Ah... no problem guys... we have a topic for that with our resident doc...  http://modelshipworld.com/index.php/topic/474-therapy-for-shipaholics/  :D  :D  :D
All kit suppliers should use that dowel system, for the reasons you stated, cost would be negligible.
Need to take a closer look at this supplier.
Stone ground mustard.
John
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
That dowel system is very clever.  Probably a foolproof way to make sure the bulkheads are aligned and vertically and square to the keel.  Very interesting!
Great to see manufacturers thinking outside the box so to speak and coming up with better ways of doing things.  A lot of thought seems to be going into the MarisStella kits to make them better for builders - novice and pro alike.  It's a pain in the *posterior* to get everything square on some kits, when in today's world with laser cutting precision, you wouldn't think this would be an issue.
Edited by Landlubber Mike
Hi Don,
I like the dowel idea. That's an interesting, and simple, solution. Most 3D programs will allow this sort of hole through the entire assembly.
Who do you think will be first to develop angled bulkheads in the bow and stern, like with proper plank on frame structures?
Best Regards,
Rick
Rick Shousha
Montreal
Wow, that is real good news. Not so surprising though as these kits are awesome. Will be looking forward to seeing more on this
Edited by donrobinson
  • 5 months later...
Hello All, Thanks for your comments, likes and for stopping by
 This is Barque Stefano week for me so I will show you some progress from this morning
Today was bow and stern filler blocks, the kit supplies these in a block that is partially laser cut I finished cutting mine with my scroll saw. The stern filler block requires you to glue three 20 mm thick pieces together, then shape accordingly. The top of the filler block rises to the stern to allow for the planking or madiere, this rise is approx. 7-8 mm. This should be done first, the next profile can then be made by measuring down approx 20 mm from this edge. The last profile is made by tracing the outline of the last bulkhead from the fore side.
Blocks cut from blank
Showing the rise of filler block and how planking will fit
Showing the formed blocks, the red marker is just added to better see the lines
Stern block attached
The bow blocks are much easier to make and follow the same principle, marking the profile lines and shaping
post-20628-0-00547000-1484071242_thumb.jpgpost-20628-0-58643200-1484071264_thumb.jpgpost-20628-0-53452800-1484071290_thumb.jpgpost-20628-0-10389000-1484071311_thumb.jpg
This last picture is just to show the lines of the hull, started to fair the starboard side to show how things should meet up. Still required are two small pieces of filler on either side of bow, then start fairing tomorrow. Ignore gap on starboard side, that was fixed. Tools used were belt/disc sander, dremel and sandpaper.
Have a Good Day
Thanks Mike, it is a good system. If you could handle it to see how solid it is you would really be impressed. Come on over sometime and check it out. ;)  :)
Thanks for stopping Bob, I probably wouldn't use "better", crazy may be more applicable. She is a wonderful kit and full of surprises, the quality of the contents are exceptional and the plans are second to none. If you happen to like sails, there are 34 I believe including stunning sails. Both the fore and main mast have two full pages of plans just showing rigging and sails, on these plans there is also bow up sections showing the trestle trees and all the blocking which is really going to help. If I get time I will post some pictures of these.
I would be more than happy to put a hold on mine and follow you and your build ;)  :P  :P
Here are some of the plans, first one is an overall, second one showing how to build masts and spars and the last two are all about the rigging these are just for the foremast. The plans are all scale size so any measurement can be accurately taken off of them , I believe they are 35" x 50" and there is 14 of them. The main mast has three dedicated sheets and the mizzen has one. One sheet is all about the sails and the rest are the construction of hull and various items required. The instruction book is 36 pages which may seem small but with all the information you need on the plans the instruction book is more than adequate. It does an excellent job of outlining the various steps and is easy to follow.
I'd probably have to bring a parka and thermal underwear this time of year? :)
Wow, those plans look beautiful.  Lots of detail there.
Yep Mike lots of warm clothes would be a good idea. I have been running to and from my garage today  in a pair of shorts and it's -23 C. It is, although only about 20 m. from my house and garage is heated :)
 The plans are really something, they don't miss a thing it's just a matter of sitting down and looking at them. A problem I seem to still have :P
It might be entertaining to see GoPro video of Don racing back and forth to his garage at -23C.  LOL
Can't believe I missed this build log.  Every time I turn around it seems like you have a new model in the works!!!  My new shop should be done in about 3 weeks.  I am eager to get back to the workbench!!!
Edited by mrshanks
Mike Shanks
Don, nice to see you back on this beautiful ship. I feel badly for your -23 degree C weather...so badly...smiley faces.
In Maui, Ian
Thanks for stopping Ian, hope you are enjoying all that heat and sunshine
joined! you had me at the dowels.
this looks like a great kit.
Edited by JPAM
Thanks for dropping in JPAM, I am just starting the planking now and should have some updates soon
Hello All, Thanks for stopping and for your likes and comments.
 Well a week has gone by and I don't have that much to show, For some reason I thought I would have had lots more to show, but I have started on the planking and all is going smooth. At this stage Stefano is 810 mm long so I suppose this is maybe why it is going slower than I thought. No matter there is no rush. The transom has proven to be a little bit of a hair puller outer but fortunately with my already thinning hair there was not much to grab onto and all worked out
The first row of planking installed at top of bulkheads, no tapering done on this strake. The bulkhead extensions are to be removed later on, therefore there is little glue applied to these points of contact with the planks. It is necessary then to pay special attention while installing the first four strakes and be sure there is adequate glue applied to their edges and proper clamping is applied.
post-20628-0-65790500-1484605891_thumb.jpgpost-20628-0-56624300-1484605916_thumb.jpgpost-20628-0-25672600-1484605936_thumb.jpg
The new shipyard aka dining room
post-20628-0-84041800-1484605956_thumb.jpgpost-20628-0-00895000-1484605980_thumb.jpgpost-20628-0-89699600-1484606004_thumb.jpgpost-20628-0-89241600-1484606030_thumb.jpgpost-20628-0-88217100-1484606056_thumb.jpgpost-20628-0-91441800-1484606077_thumb.jpg
And here Stefano is beside the Pegasus, the Pegasus is 500 mm in this picture 310 mm shorter than the Stefano. Pegasus is 1:64 and the Stefano is 1:63
 This week is the Trabaccolo,
See You All Later
Thanks Zoltan, It's been crossing my mind if the first layer turns out good enough I may skip the second layer as it is all copper plates and painted. We'll see.
Thanks Bob. The finished ship is 1.12 m. when finished so it will take up some shelf space!!
Thanks Pierre, you are right about the shelf but being there is no admiral at the present time all decorating is at my discretion and I have lots of empty walls and space  :P  :)  ;)
Hi Don,
Just found your build so I'll take my seat in the back row to see "how it's done"
Doug
Edited by Heronguy
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Thanks Mike, so far it has been lots of fun. Still pretty early though :huh:  ;)
Welcome aboard Doug always room for more. Back row is actually real close to the refreshment fridge, good choice in seating :P  :)
