I think "Wow!!!!!!!!!!" is about all I can come up with right now.   Just marvelous.
A friend of mine recommended today that I look at your log.  After looking through only a few of the recent pages I'm absolutely in awe of your build.  I plan to spend a lot of time catching up from the beginning - I think I'm going to learn a lot by doing so.
hello to all latest pictures of the construction site Fleuron
upcoming releases in a few weeks
amicably
If a day will be reproached you that your job has not been done with professionalism, you answer that the ark of Noè has been built by dilettantes and the Titanic by professionals. ;)
Absolutely beautiful work. I have a question relating to the large number of "Nails/rivets " on the inside of the cannon port doors there seem to be more than I would have thought necessary to hold the tin planks inside the outer ones?
Michael
hi Micheal
served to protect the wood by the impact of the guns were opened when the gunboats
Giorgio
Giorgio, thank you for your explanation.
michael
just amazing , and your choice of "le fleuron" is just the good one!
and you did a good job!
Of the bank I look at an ocean of pleasure, or the tumult attracts you, this global movement will be your tipcart!
current build:   royal caroline
buid finished:  la recouvrancehttp://modelshipworld.com/index.php/topic/3025-la-recouvrance-by-ofencer29350/page-2?hl=recouvrance
Beyond words, Giorgio.    Just amazing.
Hi
small advances of the ship fleuron
follow more photos......
Edited by rekon54
soon with new updates
Rekon54
Edited by rekon54
Beautiful work, Rekon.
Question: does the lower end of the rudder actually extend as far as the bottom of the false keel? In English ships, the rudder was always shorter, in case the ship touched ground.
