mtaylor
Moderators
Everything posted by mtaylor
  1. And even with wood ships, many of us are still there. Think "detailing the lower deck".... Yep....I'm still there and doing it.
  2. Welcome to MSW, Rod from another west coaster. I've spent a fair amount of time in SoCal starting when I was in the Marines. A long pause after the Marines until I moved to Oregon about 20 years ago.
  3. I didin't realize until recently that this was your first model. Not even a kit under your belt. Pretty darn amazing by any stretch.
  4. Welcome to MSW, Robert. When you're ready, start a build log as it's a great way to meet others and find help/support on your project. As for planking... go to the top of any page and you'll see near the right of the link bar "More". There's not only Chuck's method but a folder for PDF's with other methods. All are similar but have some different methods. It should give you some help on planking.
  5. Do start a build log, Mary. All our first efforts are not masterpieces but a learning experience. No one will laugh or yell at you.
  6. Not boring here. Just stop carrying it outside is my advice. Don't want to see this one broken.
  7. Cat, I suggest you open a log of your own as it's a great way to get help, meet others, and also help out other builders doing the same model. Also, do an introduction in the Introduction area.. Welcome to MSW.
  8. That all great news and work, Pat. I'm glad you got back into the shop.
  9. Try an antihistomine then. But then, I don't know what your hedgerows are made of. If real plants, it's possible.
  10. Welcome to MSW, Steve. I'm looking forward to what you decide for a project.
  11. No worries on the models, OC, but some worries about you. I hope you can stay on top of this along with the docs. The hedgerow area is looking good and well used. BTW, you're not having an allergic reaction to the grass, etc. on the model are you?
  12. Beautiful recovery, Edward. No one would ever know she did a floor bounce.
  13. Looks good, Christian. Did you decide on doing a color on the guns or are you going to let them age naturally?
  14. I've tried it both ways and end up preferring a blackening solution. My prep is/was the same for both.... acetone soak first to remove any chemicals from the surface and let dry. Second, a vinegar soak to give it some "tooth" followed by distilled water to remove the vinegar. I did prime (spray can) and then brush painted the test pieces. Maybe an air brush would work better but in handling using tweezers, the paint came off where I held them. With the blackening, no damage. About the same amount of time for prep but the time for painting taking longer per batch. I was using Vellejo paints and "fine" spray primer as I found black spray paint was too thick/coarse in addition to the paint coming off during handling. Boils down to your choice and preference. Others have reported better results using an air brush and/or had issues with the blackening. Test both methods and see which works best for you.
  15. I have no idea about your questions but a question for you and others... about motor interference. Would lining the motor compartment with say aluminum foil and having a small "finger" through the hull and into the water ground the static? You'd probably need as capacitor on the power feed I'd think. Or maybe just the capacitor would do the trick and filter out the static.
  16. Don't sweat posting on supply/supplier issues. I'm sure others will appreciate the heads up. When I did my CH-53 I ran into a similar issue.
  17. That's the way I do it on decks. I should have clarified that I start inboard on each side and work my way outboard. Sorry for the confusion.
  18. You'll need to be a bit more specific I think. Maybe photo or two along with what info you need.
  19. There's no need to put glue on the whole plank. Put a drop on each bulkhead/frame /beam at the spot you want the plank. Install plank and clamp into place. As others point out, it prevents a lot of problems doing one plank at a time. Given the nature of PVA, one can glue down a plank on the starboard side and then work on one on the port side. Back and forth and you'll get a rhythm for the process.
  20. I laughed but this is a truism of one of the modeler's skills.
  21. That's good news on the printer doing what it needs to do. Test prints look great. Once upon a time, manuals with parts breakdowns, etc. were all line drawings and distorted dimensionally so if a manual fell into unfriendly hands, they would have a tough time duplicating parts. I'm not sure if this bird falls into that category though.
