HMS Kingfisher 1770 by Remcohe - 1/48 - English 14-Gun Sloop - POF
My bet is on a hypodermic needle chisel. All you need is a steady hand and a good set of eyes.
This seems more difficult then a scraper, at least you have a guide edge with that.
Very nice work Remco!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Link to comment
Share on other sites
Stunning simply Stunning :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Thanks guys, I really appreciate the comments  :D
So how did I do it, the how-to was indeed like Jan noticed in the first picture. The divider was used to scrape a thin line evenly spaced from the bottom of the gallow. Multiple passes with very light pressure were needed to cut through the grain. In the middle the cut was done free hand.
Then I used a slightly blunted threading needle to make the molding, again multiple passes and the wood shaped nicely.
And yes Piet  I do have some miniature 0.4 mm chisels made from hypodermic needles and thin steel but I use them elsewhere ;)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Link to comment
Link to comment
I finally found my way back to my workshop. Real life, other projects and a bit of modelers block got in the way. I finished beam 11 with the hanging knees and now I moved to the bow section to built the fore platform.
The footwalling already has it's final finish so the bare wood looks light in contrast.
Two more platforms coming up...
Remco
ps Ben, nope I'm not a brain surgeon, nor something alike  ;-)
Link to comment
Ah, glad to see you back at it Remco!  How's the Admiral's table coming along? ;)
Cheers,
                       VOC Ship Surabaya
Link to comment
Nice to see you back in the shop Remco - I've missed your lovely build.
Link to comment
Thanks so much guys.
The second part of the fore platform is taking shape. The planking is treenailed, the scarph joint is simulated
Remco
ps Piet it's not on the drawing table yet....
Link to comment
Great work. Lots of attention to detail. Will continue to follow your build. I got a few nice ideas from this post thank you.
Regards, Scott
Completed builds:
Awaiting construction:
Link to comment
Thanks Scott, John.
I had to rebuild the forward small platform as the deck pillar didn't line up with the deckbeam above.
More deck pillars and stancions added, a small portion of the bulkhead is made too. The upper breast hook was made using card templates and trimmed further until a snug fit was obtained.
Remco
Link to comment
It's tricky, trying to keep in mind everything above the deck you are working on aligning properly later. I'm glad that you caught that earlier rather than too late!
Link to comment
Nice details again! Good to see some action, 'though I understand it is sometimes better to take a brake
Carl
Link to comment
Very interesting process on the copper bolts, Remco. Thanks for posting.
Ed
Link to comment
Trying is the right word, and then comes hoping you've got it all in the right spot. Glad this was an easy fix, further down it would have been impossible...
Ed I now use a cup burr that works even better
Here the third platform is partially complete and the riding bitt's are test fitted, hard to see but they taper quite dramatically towards the bottom of the hull.
This is one of those jobs where I would like to have 6 extra hands  ;-)
Remco
Link to comment
Thanks guys, but who said I only have 2? ;)
The 3rd section of the platform needed more detailing, now I can move on to adding detail to the riding bitt's.
Remco
Link to comment
Remco,
That is a very interesting cup bur. Does it have a name. The problem I have with the ones I use is that they quickly plug up with copper and stop cutting. Yors looks interesting. I will look for it.
Thanks,
Ed
Link to comment
Remco,
One search and I found it. Fox Champion Cup burs. Worth a try. Thanks, again.
Ed
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
