Dear friends,
At the end of the last year I was deciding, what a ship will be next. I put aside all my favorites ships, and try to find something, what I never built. Then I found some informations of the wreck of fluit, lying next to Dalaro - and I decided for this one.
Simplified history:
Anna Maria was built for consortium of 15 shipowners in Swenden for trading route to Portugal and back, trading iron, copper and wooden planks from north and salt and wine from Portugal. In the winter 1708 / 1709 the ship stayed locked in ice in Dalaro. The crew was sent home except 5 sailors, who had guard the vessel. At the evening of 6 th february, after supper, the crew left the ship, and very soon she catch the fire and sunk under the ice.
Shipwreck was found and identified by amateur divers in 60´ts.
I found plans on russian webpages, they were created by Cor Emke, Bussum Netherland. Dimensions are in Amsterdam feets, so it was very easy to transform it to 1:96 scale. I will using all my technologies as always. I started the build in march of this year, but I didn´t have time to publicate on several forums.
As 1st step, as always, I transform hull lines to 3d, create holes for strenghtening and strengh the frame by wooden bars. As you can see, I had to create two ribs which aren´t included in plans.
Next pics showing frame with horizontal ribs and decks.
Link to post
Share on other sites
Then I continued with second part of layer of the bottom part of planking using 5 mm strips of drawing paper, I glued them across the first layer. Third layer of planking followed and the upper part of planking. The upper part of planking I made from four parts, the curvature on the aft I had to make separately. I sanded each part of planking.
Link to post
I continued with imitation of planking.I made it as always - using strips of foils ( after gluing of strips I´m using hairdryer to heat foil for better adherence ). The hull was " too shiny " , I patinated it to make a planking effect using aniline water colors. and colorless matt varnish. Then I painted bottom of the ship.
It looks like gunports are too close to watreline - but it si exactly based on plans.
Gratings you can see are laser cutted.
Link to post
And... after several months I finally found a little time to continue on the model. I made some doors, keel and improved planking on the lower part of keel considering to plans and Ab´s instructions ( I´m consulting build with Ab Hoving ) . I believe I will have much more time next months.
Next pictures shows the ship today. I will continue with wales and some parts on decks.
Jan
Link to post
Thank you very much for your kind words :)
The handrail is finished. You can see the result on following pictures - I´m quite satisfied. Now I have to repaint the inner part of sides by matt uncolored paint to remove traces of glue and I can continue with the equipment of the maindeck.
Jan
Link to post
This has been said before but... can't believe it's "just" paper!
For the record, the reason no one was on guard when the Anna Maria caught fire was quite specific: the drinks aboard were frozen solid so the last man left to join the others in the pub to warm himself with some of the still liquid variety. They were all awarded with a few days prison, after the shipowners asked the court to show leniency (makes me wonder if there were insurance frauds already then...).
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
