Some last minute stunning details ... Looks really marvelous.
Carl
Hello,
I am very pleased with your positive comments.
Here it continues in the report with a small update
Breeching rope for the 18 - pounder
The four 18 - pounders of La Créole have meantime been provided with the latest fittings. The next step is to prepare the breeching rope.
The breeching rope of 18 - pounder had a length of 8.20 m and a diameter of 55 mm.
The attachment of the breeching rope inboard on the bulwark was performed using eyebolts that penetrated the hull in the original and outboard with a screw (yellow arrow) were countered.
Amazing detail! Looks like the real thing!
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
@JesseLee
Thank you for the nice comment.
Here's another attempt to make the lashings with a brighter yarn. So it seems so that it works better with the brighter yarn.
Bye for now ...
Edited by archjofo
Hello,
currently I am working with the production of the gun tackle.
Here are a few pictures of the components and a finished gun tackle.
Next I will show you the gun tackle how it will look on the model.
The detail and shape of the hook is impressive (as everything else.....)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Hello Johann,
I can only say, thanks so much for sharing your top notch art in historical shipmodel-building. Your build log ia a treat for the Viewers eyes....
Wunderbare Arbeit !
Nils
Current builds
-Lightship Elbe 1
Completed
Very nice! What wood are you using for this?
Equip the blocks with sheaves poses a particular challenge.
So I tried it.
Whether it is visible after the pull through of the rope, who knows?
The sheaves have a diameter of 2.5 mm and a thickness of 0.45 mm.
Sheaves made with a lathe? How do keep from loosing them when you 'slice them off' the rod?
Carl
A good way Carl is to use a thin wire in the tailstock and as the parts part off the main bar they slide away from the chuck.
Michael
Life like ... Increadible craftmanship
Carl
WOW!! I have never seen so much detail in such a small block!
Hello,
thank you very much for your nice comments.
The hooks so far prepared are not optimized in shape.
The original hooks were forged from iron. They had thickened and dilutions. The shape is very special, as can be seen in the next picture.
Therefore, I have my previous manufacturing method refined.
On the next screen, the procedure is shown in 7 steps.
Johann,
This is truly a mastery of the metalwork.
Johann, it's a joy to watch your work. Outstanding craftsmanship
I'll try your method for the hooks, they look superb.
Remco
Hello,
I am very glad for your positive comments, thank you for that.
So here are all the hooks before they are blackened.
The next picture illustrates a comparison between the 1st version 2 and version
of the block with hook.
That second version does look like you can hang a ship's boat with it. The first one is really fragile ... It is an enormous improvement not to say the least!!!
Carl
Johann,
hooks and appropriate block tackles are super,
well done
Nils
Current builds
-Lightship Elbe 1
Completed
Hello,
thanks for the nice comments.
It is a great pleasure again and again.
Here I show you how I make the blocks for the 18 pounder.
For this I use a primitive holding device so that I can bring each block with a file in form.
Your work is absolutely amazing!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Continuation: Rigging the 18-pounder
All components for rigging of the four 18-pounder guns of La Créole were completed.
You can see the double and single blocks of Seitentaljen, the eyebolt and the hooks on the inside are attached to the bulwark and the block hook, for hooking the tackles on gun and the bulwark.
Until next time ...
Edited by archjofo
