Hello,
I will continue at the French corvette with the installation of the anchor supports on the larboard side. The anchor was initially placed only temporarily, to see if it fits.
Here I show you two photos:
Allways a pleasure to see your updates, Johann! Lovely metal work!
Alex
Current build: HMS Sphynx, 20 gun ship launched in 1775 at Portsmouth, Hampshire.
On the drawing board: HMS Anson, 64 gun third rate ship of the line, launched in 1781 at Plymouth
Wunderbar !
Nils
Current builds
-Lightship Elbe 1
Completed
Hello,
many thanks für the nice comments.
In between, I will still show you how the portholes of the ventilation hatches are constructed.
The glass body with a diameter of 1.3 mm were punched out with a specially prepared punch pliers from an acrylic glass plate.
Then they were glued with Micro Kristal Klear in a brass tube piece.
The brass tube piece has an outside diameter of 2.5 mm.
See you soon ..
Outstanding build Johann B) Your fastidiously clean metalwork really brings the model to life :wub:
Kind Regards
Nigel
Currently working on Royal Caroline
Hello,
your positive comments are always pleased me.
With other fittings on the outboard walls I want to continue my report.
In addition to various eye bolts with rings were also fittings to customize for the fore-channels.
One of these fittings is used to hook the lower-studding-sail-boom.
The other is for the mooring of the flying-jib-guys.
I hope you enjoy the pictures.
Edited by archjofo
Super metal work Johann,
Three out of five of those rivets in row are dummies, what are you using as dummy rivet heads ?
Nils
Current builds
-Lightship Elbe 1
Completed
Hello Nils,
thanks for your nice comment.
There are ordinary micro brass rivets. These were soldered and sanded down.
This has the following reason:
For mounting two bolts are completely sufficient.
Otherwise the installation would be too problematic.
Hello Friends,
today I show some news of my little naval shipyards.
In the quarter galleries were still glued the window. The tiny windows were made ​​of acrylic glass. I have fixed this with Micro Kristal Klear.
As a consequence I had to install wooden strips on the quarter galleries yet. These are just decoration.
Soon it continues here again.
Edited by archjofo
Johann,
This is an amazing build you have going.   I am surprised though that the quarter gallery only had one small window.
Hello colleagues,
thank you for your encouragement.
Lately, I was not very productive. To this end, my scanty results:
Various works: boarding ladders port side, eye bolts with rings for the deck and inboard.
On the port side still had to be mounted the boarding ladders. This I had made ​​some time ago and given to appropriate explanations.
For the open battery deck I made still eye bolts with rings, as well inboard of the gun ports, a total of 60 pieces. Also here is to note again that these differ in the size of the eye bolt on the outboard side.
To be continued ...
Edited by archjofo
As we say in the Netherlands: 'The bow can't be strung all the time', after all it's not a race. You still managed to show us some nice new details
Carl
Hello,
thanks for the nice comments.
Another small detail has been made ​​for the French corvette.
It is a roller on the Main deck .
This is fixed in front of the main mast on the open Main deck .
The making of this steering roller (height approx. 8 mm) was performed in three parts, which I turned on my little lathe. The roller was made of brass.
For what purpose this roller was used precisely, is what I can only guess.
Because it is in the context with the guide rollers (tourniquet), I see a connection there with the messenger.
I also hope on the expertise of one or the other on the forum that explain this more detailed
To be continued ...
Astonishing those details!
Carl
The quality and attention to detail with all your metal work is simply outstanding Johann!!
Kind Regards
Nigel
Wunderbar!!!
Carl
Kind Regards
Nigel
Hello Johann,
NMBROOK schreibt meine Meinung.
Kar   l :10_1_10:
Johann your complete work is outstanding but your metal work is out of this world :) Thanks for sharing and keep on! Regards :)
Current build: LA MARTEGAOU
Past build:
BRACERA
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do... Sail away from the safe harbor. Catch the tradewinds in your sails. Explore. Dream. Discover"
KIND REGARDS!
ELMIR
Hello,
I have to correct a statement.
This piece of equipment is not a stearing roller
(reel ). Meanwhile, I know that this is a chain-pipe. This part is used for the anchor chain, to let down into the chain locker.
Hello,
it has been some time since my last update to my building report.
So I made in the meantime other small but important details. So the timberheads received post covers in roof form.
Another detail to protect the hull from the anchor flukes was added.
Here you can see some pictures.
I hope that you like it,
Johann,
Ausgezeichnet, wunderbar. Some stunning looking detail you've produced. It renders me speechless ...
Carl
Your detail work is just stunning Johann. It never fails to bring a smile to my face. :)
