Everything posted by mtaylor
Just one word from me, Denis... WOW!!!!!
- 555 replies
- sovereign of the seas
- mantua
Matti, Looking better than ever. What Nigel said about a cover up is a good idea. I've done a similar thing and recommend it.
Time to start giving hints, Kevin.
Short answer... no. 1/4 scale is equal to 1:48 in that 1inch = 4 feet = 48 inches of the real thing.
Jason, If you read through the logs, all kits have issues. Some with quality, some with amounts. Hang in there.
- 116 replies
- constellation
- artesania latina
- 1,873 replies
- occre
- san ildefonso
Mile, Beautiful work. I'm looking forward to seeing more. Drazen, Thanks for posting these.
- 86 replies
- royal caroline
- yacht
You might try softening the brass as it work hardens when you work on it. Heat it red hot and let it cool.
Plated Iron Hull
mtaylor replied to Pete Jaquith's topic in Building, Framing, Planking and plating a ships hull and deck
I've not seen that method. There was a builder on MSW 1.0 and I think did a bit here on 2.0 who was building a destroyer or cruiser using printing plates, which are thin metal. I'm not finding it... so I'm not sure he did carry it over. -
I've used spray mount (3M product) but it doesn't give you a whole lot of time to fix it. If it's that brittle, rubber cement might work. Put it on the mounting surface and then put the plan down on it. The problem is, any adhesive will probably grab pretty quickly. Have you tried contacting Model Expo and see if they have the old ones available?
Hi Jason, I used basswood for the galleries (from local hobby/craft shop). My references were pictures of the actual ship and then kind of winged it from there. I cut out the top and bottoms as mirror images (port to starboard) and then fashioned them together. A bit fiddly but it was fun and very satisfying when they were done. Don't use balsa as it's too flimsy and easily damaged. The only time I use it is for prototyping. I used it on the galleries to get the shapes right before cutting the basswood.
- 116 replies
- constellation
- artesania latina
Sjors the master... planking, ratlines, and now crow's feet!!!!
- 1,873 replies
- occre
- san ildefonso
Yep, the quarter galleries are crap. As I see it you can clean up the brass (I don't recall them being solid brass but white metal and bronze plating) and paint them. Or scratch build new ones. The ones in the kit are about half as long as what's on the real thing. I scratched the ones for my Constellation and they weren't all that difficult to make.
- 116 replies
- constellation
- artesania latina
Model Machines 4" Table Saw
mtaylor replied to dewalt57's topic in Modeling tools and Workshop Equipment
Al, Have look here at Jeff's Hobbymill page on how he uses the Byrne's Saw: http://www.hobbymillusa.com/byrnes-saw-operation.php Lots of good info on blades, etc. -
Nice work. Sort of like riding a bike isn't it?
- 237 replies
- cutty sark
- revell
You, are an Officer, sir. I'm a mere lackey down in the bilges.
- 625 replies
- bounty launch
- model shipways
