Everyone else has said what I would have said...  so I'll just applaud.   post-76-0-59032400-1463104439.gifpost-76-0-59032400-1463104439.gifpost-76-0-59032400-1463104439.gif
Wunderherrlich! Marveilleux!
XXXDAn
Edited by dafi
Many thanks to Gerhard, Grant, Patrick John, Mark, Daniel,
and all the "likes"
for those much appreciated and kind comments.....,
I`ll be looking to rig the foremast and it`s shrouds next
Nils
Current builds
-Lightship Elbe 1
Completed
Update
cleats on forecastle deck edge, mounting of spare anchor,  and fastening of five turnbuckle screws per side,  for the shrouds (M1 threads, left / right) and foremast backstays
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi Nils
Absolutely brilliant work. I think the only thing separating your ship from the real ship are some crew members, salt-spray and a few streaks of rust here and there.
At the rate you're going, she's going to be finished in no time.
Cheers
Patrick
Edited by Omega1234
thanks Patrick,
good idea with the salt spray and streaks of rust, I may take it up later on......, for crew and passengers it`s not so easy with the suitable scale, but I`ve been gathering typical "turn of the century" passengers and crew members, for sailors and officers I recently found some nice figures in scale 1:144 from North Star Models
Nils
Current builds
-Lightship Elbe 1
Completed
Spectacular work Nils.
Bob
Thank you very much Bob
for your nice comment Bob, there is a little walk bridge that connects the promenade deck with the forecastle deck. I trust its better that this  that would have to go on first, otherwise there is no sufficiant access for mountung it, when the shrouds are in the way
Nils
Current builds
-Lightship Elbe 1
Completed
She's nearing the moment to slide of the building slip, Nils. Marvelous work on all those details
Cheers
Thanks for your nice words Carl,
about 2/3 of the remaining ship are by far not at this degree of progress yet......
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Martin,
as already mentioned to Bob, there will be a walkbridge between promenade- and forecastle deck. As far as I know this could be used by passengers and crew to move around.....
In some pics (Norway Heritage, for KWdG) it shows this bridge in simple gangway character, so I`m not sure if not perhaps this position was only the resting place for the ships own gangway during travel.....
Nils
this pic found and  borrowed from the web....
width 6 mm, railing hight 8 mm
telescope support for adjusting the correct hight
Current builds
-Lightship Elbe 1
Completed
Steve,
thanks very much for your nice compliment...
Nils
Current builds
-Lightship Elbe 1
Completed
Vielen Dank Johann,
much appreciated....
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for your nice compliment Ed,
Nils
Current builds
-Lightship Elbe 1
Completed
Fantastic work Nils!!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Nils, I am wondering if you own a resistance soldering machine.  That would make doing some those assemblies much easier.  Do you plan on painting  that walkway and how do you prep it?
David B
Edited by dgbot
Nils,
I remember that quite a lot of finishing work is done whilst afloat ... Though I presume you are not ging to copy that building location ...
Cheers
Carl
Hi David,
no resistance soldering involved. Soldering done by means of mini gastorch and soldering iron. For preparation pls. ref. to scetch.... All will be primered and painted....
Nils
Current builds
-Lightship Elbe 1
Completed
thank you so much for your nice compliment Lawrence,
during checking out  the run of the shrouds and backstays with preliminary sewing thread, I just noticed that there should be 6 turnbuckle screws (instead of 5) on each side, so warm up the blackening acid once again....
Nils
Current builds
-Lightship Elbe 1
Completed
Nils,
Cheers
Thank you Carl,
you`re right with the fitting out alongside the fitting out quay, but most of that would have been the luxurious fitting out and furnishing of the saloons, which I can skip......
Nils
Current builds
-Lightship Elbe 1
Completed
Update
starting foremast ratlines, determining the line thicknesses....
Nils
this gallows is just a little dummy setup to determine the line thicknesses
the shrouds and backstays are from flexibel 7-fold galvanized steel  chord with a total thicknes of 0,3 mm diam.
(normaly used for wire controlled model aircraft)
the turnbuckle srews are the smallest I could find ( M1 left / right thread)
the upper shroud distances are given by the 4 slots in the top`s spreader
the slotrings for deck fastening are soldered at the joint, in order to prevent opening
the ratlines thickness is chosen to 0,2 mm thread in scale (the actual would be ( 144 x 0,2 = 28, 8 mm diam.)
Current builds
-Lightship Elbe 1
Completed
Hi Carl,
the shrouds and backstays are from flexibel 7-fold zinc-galvanized steel  chord with a total thicknes of 0,3 mm diam.
(normaly used for wire controlled model aircraft). After some weeks they get a bit darker when they oxidize. The ratlines are polyester thread
Nils
Current builds
-Lightship Elbe 1
Completed
