Everything posted by mtaylor
Beautiful, Mike. The display really shows it off nicely.
- 55 replies
- 18th century longboat
- model shipways
Very nicely done, Robbyn. I guess your not a real fan of painting?
- 234 replies
- model shipways
Well.... Wayne, you brought up nuts.. see where it leads? To the guys in white coats. I'm expecting white coats to lead us somewhere.. goats? White paint? White flags? Who knows. Meantime, I think I'll drink my coffee and lay low below the radar until this settles out.
- 1,873 replies
- occre
- san ildefonso
Thanks everyone. Aldo, Several ways of doing the whelps... use a solid block of wood and cut the whelps to shape then slice them apart. What I did was put in the timbers and then spun the whole thing on the lathe and shape it. Walt, I think only heat might work for epoxy. You might ask this in the Wood Tips and Tricks section. Popeye pointed out a great resource for capstan operation. Dafi's build is great for his exploring not only how things were made, but how they were used.
Gripos-kaiki by Giorgos - FINISHED
mtaylor replied to Giorgos's topic in - Build logs for subjects built 1851 - 1900
Giorgos, Thanks for sharing your beautiful build with us. I hope you'll share your next one also. -
Microlux Tilt Arbor Saw Problems
mtaylor replied to capnharv2's topic in Modeling tools and Workshop Equipment
Bruce, I think most of us are headed to Byrnes. With me, I'm just cheap.... er... frugal. When my saw dies, I'll upgrade. Meantime, I'll just keep plugging away with what I have. -
I think that was "not me" who mentioned nuts somewhere else... I'm fond of popcorn and beer. Oh.. and more importantly.. coffee!!!
- 1,873 replies
- occre
- san ildefonso
- 122 replies
- finished
- artesania latina
John, Be cautionous with this crew. Old saying: he who stirs the pot gets splattered. Or is that "their plane gets splattered..?" No matter, I'm going back to making little pieces of wood from bigger pieces of wood.
- 2,250 replies
- model shipways
- Charles W Morgan
Nicely repainted, Sjors. I'm having to think a lot about this... peanuts, padded rooms, doctors, buses and then there's ships that go both ways. I know it's Monday but....
- 1,873 replies
- occre
- san ildefonso
Looks fantastic, Grant. I think Andy is right.. make it a separate model.. Man, that is good work.
John, That's a sweet plane. Now don't go tempting Augie because he's got rigging to do.
- 2,250 replies
- model shipways
- Charles W Morgan
Buck, It's the weekend, let's both have one.
- 515 replies
- artesania latina
- whaleboat
Augie, At least you know it was a D-something.....
- 2,250 replies
- model shipways
- Charles W Morgan
Bill, If you'll go here: http://modelshipworldforum.com/ship-model-rigging-and-sails.php there's an article on making sails. He talks about materials to use and also how to furl them. Even though it's basically for a square-rigs, the same principle applies to yours.
Let's not call it laziness... I'm doing 1:64 and I'll not be treenailing. The planks are only 1/8" (about 4mm) wide and that's a tad small for these eyes. Then on top of it, they should be almost invisible anyway as a plug of the same wood used for decking was used to put in the hole.. Not worth the aggrevation, in my opinion.
Harvey, I was stripping off 1/8" planks off 1/16" in walnut stock and I ran into this a couple times today with the 168 tooth blade. It seems the feed speed is what does it. Too fast and the motor "bucked" and tried to kick the wood back. I suspect it's sawdust build up. New blade and freshly waxed.... So, I grabbed piece of boxwood and piece of cherry. Too fast on the feed speed and it bucks. I'm not feeding painfully slow, but the feed speed needs to be less than the 80-tooth blade. -
Bracera (Brazzera) by Albuk
mtaylor replied to Albuk's topic in - Kit build logs for subjects built from 1851 - 1900
You're doing a great job on a seldom built model, Alex. I think it's the first one of these for MSW. Beautiful planking. I like the various shades of the planks. The cargo hold is a neat idea and your pump came out very crisp and clean. -
John, You're making fast and excellent progress with this. Keep it up and you'll be finished before you can even load into the RV.
- 2,250 replies
- model shipways
- Charles W Morgan
NIce deck, Kevin. Did you caulk and treenail it? Good practice for the model, you know. <ducks><runs>
- 1,319 replies
- caldercraft
- Victory
