mtaylor replied to mikiek's topic in Building, Framing, Planking and plating a ships hull and deck
At that thickness, about a 160-170 tooth blade for a 3" diameter hobby table saw. I use mine for that purpose a lot. -
There is one other consideration, Frank. With silver soldering, the joint has to be almost perfect. There really isn't any wicking and gap filling like with the soft solder. -
Darren, 30 feet isn't unrealistic. Depending on the shipyard and what they had for lumber stock, it could be a bit more or less. Are you doing a build log of her?
Brian, Someone actually told you put a model on hold? You're not talking about the Yacht Mary, are you? Patrick, There was (might still be there) a frigate, as I recall in the Japanese Model site The Rope. The interesting part that applies is the builder used small hydraulics to lift the model into several sections such that each deck was visible. So instead of hydraulics, maybe something along the line of telescoping stanchions that would allow the interior to be raised and displayed as "layers"?
- 1,083 replies
Fantastic stuff you're doing for the decorations, Dave. They look super...
- 962 replies
- sovereign of the seas
- ship of the line
