I glued on the friezes.  Keeping the friezes from sticking to the wrong things while applying them was a bit tricky, but I manged to pull it off.  I'm following Mike's (Stuntflyer) lead and keeping the painting to a minimum.  I chose not to apply any white trim paint.  As a newby, I want as much wood showing as possible!
Erik
I glued in the floorboards.  I used pieces of .030" stryene as temporary spacers between the boards as I was gluing them in so they would be a uniform distance from one another.  Also, now that I'm working on the interior, I'm using the build board I had made. :)
Erik
A couple of quick shots of the two platforms.  I wasn't comfortable gluing the edges of the boards.  I didn't want to have glue smudges before I stain/poly.  I used left over .020" planking material along the bottoms and glued the boards to them.  This also reinforces the platforms to keep them flat when I stain/poly.  A considerable amount of sanding was necessary to get the bow platform to snug down low enough in the hull.
Erik
Erik, that's the way I did the platforms. Looking real good.
Respectfully
I just went through your log Erik. You are doing a great job on a difficult orohect,. Leaving the hull natural is showing off your skills niceky.
David B
I love how that looks.
One last photo for a while (I'm heading to Wales and western England for vacation for a couple of weeks :) ).  I attached the risers.  I made jigs out of styrene to make sure the height was uniform for the entire length of the riser.  I glued the riser to 5 or 6 frames at a time with PVA, holding the jig in place above, so had time to adjust it, and then moved on to the next section.
The photo isn't that great.  the bright halogen light I use for photographs makes the riser's finish look splotchy, it's not in person.  I scribed fairly deep grooves in both risers.  But they disappeared when I soaked the riser in water to get the edge bend at the bow!  I am annoyed, but not worried that it will detract from the overall look.  I've tested the stain/WOP on a scribed thwart and it holds the scribe fine.
Erik
Erik,
that looks very nice and don't bother about the splotchies. I have a hard time to detect them.
As for the varnish, I have an ample collection of Min-Wax varnishes that I have blended back and forth. And found the mixtures that I like.
It's all in the builder eyes and perspective how a model will turn out.
Don't be disgourage - it will be amazing!
Chuck got me back on the right track!
Respectfully
I'm back from my trip to Wales and England, and back working on the longboat.  I've added the curved piece attached to the cap rail at the bow, the front part of the locker at the stern, and the thwarts (not including the one the mast will go in).
Erik
Beautiful work Erik :) .
:cheers:  Danny
Cheers, Danny
Wow Erik,
Seems like we are at the same point in our builds.
Very inspiring.
Your longboat looks very nice.
Respectfully
Hello Erik,just saw your build log. Your work is very sharp and clean,great painting job also!! :) :)  I will follow with interest.
Kind Regards
Dimitris
Current Build: Amerigo Vespucci -Mantua- 1:100 scale
Completed Build logs: Bluenose II AL 1:75 scale
Gallery: Bluenose II AL 1:75 scale
Future Build: Royal Caroline -Panart- 1:47 scale
I finished the thwart that the mast will be attached to.  The brass work was more difficult than I expected.  The material is soft and noodley.  :)  At any rate, I think it came out well.  I was able to match the paint on the belaying pins to the wood color pretty decently.
Erik
Erik,
that mast thwart including the "brass fitting" looks extremely nice.
Did you oxidized the brass or painted it?
Very good job!
Edited by Nirvana
Respectfully
Thanks for the kind words!  I painted the brass black after I shaped it, but before I glued it on.  I touched it up after the parts were attached.  I had blackened the lift rings when I added them the other day.  The blackening seemed easy to rub off, so I figure with the parts that will be handled more when attaching, I'll use black paint.
Erik
Looking great... every bit added it making better and better.
Looking good Erik :) .
After that . . . there's no more procrastinating doing the windlass.
Fun bit :D .
:cheers:  Danny
Cheers, Danny
Erik, your Longboat is really shaping up.  Now comes the fun part.  I will be going through your log when I start mine and pray I do as well as you.
David B
Edited by dgbot
