Everything posted by mtaylor
John, Looking wonderful. And to think, you do this in front of a live audience at the museum.
She's coming along beautifully, Denis.
- 555 replies
- sovereign of the seas
- mantua
Best wishes on the new posting. Hope it works out to your advantage. We'll try to be patient and also try to keep a certain person from bugging you for pictures.
- 1,319 replies
- caldercraft
- Victory
The case is looking grand, Augie. As for the "cruise"... maybe pre-assemble downstairs, take upstairs and final assemble? The thing will be a beast to carry. As for waiting by the mailbox, maybe we'll join you... a few resfreshments, maybe?
- 1,668 replies
- syren
- model shipways
- 1,279 replies
- agamemnon
- caldercraft
Nice work on the windlass. I'd think about at least planking the hull before fixing anything to the deck since you'll have roll the ship around a bit for that.
- 89 replies
- scottish maid
- clipper
Michael, The board itself will stay put until the exterior is at least fully planked and probably the quarter galleries done. Need the strength of all that. Or so I think. The frames with the black x's, I'm planning on removing those when the "not the wall side" is at that same point as the "wall side". On the other hand, there was a reason Hahn left the board on until it was fully planked in side and out and the carvings were on her. Methinks it's the convenience of having it on the board.
Thanks all. Matti, I'm thinking I'll just walk away from CA and use epoxy when I need that level of bonding. John, I think there's some distortion and maybe a shadow playing havoc. The build board looks bent and the door frame goes one way and the workbench the other. Weird. There is point just aft of the first port where it does start to run "high". The plank count goes from 6 to 6-1/2. What I did was use wider plank at the top to compensate and spiled it in. Those three upper planks (including the ebony) start to roll outward just about that first port. I'll revisit that area when I turn her about again to continue the planks up to the sheer of the foredeck. Augie, Anonymous works for me. Admirals get shot at first.... Pat, I don't think that will happen. My last day of work is planned for Dec. 31st. Speaking of gunports... did the French put a gun in the bridle port or leave it empty? I ask since the spacing between ports is wider between the first and second port then the rest and the first is also slightly larger. Also, the curve of the bow and the riding bitts seem to make the work area smaller.
I got the cracks filled using Chris's method of finish and sawdust and then sanded with 400 grit. I'm holding on the 600 grit sanding until the whole outside is planked. All the gunports have been squared up per the drawings. So far, so good in my estimation but it can be better. I'll turn her and do the "not the wall side" and see if I can improve. I'll probably revisit some of this side after the other side. I'm re-thinking my main wales. Only the top one will be ebony, the rest are blended in to it and the regular planks so I'll go with the swiiss pear and leave it natural for that. At least the ebony that's there will help set the tone for the sheer. A darn sight easier to work with.
Grant, Have a great trip. Send pics occasionally. I'll get some of the powder monkeys to clean up the popcorn mess and get the chairs put back into place.
Hi Jim, I'm a fan of the "little known" ships. Your Lacawanna is looking great and I love that finish on the hull.
- 116 replies
- finished
- Lackawanna
The hardest puzzle I ever saw only had 500 pieces. It was pure white except for a dot in the upper right hand corner. It irritated me no end that when I was done, it was upside down.
- 1,038 replies
- King of the Mississippi
- Artesania Latina
