mtaylor
Moderators
Everything posted by mtaylor
  1. Forgive me for rabble-rousing.... only 90 more Sjors. I'll be quiet and go start building an Admiral's table.
  2. Doh... I guess I read too much into this... apologies.
  3. Roman, You've added fuel to the speculative fires.... I think what you say is true for 1755. As some point, Licorne went through a major repair/rebuild. The plans for her capture in 1778 show as I've described. Just another one of things that make you say: "What the....????"
  4. Oh... !!!! I see. A spacer might work with gunports cut into it, much like the many of the kits come with. I fear you may need more frames otherwise when fairing, they'll go every which way. I'll have to think about this....
  5. Very crisp and clean and I love the way the wood colors blend and accentuate. Beautiful.
  6. You're Wasa is looking most excellent. I like the wood tones and little touches that give it that "scratch look".
  7. Michael, Let's see if I can help with the picture issues.... First load the pictures using "Choose Files". Then, put your curser where you want the picture. (#1) Then click "Add to post". (#2) If you don't they can end up being rather random. You can do this up to the maximum limit per post (which I think is 10). Or maybe it's per "upload"... I'm not 100% sure as it's been a long time since I uploaded a pile of pictures.
  8. Beautiful stern work, Matti. I'm sure your galleries will come out just as nice.
  9. Chris, You could be right on the time frame... especially if converting le Commerce de Marselle into L'Orient. Is that even possible? Or will you end up reworking the plans completely? Hmm.. daunting and fascinating at the same time. BTW, I'm hoping you'll build L'Orient as she was before the Battle of the Nile and not afterwards. Though I suppose an interesting diorama could be done of that.
  10. So you're using bulkheads instead of frames? Post a pic and lets get a look at the problem.
  11. Roman and Joss, Interesting discussion on the gunport/position placement. The rule may not have hard and fast for the French as well... On Licorne, quarterdeck guns are placed between the ports on the gun deck. On the foredeck, however, they are directly over the bridle port. I've done a quick search on other sites and it seems the rule was applied but in the case of Licorne, it wasn't. Interesting to say the least which makes me think the bridle port may have empty.
  12. Spencer, I'm not sure I understand the "cut them apart" thing. The spacers would secure the frames to each other. Here's mine: The spacers at the top and bottom held the frames rigid. I could then add the sills which also give some rigidity.
  13. Great looking crew Frank. Though I must admit, they seem to be doing some sort of disco dancing...?..!!! I just assuming that they are a happy lot to have a good Captain and a fine ship.
  14. Looks like you're getting close to the finish line. Looking great with the lights. And without the lights.
  15. Chris, Sweet work on the cheeks and trailboards. Been shopping at Ancre', I see. Impressive. Only two builds for the rest of your life????? I have faith that you'll get more than two done.
  16. Spencer, Use spacers as Hahn did. A bit of scrap wood above and below the gunport (between the frames) does wonders.
  17. Augie, The "safety timbers" are an excellent idea. So one more sub-deck and then hull planking?
  18. If it's not one thing (raccoons), it's another (blizzard). I guess you'll be making a visit to Gnomes-R-Us??
  19. Robbyn Augie and Robert have the only two viable ways of fixing this from the way you describe it. For drilling metal.. you need to "dimple" it with punch to keep the bit from wandering. Installed on a mast, the dimpling is almost impossible without breaking the mast. If you decide to try the JB Weld, dimple it with a nail point before it hardens. And definitely follow the instructions on surface prep and application. I've used the stuff on engine blocks and it works great if the instructions are followed. If they aren't... well, it wasn't a pretty sight.
  20. Ah...planking has started and looking good. Yeah, I know it's a sub-deck but ya' gotta' start someplace.
  21. Can you point us to a link to see specifically what you're talking about? I'm with Sam but it's possible you're seeing something else.
