When I purchased the Bluenose from Model Shipways I also purchased the accompanying paint set.
I had seen some bad reviews about Model Expo's paints.  However I'm not sure if the Model Expo's paints are the same as the Model Shipway's paints.
It was a small investment to get the paint.  I was more concerned about getting the colours right.  Should I go ahead and use this paint or should I throw my investment in the trash and go another route.  I plan on using a brush and not airbrushing.  If in fact this paint is not recommended, is there something I can do (use thinners etc) to still use it.
Your comments would be most appreciated.
Derek
If you want to build a ship, don't drum up the men to gather wood, divide the work and give orders. Instead, teach them to yearn for the vast and endless sea
Antoine de Saint Exupery
Current Builds
Bluenose - Model Shipways - 1:64 Scale
Fair American - Model Shipways - 1:48 Scale
HMS Winchelsea 1764 - Group Build
On Deck
Guns of History Naval Smoothbore Deck Gun - 1:24 Scale
Finished Builds
Mare Nostrum - Artesania Latina - 1:35 Scale
Guns of History Carronade - Model Shipways - 1:24 Scale
I believe the ME paints are the MS paints (same company)...
As for tossing them.. test some on the woods you're using.  If all that needs to be done is thinning or some other trick of the painter's craft, use them.
Derek, they are water soluble so just thin them down to the consistency you want and brush them on - they go on okay and cover well. I personally find them a tad thick but they are okay to use. Don't throw them out.
Jack
Current buildUS Constellation
You can get a "universal Acrylic thinner" at Hobby Lobby and elsewhere.  It's worth trying to bring them back.
Maury
The biggest problem with them is inconsistency, so you have to thin then test, thin and test, and each color (and each jar) will me markedly different than the others.  I used them on my AVS and got good results, but I won't be using them again.  Also they are completely unsuitable for spraying if you ever go that route, they'll gum up your airbrush with rapidity as the pigment is not fine enough for airbrushing.
Since you already have them, I'd say give them a shot, and if you just don't like them, it's not that much money to replace as needed with Vallejo or something else higher quality.
Did you read Brian's (GuntherMT)  post above ? He answered your question.
Jack
Vallejo makes a paint specifically formulated for airbrushing straight from the bottle - no mixing or dilution required. They also make a formulation for applying with a brush. Both are available from Hobby Lobby or Micro-Mark (in NJ) mail order.
Edited by Jack12477
Jack
Amazon has the paint too.
I like Vallejo's paint.
Respectfully
12 minutes ago, mtaylor said:
What size hardwood?  Are we talking billets, logs, sheets, strips?    So... wide open question so the answer is depending one what, will determine the tool.   There's assorted power and hand saws, even Exacto blades.
Did you read the basic hand tools article here:  http://modelshipworldforum.com/ship-model-materials-and-tools.php ???   That section should answer all your tooling questions.
As Mark mentioned, did you read the article about materials and tools? I also posted that article for you to read in Chuck's planking questions.
I would sincerely recommend to read through many of the help and hint articles posted. Most of the questions will be answered there.
Respectfully
Check the ModelExpo website.
Respectfully
FWIW, I tossed the Model Shipways paints and went with Testors Model Masters acrylics, applied using a brush.  At the time the MS paints were thick and chunky, and I fell back on what I was comfortable with from my old plastic days.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
I hope I am adding useful information to this mix. Here goes.
I have yet to try these paints as I was a "committed" Floquil user for many years and had good results (spraying or brush) with them albeit the toxicity was a constant worry. When I returned to modeling recently I was disappointed to learn of the demise of the company. I turned to Model Master paints as an alternative and found them to be a reasonable substitute although I am still in the experimental stage. I did run across this chart on the web that correlates the 2 brands. It i MEhttp://www.microscale.com/Floquil Color Chart.pdfs . I have also been looking at Tru Color paints trucolorpaint.com which are supposed to be comparable to Floquil paints in propertiies if not color. I have tried to get a chart comparison from them but the last time I tried they never came through. Both MM and Tru Color are mixable to get any hue or color one is looking for. I solicit comments from others.
43 minutes ago, singhnick348 said:
What is the average price for a bottle of Vallejo acrylic paint?
Do you ever do your own research ? Or do you expect us to do it for you?
ModelExpo - Vallejo paints
Hobby Lobby - Vallejo paints
Edited by Jack12477
Jack
Nick....
Google is your friend.  Heard of it?
7 minutes ago, mtaylor said:
Nick....
If not Google, Bing it!
Respectfully
I have bought and used the model shipways paint and have to agree with Brian that it is very inconsistent.  I have several jars of their paint that were never opened before and yet when opened the paint appeared to be a shrunken hockey puck!  Some of them were more the consistency of paste, and even with prolonged mixing and thinning with water, required much sanding to eliminate the coarseness of the finish.  I don't know if somewhere in shipping they were frozen or what.  On the other hand. some of the others that I was able to use seemed to work just fine.  So my opinion is to search for another brand or hope you get lucky.
Dave
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
I built the Bluenose II and wanted a midnight blue color for the upper hull and a rust red for below the waterline. I couldn't find what I wanted in any brand of paint. I went to Lowes and looked at all their paint color chips and found the colors I wanted. I had them make me a trial jar of each color using eggshell acrylic base. I thinned this 20% with distilled water, Brushed on several coats, and finished with a satin Wipe-on-poly. Came out very nice. At $3.95 for an 8 oz. jar, you can't beat this.
MS paint dried up very quickly once a jar was opened.
So I did a try with our food vacuum sealer, shh don't tell the admiral,
Process:
1 - opened the jar - did some painting on a test piece of wood, that meaning returning the brush back to the jar.
2- closed the lid - only hand tight
3 - put the jar in a sealant bag, used the vacuum sealer
4 - had it sit for one week.
5 -  open the bag and jar, not completely dry paint but much more dense.  Couldn't get it diluted properly.
Wonder if there is something of the chemistry of the paint that causes it.....
I am not a chemist maybe someone else has an explanation.
Respectfully
Pet peeve of mine: Floquil paints are not "acetone based" and Acrylics are not "water based". In both cases the water and acetone are in the case of the Floquil, solvents for the paint polymer vehicle or, in the case of Acrylics, they are water borne i.e. they are suspended in the water by various means but not soluble in the water(acrylic paint vehicles have little or no water solubility depending on their acrylic polymer's composition). There are acrylic paint vehicles that are soluble in the appropriate solvent blend (KRYLON spray paints for example). Some acrylic vehicles have partial solubility in water alcohol mixes which is how acrylic water borne hobby paints develop good flow and level properties.
Best
Jaxboat
  • 5 weeks later...
I've taken to using Vallejo's paints. they brush on nice and smooth and coverage is excellent and are very vibrant, They also come in a good sized bottle.
Paul
In Work: HMS Hood
Finished: -queen-mary-2
Finished: rms-titanic-1912
Finished: king-of-the-Mississippi
Finished: Sanson
Hello Les here. Here's my short primmer on paint. Sand out wood till smooth. If you have a compressor blow off sanding dust and wipe down with a damp lint free cloth. Blow off again. Over bare wood I use Humbrol or Testors flat oils.  Oil soaks into wood and seals better than latex. Spray or brush on in a light coat. After 12 hours sand lightly and repeat if necessary. Now your good to go. Use oil or latex for your top coats. A smooth base will give you a good start on the top coat. I have seen many finishes ruined by a lack of proper pre prep.
Hi Les,
Check my March 31 post if you haven't already. It may give you some ideas. As everyone says, the work is in the preparation, filling and sanding to very smooth. Then a primer. Several thinned coats work much better than one thick coat.
Regards
I agree with you Michael.  I used Home Depot because it's close to home. They even can match a color swatch.  Thinning is necessary to get a smooth finish. That's the best deal you will ever find.
Pythagoras (Tom)
Confusion continues for this novice.
In another section in this category, I asked about using paint samples from Lowes or Home Depot.  I received several answers describing that paint pigment's will be to large and cover detail.  I specifically mentioned latex, which is also mentioned above.  Does thinning reduce pigment size?
Chuck A
Chuck A.
If at first you don't succeed, destroy all evidence that you even tried.
No, the pigment size is determined when the pigment is ground up.  Thinning only affects the liquid part of the paint - regardless of being latex or oil based.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Pigment is prepared for incorporation into paints and inks in various ways. The general term is grinding. Energy is applied to the pigment to disaggregate the particles and wet them. I have made water borne acrylic house paint in a lab with a Waring blender. The finer the pigment the smoother the finish. House paints from home depot are not going to have the finer sized pigments of a good quality waterborne paint. BTW: not all waterborne paints are latex. Latex emulsions are totally insoluble in water.They are stabilized in water as emulsions by surfactants (soaps). Some waterborne paints have limited water solubility and are called water reducible. Such solubility aides in pigment dispersion and flow and leveling during application either by brush or spray. Waterborne acrylics are very sophisticated and chemically complicated beasts.
Hello Les here. As a cabinet maker, I spray my own finishes. I thought man I can save big money and buy a quart of latex paint for 12 bucks where a tiny bottle of Testors or Humbrol is 4 bucks. Didn't work out so well with my airbrush. However it has to do with how finely the pigments are ground. Trying to airbrush with Benjamin Moore paints won't work, nice if you use a Binks automotive sprayer  to spray cars and furniture. Trust me on this issue. Hand brushing works out well but you may have to thin it out a little to get an acceptable base coat. Top coats the same procedure. Overall I still prefer an oil base top coat as it has a longer flash over time so you can go back and smooth out brush strokes. Latex based paints have come a very long way and the VOC loads are lower. Great if you don't work in a ventilated area. Practice is most important. A poor quality paint finish can ruin your best efforts. You don't want any model to look like it was painted with a broom.
