Thaks for the nice comments. Making this figurehead was so much fun that I finished it first.
First an idea of what i should become
Wings in pencil
Wings carved
IMG_20200413_153641.thumb.jpg.f52cab4ea847386a4c57864a30e05390.jpgfeathers carved and start loosening the piece of wood
Need plastic surgery (CA glue)
carving ready
IMG_20200413_183538.thumb.jpg.1a4bc0dbedcfc02535d2de9e58182d7b.jpgIMG_20200413_183552.thumb.jpg.e694b0f0b6c9711328389646f6f56e93.jpg
a base coat of white
painting in progress
painting ready and dry fitted
used tools and paint
the figurehead is not yet glued on. There is still too much chance to damage it during the further build
Thanks for folowing, likes and comments
NIce indeed Patrick - looks like a  perfect 16th Century art work.
I will also attempt a first dragon head carving for my Viking project coming up - New learning for both of us -- very nice first attempt  :imNotWorthy:
Edited by md1400cs
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Nice work on the figurehead, Patrick.
Most of my time the last few weeks has gone to installing a new laptop.
The old laptop hadn't survived a fatal upgrade to windows 10.
And considering I'm no IT specialist , complete installation of the new laptop takes a while ...
Building the staghorns
The staghors were first completed and then glued on the model.
In total there are 10
4 at the waist
4 on the half deck
2 at the fore castle (to be placed later)
The places where they are provided are based on these drawings.
Building staghorns
first glued on a plank
IMG_20200408_191605.thumb.jpg.052c72c4607a021bf4509df07a0e19c3.jpgIMG_20200409_182452.thumb.jpg.96f39ccba0df9dcaea867280f4656b77.jpg
after drying cut loose
IMG_20200409_182548.thumb.jpg.c117d24872424b78a1e497710ce741b9.jpgIMG_20200411_163017.thumb.jpg.a59fcd7a60fa0316eae703002a969c05.jpgIMG_20200419_154834.thumb.jpg.2f4f96115dce200b8569bcc3ae0ab7af.jpgIMG_20200419_154846.thumb.jpg.0f776561c88b4340d9cc884b6adcf287.jpgIMG_20200422_193430.thumb.jpg.a3681eb7c8fb448cdf9c6c543dc524a9.jpg
Meanwhile, the construction of 2 pumps has started.
Again many questions. On which deck, how much and where do I place them.
Which deck?  The deck below this deck is expected to drain  water to the hold. Therefore, the pumps are on this deck at the waist / rear castle.
How much ?   Probably 1 or 2. Because we anticipate a long unknown journey. This Pelican gets 2.
Where? Normally behind the main mast close to the center of the deck.
The pumpshafts should be (visible) on the lower deck.
But to be able to drill holes , I will have to remove part of the deck from the rear castle (small construction error :default_wallbash:).
These pumps will be glued to the deck later. If I place them now, they'll get in the way of the knighthead and I'll get in trouble later.
IMG_20200330_165625.thumb.jpg.965663f15ac499794e49fed3dd58eb5a.jpgIMG_20200330_193441.thumb.jpg.6e18fff3f923b020c74ef543078b9740.jpgIMG_20200419_154911.thumb.jpg.012b4c6e9f5882ded275da6047efc99c.jpgIMG_20200420_195749.thumb.jpg.4c56c88201d7b1d3646d4e27335ab11a.jpgIMG_20200422_182851.thumb.jpg.0da51ba9233f78bd296d91220ac2cfae.jpgIMG_20200423_200850.thumb.jpg.aee6540949e7336fb5eee1b72ceacfb7.jpg
Thanks for following, comments and likes
Even those need time to do so. It takes me nearly three days to have it up and running the wy I want and need it
Lovely pumps by the way
Carl
16 hours ago, G.L. said:
Those pumps worked very well, Patrick. They are perfectly round, and that without using a lathe!
They were rounded with a very poor man lathe (a knive, a file and sandpaper)
I should invest in some better material.  But ... space, space. no space left to install it
13 hours ago, flying_dutchman2 said:
Patrick,
I like your staghorns and especially the pumps.  I know that my Zeehaen needs a lot of the staghorns and a few of the pumps.
The staghors came from the Duyfken replica . The pumps are from the Batavia and Duyfken replica
It looks that on Windows 10 everything should work through paid micro$oft programs. That's my problem...
Ps,
Most things on the lapotop already work back (for free).
Edited by Backer
Finishing the pumps.
As said, the pumps of the Batavia and Duyfken replicas served as an example.
A hole is drilled in the centre of the pump. This is where the metal wire comes in that is attached to the pump arm
A plastic disc is glued to the base of each pump. Around the base is tissue paper glued with CA glue IMG_20200425_154503.thumb.jpg.9a9c06cc6619e4500c07f9bd102d2480.jpg
Pumps painted. The basis is a kind of seal between the pump and the deck (source Duyfken Replica)
IMG_20200425_192240.thumb.jpg.a178cc5f010e78304a6888c20ae551e3.jpgIMG_20200425_192256.thumb.jpg.8cf1788a15aca01989470c1e90c9c41d.jpg
Ther is no outlet  on the side of the pumps like on my "modern" pump.  Reason, they do not serve to pump clean water into a bucket. But to pump dirty water out of  the hold.
Pumps dry fitted in place.  2 options.
option 2
For the moment, i go for option 2
Edited by Backer
And a few weeks ago i sawed wood for masts and spars
IMG_20200404_164254.thumb.jpg.35e7a5e50ef51abf6b7abace284a7005.jpgIMG_20200425_194951.thumb.jpg.237a71bee03b9412bc450f9b47f0416a.jpg
Before i install the fore castle i have to decide where the shrouds of the fore mast come, and how much.
Some info about the lengts of mast early 17th centuryIMG_20200425_170731.thumb.jpg.8bde38c893dddc101a94554c7ee9e7c3.jpg
And it seems that the lower part of the main and fore masts are about the same height on level
The number of shrouds on the fore mast also varies a lot (between 3 and 6)
Determine mast length in relation to the deck. The fore mast is a little bit shorter than the main mast.
The angle to the deck also varied greatly. From right-angled to strongly bending forwardIMG_20200425_170832.thumb.jpg.6c56f7a27759e33db7f51eeee3deff15.jpg
5 is to much,  when we fire the cannon, we will do more damage to our own rigging than to the opponent.
4 is better, where one enters the ratlines (on the forecastle) the distance between the shrouds is already much narrower.
Thanks for following, likes and comments
All grooves for the shrouds are made.
A lot of work to determine the position of 8 grooves.
IMG_20200426_163621.thumb.jpg.af3862f615675ae0994002af119948a2.jpgIMG_20200426_163832.thumb.jpg.14d06acff223db0ee5ce9969ddf38d5a.jpgIMG_20200426_163647.thumb.jpg.ec49bb79fd341af4381017f6badee4c8.jpgIMG_20200502_114114.thumb.jpg.ae1f72e614644b24729c99c19f4fdf51.jpg
Reminders with the necessary dimensions
The fore castle
Especially on Spanish galleons, this, together with the rearcastle, was one of the most important defenses of the ship.
In function of boarding an enemy ship and defending one's own ship. Usually it was custom to give 1 salvo with the ship cannons and then board the enemy ship with the well equipped and trained Spanish foot soldiers.
The English began to develop a different strategy over time. Better placed cannons that fired several salvo's.
Different strategies.
The interior of the fore castle.  Since the cannons and most other items have already been made, this goes quite smoothly.
And first I make a layout of the deck (approximately).
IMG_20200501_123243.thumb.jpg.1cd212c0530fcf07732537533d018200.jpgIMG_20200501_123427.thumb.jpg.7d9086c87169a470388c5af8cdf217b0.jpgIMG_20200502_114006.thumb.jpg.491222bc681e0946d2ac78cd63989925.jpg
On some merchants the galley was sometimes placed in the fore castle . For hygiene reasons (even as early as the 16th century).
Because this is not a real warship, but more of a (heavily) armed merchant ship. There will be some kind of small cooking place in the forecastle.
source
IMG_20200427_160139.thumb.jpg.a41bab5401dc60d8397af21e159166e5.jpgIMG_20200427_160149.thumb.jpg.1573bec21c49d970847682ad59e5fabb.jpg
 Forgotten something on the beakhead (n°35)
Solved
Thanks for following and likes
Edited by Backer
Wonderful work (as always) Patrick, thanks for sharing as you introduce me in shipbuilding from the (end of)16th century.
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
A 16th century "cooking stove".
Only 2 things are maybe correct Made of bricks and it can be placed in the fore castle.
Everything else is my own guesswork.
A brick construction on a moving wooden ship, I think, should be reinforced with wood and or iron. Otherwise, the construction will not last long.
Plastic sheet is the material i use.
Making a brik wall
The base
Make a hole
"iron and bolts"
Neutral grey is base color. While still wet, dry brushing with red
While still wet, dry brushing with sand
Metal parts painted (2 buckets as a test)
traces of soot
ready to install  (2 buckets with extinguishing water)
IMG_20200503_161203.thumb.jpg.17de8d4af563d9ab8fd23205ffb20838.jpgIMG_20200503_161244.thumb.jpg.62c80025466d6f19c69392189411c965.jpg
ready for coocking
IMG_20200504_194624.thumb.jpg.4c1834a99cff699c09b98dc9eb34fa4c.jpgIMG_20200504_194919.thumb.jpg.c5b2c26b626d239c1aa3d995a1e0aa16.jpgIMG_20200504_194722.thumb.jpg.b78e263af057abc2fe53fc93f982438c.jpg
Removable grating will be installed above the kitchen.
Lovely stove!!, I think your interpretation would pass muster. Sterling  job sof far👍
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Patrick,
Your stove is as rkwz just mentioned - indeed it is.
PS: As you certainly know model train suppliers also have sheets and "what not" that simulate brick. No need to do all of that excellent prep work...
though possibly not to the scale that you needed. Oh  I assume even back then bricks were the medium used to make ovens.
and ---- BTW your bullet shell casing buckets are in my memory banks
Cheers,
Michael
Under the table:
Completed:
Vasa-Corel -
Superb work on this "cooking stove". Ready for a "grillade-party" 😀
I really love the paint job and the result is really great !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
Thanks everyone for the nice comments.
Brick walls can indeed just be bought. But my model shop in the city of Antwerp is closed because of Corona.
And actually the build of the stove was not that much work. Building about 1 h and painting 30 minutes.
Installing the stoove on the model took the longest time.
Removable grating will be provided later.
After the corona lock out,  BBQ on the ship for all members. :champagne-2:
(Does anyone have a shrink machine to make us all 45 times smaller?)
No but you could take it out and pump it to the right size for a BBQ
Very realistic Patrick. Don't hurt your back  moving the ship with the additional weight
Edited by cog
Carl
Hello everyone. Work in progress, update
Further work on the interior and the pots and pans of the chef.
Some brass cooking pots
Metal pans (actually a panther wheel and a copula of Russian armed car).
A Ladder.
And of course firewood.
IMG_20200506_192555.thumb.jpg.afa0492d95a6167a26dfe3d57257ba1a.jpgIMG_20200510_164943.thumb.jpg.936bee619ee85ad66a23884fdafbb19f.jpg
And the planking of the deck. The deck planking was more work than expected.
An example of a forecastle with some kind of grating.
IMG_20200506_195557.thumb.jpg.5dde3f5c5bc61498a55fd723cc5f9d66.jpgIMG_20200511_154021.thumb.jpg.22929cb65d44de3ff8d59124650861c1.jpgIMG_20200522_181108.thumb.jpg.2840f24c2f2989e2bab147964c6dfd7c.jpgIMG_20200522_181125.thumb.jpg.7bc50394bb4b6968ab3fc942be53a16d.jpgIMG_20200522_181648.thumb.jpg.aa51bd16ebe57ab834523bd106547167.jpg
A kitchen, pots and pans, but no food on the table.
Boring... 😴
While thinking about making the masts. I went looking for a wood lathe.
There are lathes for a reasonable price. New or second-hand.
But why don't I try to make one myself. Can't be that difficult. I thought
So all my spare time on the weekend is spent in a self-made lathe.
Ingredients
A drill.
Part of my worn out drill.
aluminium profile.
Bolts, nuts and screws.
Time...
And, to my own surprise, it worked. :Whew:
IMG_20200525_133145.thumb.jpg.bfa48b21ecf13fbaa50d0e540989d1d7.jpgIMG_20200525_123925.thumb.jpg.b22ef5ff225c08638ac77b923e2bf70f.jpgIMG_20200525_133024.thumb.jpg.1d29e2928b8768045ba57f2643897406.jpgIMG_20200525_133051.thumb.jpg.76dc6d8a90b9d87b392f439109f03204.jpgIMG_20200525_123900.thumb.jpg.4ffa4b079702e32462035e1a84388ac1.jpgIMG_20200525_144350.thumb.jpg.e6b4b5fb5324ec767f111856302f6c5b.jpgIMG_20200525_144409.thumb.jpg.a52be6cc85548be563a0a7d0da1ad87c.jpgIMG_20200525_144421.thumb.jpg.a52249e8317c6d66a6ad205037a7dd28.jpg
Mizzen, main, foremast and bowsprit.
Dry fitted (all still too long and not at the right angle)
I made mine almost the same, a bit lighter though, and bought a spinning centre for a lathe
diy.lathe_012.jpg.baa731458338378b854201603646819e.jpgdiy.lathe_011.jpg.7fa22136497847f57f746af04a896f9f.jpg
It seems I didn't put it back on in the jigs section after the crash on MSW 1.0. Thanks for showing, now I know how I can add a rest for the chisel
Carl
Finished the forecastle.
Made removable grating
IMG_20200524_195719.thumb.jpg.5ab1f4f8e3eae579308987c0d70102fc.jpgIMG_20200530_103231.thumb.jpg.3f7dfcdae2cfbfad59d992e1cbbd1242.jpgIMG_20200530_103254.thumb.jpg.eac41c9a1d557b459efedf063dda25cf.jpgIMG_20200530_103325.thumb.jpg.6df85ccd7140b12b92e2d0ab4a60f152.jpg
And we have a pelican on board.
I never thought I'd ever get this far building this Pelican
